White95
Post your engine combination!!! [Pushrods]
351 Windosr
Stock bottom end
FTI Custom Camshaft
FTI 234HR Trick Flow High Port Heads
Victor 5.8 Intake
#36lb injectors
Accufab 1 5/8 Longtubes
Accufab 75MM TB
PMAS 90MM Mass Air
351 Windosr
Stock bottom end
FTI Custom Camshaft
Victor 5.8 Intake
#36lb injectors
Accufab 75MM TB
PMAS 90MM Mass Air
Whats up travis? Did you sort out your problem yet or is it still snowing up there lol
Ported gt40's,comp dual springs and retainers,5 angle valve job,proform 1.6 ratio roller rockers, comp xe264hr-14 cam, ported explorer intake, 75mm prof. Products throttle body, 75mm pro-m maf calibrated for stock 19# injectors, fender style coldcair intake, 1step colder plugs, 13* base timing..
No numbers or runtime yet..
Sent via Galaxy S4 active..
stock block .030 over
dss 331 rotating assembly with a scat cast 9000 crank
trickflow 170cnc with 7/16 studs
comp ultra gold rockers
comp billet double roller timing chain
fti custom camshaft
arp hardware throughout
tmoss ported 94 cobra intake
70mm tb
#38 injectors
pro m 80 maf
powerpipe
aromotive stealth 340 pump
3 row aluminum radiatorpost-572-1388183959231_thumb.jpghoping to get it together soon
I got a sad r352.3
tfs225r
10.3-1
ysi
solid roller, .700 lift 262 268 duration @.050 and alittle vortech ys
On going project, 94 cobra, r block, tfsr225, hp efi, vortech ys
Instagram [MENTION=584]Rolocut[/MENTION]
not to get off the subject @SVT Rob I want to see more of the RX7!
That's my buddys car, it's LS1/T56 swapped, Trex cam, ported heads, ported LS6 intake, ported LS6 throttle body, 42lb injectors, dyno's ~470 to the rear wheels. His last time at the track, he ran an 11.9 @ 127mph w/ a 2.3 60'. Poor track prep, he couldn't get his DR's to hook up at all. Previous outing before the cam and heads, he ran an 11.9 @ 112 w/ a 1.8 60'.
Stock HCI
Procharger 3.4 pulley @ 13 psi with custom 8 rib
3 core intercooler
Anderson Powerpipe
75mm Throttle body
Smog delete
Battery relocated to trunk
Lucas 42lb injectors
Walbro 255lph fuel pump
Transmission:
Tremec 3550
Unknown short throw shifter
Aftermarket clutch (unsure on brand)
Ford Racing Clutch cable + Quadrant
Exhaust:
Mac Equal Length Headers
Pypes Catless X Pipe
Flowtech Terminator Mufflers
2.5 inch SS foxbody LX Tailpipes
  • Supporting Member
still waiting to go in the car!
306
stock rods and crank
TRW pistons
GT40 irons with FTI spring package
FTI custom cam
1.72 scorpion rockers
Cobra Intake - powder coated
all ARP hardware
What are you expecting to put down? I assume you will be getting a chip burned as well?
I'm guessing that I should make at least 50HP more than stock, with at least that in torque.  There will be NO chip, tuning device, tune - stock computer only.
  • Supporting Member
Very nice. I look forward to hearing what you do put down for final numbers. Is there a build thread? I can search and am not too lazy but currently on mobile. If so I'll go searching.
There sure is!
http://www.sn95source.com/topic/3116-new-project-daily-driver-motor/
Sportsman block stroked/bored 331 w girdle.
Scat crank and rods clevite bearings
Mahle forged pistons (16cc dish) cr 8:7:1
Gt40x heads Port and polished larger valves 10*locks and retainers
Trick flow roller chain and pushrods.
Fms blue 1.6 rockers
Anderson b31 cam
Systemax upper ported truck lower
Fox TB 75mm Holley tb
V2 s trim blower asp crank pulley with 3.33 pulley
Red race blow off valve
Pro M 80mm blow through.
So I have been holding out on everyone for a bit. The engine builder I have is Steve Lapointe. He builds pretty nasty motors. One of which set the record in extreme street eta2ava2.jpg
So needless to say. I picked up that motor completely refreshed and everything new with a new Cnc program on the heads that fox lake has not released to the public, and a ported funnel web along with those new headers that were not on the motor when the record was set.
Motors a 364.
Victor race heads 7721, fox lake Cnc
L19 head studs--2k new
Stiched heads and block
Iron eagle, billet mains
Callie's billet crank
Callie's billet rods
You get the idea
Around 40g into motor.
This will be used for a new project, prob x275, xtreme street or ultra street car
This is probably the most bad ass small block ford ever built with unlimited power capability
Instagram @rolocut
That's bad ass . This is my home boys 401ci f1x procharged setup , last night out of the year he went 8.01 at 173mph it will be in the 7's come spring .... I vote for doing a x275 car it's the way to go . 440D5334-481D-481D-BD1A-761A8F75F804-208
im still such a noob. every time i see a bunch of AN fittings i get all excited. thats a nice looking set up!
A/N fittings make everyone excited especially when there large and in charge
Yeah, thats a bad ass set up. This was an extreme Street car the motor was in so it was and still is limited blower size. They just made a smaller limit on that. X275 is 1/8th mile and xtreme street is 1/4 mile. New car will not look to much different from my set up. I will however do procharger so i can just swap head units for the class im in between f1x and f1r or f1c. i like to seethe air to air intercooler. All the fast cars use either no intercooler or a air water and thats just not street friendly lol. When i do mine it will be air to air aswell. But of course ill have my own custom aluminum touches on it.
Yea he races in whatever class the car fits , x275 worked for one of the events this past year it's actually a air to water setup , the car no longer sees street duties it has dual batteries now 26F912E7-8C38-4A3C-97CB-D8699C2A8343-208
773ADB3E-0B30-4460-ABAD-6263EA2CFB28-208
What would you suggest is the best
Intake manifold, heads, cam, and throttle body size with the size of the MAF sensor and suspension
Im still learning and trying to research before I start buying parts.
Any advice will help :)
Its a daily driven car but I want to have more power, not trying to make it crazy fast but maybe around 350rwhp
Hey frank, throw up a new thread for your topic. Include your goals for the car, do you just want to street drive it? Track it? Drag or autox? All these make a difference in which direction to build a car.
NEver noticed the horseshoe in this pic hah. nice touch
