Det_Riot Posted August 23, 2013 Report Share Posted August 23, 2013 Yupp, Swapped the tr3550 and ended up running times comparable to before my HCI was running right -__-edit: I'll update later, I had about 11 runs. previous best: 14.2@107 with a 2.45 60'Yesterday's best: 14.0@98 with a 2.08 60' Link to comment Share on other sites More sharing options...
SiK98GT Posted August 23, 2013 Report Share Posted August 23, 2013 Thpse 60 foots are killing you dude. Get down to a 1.8 or so and you could be running mid 13sSent from my Modded and overclocked Galaxy S2 Link to comment Share on other sites More sharing options...
Det_Riot Posted August 23, 2013 Author Report Share Posted August 23, 2013 More concerned with the fact i lost 10mph since march o_0 lol Link to comment Share on other sites More sharing options...
copmagnet Posted August 23, 2013 Report Share Posted August 23, 2013 scared to get a red light? punch it on the last yellow, LOL Link to comment Share on other sites More sharing options...
1997cobra Posted August 23, 2013 Report Share Posted August 23, 2013 we just need to swap my axle in one of these weekends..its seriously less then a days work... try it before you buy it Link to comment Share on other sites More sharing options...
Knuckles Posted August 23, 2013 Report Share Posted August 23, 2013 scared to get a red light? punch it on the last yellow, LOLhuh? how is his reaction time playing into this.10mph is pretty serious drop your car should most definetely be running quicker than this. Link to comment Share on other sites More sharing options...
wmfateam Posted August 23, 2013 Report Share Posted August 23, 2013 Going in shallow will help time and speed a tiny little tid bit. Link to comment Share on other sites More sharing options...
copmagnet Posted August 23, 2013 Report Share Posted August 23, 2013 huh? how is his reaction time playing into this.10mph is pretty serious drop your car should most definetely be running quicker than this.depends on how his track runs the light. ours changes between time starting on the green and time starting once the vehicle crosses the line. they call it "time attack" or some gay shit. Link to comment Share on other sites More sharing options...
Yeahloh95 Posted August 23, 2013 Report Share Posted August 23, 2013 something doesnt add up, is the clutch slipping ? 10 mph is like 100 hp loss, what was 1/8 mph ? Link to comment Share on other sites More sharing options...
copmagnet Posted August 23, 2013 Report Share Posted August 23, 2013 still have that ghetto rigged cable set up? Link to comment Share on other sites More sharing options...
Musturd Posted August 23, 2013 Report Share Posted August 23, 2013 Yea the bottom run is bang on mph and trap speed for the most part previous best you were frying em Link to comment Share on other sites More sharing options...
NVRL8TE Posted August 23, 2013 Report Share Posted August 23, 2013 Your car was trapping 117? Link to comment Share on other sites More sharing options...
Musturd Posted August 23, 2013 Report Share Posted August 23, 2013 107 which is where I think it would roughly be within a few mph 110 isn't by any means impossible with his car it's a low 12 second car with ease on a sticky tire . Link to comment Share on other sites More sharing options...
itsblown93 Posted August 23, 2013 Report Share Posted August 23, 2013 Get rid of your stock gears that will help out more then you think Link to comment Share on other sites More sharing options...
F8L GT Posted August 23, 2013 Report Share Posted August 23, 2013 Your car was trapping 117?No, his previous was 107 and now running 98Sent from my MILESTONE3 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Musturd Posted August 23, 2013 Report Share Posted August 23, 2013 Say what ? He's rolling on stock gears ? Yea get some gears in that beetch Link to comment Share on other sites More sharing options...
Det_Riot Posted August 23, 2013 Author Report Share Posted August 23, 2013 we just need to swap my axle in one of these weekends..its seriously less then a days work... try it before you buy it I'm pretty alright with this. Then we don't even need to pull out axles for your big brake kit!scared to get a red light? punch it on the last yellow, LOLhuh? how is his reaction time playing into this.10mph is pretty serious drop your car should most definetely be running quicker than this.Yupp basically Going in shallow will help time and speed a tiny little tid bit.Going in shallow?something doesnt add up, is the clutch slipping ? 10 mph is like 100 hp loss, what was 1/8 mph ?No clutch slip, new clutch this past Junestill have that ghetto rigged cable set up?FixedYea the bottom run is bang on mph and trap speed for the most part previous best you were frying emNope hooking and bogging for the most part even when launching at almost redline. The 14.0 run I had a little too much tire spin off the lineGet rid of your stock gears that will help out more then you thinkI was trampling 107 on stock gears LolSay what ? He's rolling on stock gears ? Yea get some gears in that beetchSo basically here's what I think happened. When I swapped the tr3550 in, the previous owner said it was built to tko500 specs. Well by that I think he meant gear ratios. If that's what happened, my first gear dropped from a 3.35 in the t-5 to a 2.87 in the tr3550. I back checked off of an online gear to speed calculator and the numbers seem to make sense for the dramatic loss of mph. In order to make up for the gear loss in the trans, I'd have to run a 3.31 to put me back near 3.08 quality. And at least a 4.10 to put me to the equivalent of a 373 with a t5 Posted via Topify using Android Link to comment Share on other sites More sharing options...
Musturd Posted August 23, 2013 Report Share Posted August 23, 2013 That's exactly it the gear ratios drastically can change with the gearing in these trans. How much psi are you running in those mt drag radials to , you should be able to cut 1.7-1.8 60fts with those. I've never used drag radials on a stick car because they can be violent Link to comment Share on other sites More sharing options...
F8L GT Posted August 23, 2013 Report Share Posted August 23, 2013 Well that explains why they were hooking and bogging. You didn't have enough gear to do any good . And going in deep as known as deep staging, you roll in till you shut off they pre stage lights and just have stage lights litSent from my MILESTONE3 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Steve@CJPP Posted August 23, 2013 Report Share Posted August 23, 2013 dude you didn't tell me last night you were sleeping at the light. holy 60 batman. YELLOWYELLOWYELLDUMP CLUTCHOWGREEN (at this point your foot shouldn't come off the gas pedal till you come through the traps)HE GONE!! Link to comment Share on other sites More sharing options...
1997cobra Posted August 23, 2013 Report Share Posted August 23, 2013 Sadly, I need to go with a new edge axle Posted via Topify using Android Link to comment Share on other sites More sharing options...
F8L GT Posted August 23, 2013 Report Share Posted August 23, 2013 Lol [MENTION=270]Steve@CJPP[/MENTION] what's sleeping at the light have to do with the 60' lolSent from my MILESTONE3 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Steve@CJPP Posted August 23, 2013 Report Share Posted August 23, 2013 Lol @Steve@CJPP what's sleeping at the light have to do with the 60' lolSent from my MILESTONE3 using Tapatalk 2because he carried that sleepiness right through his sixty foot lol Link to comment Share on other sites More sharing options...
F8L GT Posted August 23, 2013 Report Share Posted August 23, 2013 because he carried that sleepiness right through his sixty foot lolTime doesn't start until the car moves. I can see that 60' from him hooking and bogging way downSent from my MILESTONE3 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Steve@CJPP Posted August 23, 2013 Report Share Posted August 23, 2013 Time doesn't start until the car moves. I can see that 60' from him hooking and bogging way downSent from my MILESTONE3 using Tapatalk 2lol Mike you missed the sarcasm didn't you, that was me busting his balls. :trollface: Link to comment Share on other sites More sharing options...
F8L GT Posted August 23, 2013 Report Share Posted August 23, 2013 I see it now. Its the lack of sleep lolSent from my MILESTONE3 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Steve@CJPP Posted August 23, 2013 Report Share Posted August 23, 2013 I see it now. Its the lack of sleep lolSent from my MILESTONE3 using Tapatalk 2lol it's all good brotha. :drinktothat: Link to comment Share on other sites More sharing options...
wmfateam Posted August 23, 2013 Report Share Posted August 23, 2013 Shallow is when you stop as soon as the second stageing lights come on, barley moving into the beam, it is like having a 6 inch head start (hehe that sounded dirty) Link to comment Share on other sites More sharing options...
F8L GT Posted August 23, 2013 Report Share Posted August 23, 2013 Shallow is when you stop as soon as the second stageing lights come on, barley moving into the beam, it is like having a 6 inch head start (hehe that sounded dirty)Wow I really need to stop posting when I only sleep for an hour. For sinew rain I thought it said deep lol. setting your front caster alignment can also give you a little edge on the lightsSent from my MILESTONE3 using Tapatalk 2 Link to comment Share on other sites More sharing options...
wmfateam Posted August 23, 2013 Report Share Posted August 23, 2013 Wow I really need to stop posting when I only sleep for an hour. For sinew rain I thought it said deep lol. setting your front caster alignment can also give you a little edge on the lightsSent from my MILESTONE3 using Tapatalk 2Well now everyone knows both ways to stage, so now he just needs to pull off a perfect light and join the club. It was funny when I beat a guy with a faster time but he was sleeping at the line. Link to comment Share on other sites More sharing options...
Musturd Posted August 24, 2013 Report Share Posted August 24, 2013 I've been racing for years and only recently learned about staging shallow and deep on a bracket day Link to comment Share on other sites More sharing options...
Yeahloh95 Posted August 24, 2013 Report Share Posted August 24, 2013 are you going thru the traps in 3rd gear ? Link to comment Share on other sites More sharing options...
Det_Riot Posted August 24, 2013 Author Report Share Posted August 24, 2013 So fucking around at wok with some numbers and here's what I got:3.90s4.10s4.30sI'd post up the comparison to the t5 but I didn't take a picture that way. The 430s are equivalent to a t5 with 410s, 410s to 373s, 390s to like a 373. Hell id need a 331 to get back to a stock gear throughout the car haha now I just got to decide what gear is for me Link to comment Share on other sites More sharing options...
95opal Posted August 24, 2013 Report Share Posted August 24, 2013 410 s nothing less Link to comment Share on other sites More sharing options...
Det_Riot Posted August 24, 2013 Author Report Share Posted August 24, 2013 410 s nothing lessWhy's that? Link to comment Share on other sites More sharing options...
Yeahloh95 Posted August 24, 2013 Report Share Posted August 24, 2013 you cant fear the gear Link to comment Share on other sites More sharing options...
smallblocksn95 Posted August 25, 2013 Report Share Posted August 25, 2013 I put 3.90s in Alyssa's....runs pretty good Link to comment Share on other sites More sharing options...
Det_Riot Posted August 25, 2013 Author Report Share Posted August 25, 2013 I put 3.90s in Alyssa's....runs pretty goodShe's got hci right? Or not yet? How is it on the highway? Link to comment Share on other sites More sharing options...
smallblocksn95 Posted August 25, 2013 Report Share Posted August 25, 2013 Her motor is completely stock, she pulls 2500 at 70mph. Mpg barley changed highway, in town went up obviously Link to comment Share on other sites More sharing options...
Schiffy Posted August 25, 2013 Report Share Posted August 25, 2013 4.56's or bust!!!!!!! Lmao Link to comment Share on other sites More sharing options...
