Prokiller
February ROTM Voting - Build thread
February ROTM
19 members have voted
  1. 1. Who has the best build?
    • arayray
      2
    • SublimeRT
      7
    • 95opal
      10
Yes i know it's already February 1st as I post this but sadly that's because I was trying to get as many nominee's submissions as possible.  In the end we're back to three this month even though we had such awesome participation in the nomination thread.  To recap, this month we are trying to select the best SN95 build out there.  It's kind of hard to really sit here and say this car is the best when most of the parts may not even be bought yet but I wanted the contestants to give you a sense of the direction of the build other than just where it stands now.  So when you vote, take into account both what the car currently has and where the plans are going to take it.  I've also asked each individual to give us a picture or two of a project aspect that they are of which particularly proud.
arayray
Here is my 1996 Cobra that I bought on 11/17/12 after selling my first car (98 v6). Some mods that were done to the car before I owned it: 3.73 gears, Magnaflow Tru-x Catted X pipe, Mac Catback, S281 Wing and 04 Cobra Wheels.
Now here is the full list of mods:
WISH LIST/TO DO:
  • SHAVE & REPAINT ENGINE BAY
  • WIRE TUCK ENGINE BAY
  • AEROCATCH HOOD LATCH/PINS
  • ENGINE REPLACEMENT EITHER: SUPERCHARGERED COBRA MOTOR OR COYOTE SWAP
  • TRANSMISSION REPLACEMENT: T56
  • IRS BUSHINGS, GEARS AND POWDERCOAT
  • DOUBLE DIN CONVERSION W/ TOUCHSCREEN RADIO
  • PAINT TO MATCH WIPER COWL
  • RETROFIT HEADLIGHTS
EXTERIOR:
  • CUSTOM PAINTED 12 INCH 'SPIRITED GREEN METALLIC' STRIPES
  • S281 SPOILER
  • FOLDING 04 COBRA MIRRORS
  • CUSTOM SMOKED HEADLIGHTS & TAILLIGHTS
  • SEQUENTIAL TAILLIGHT HARNESS
  • 3K COOL WHITE HID HEADLIGHT & FOGLIGHTS
  • CUSTOM HAND PAINTED COBRA EMBLEMS
  • 20% WINDOW TINT W/ FRONT BANNER
INTERIOR:
  • 04 COBRA CONSOLE PAINTED BLACK
  • AUTOMETER GAUGE POD W/ WIDEBAND & COOLANT TEMP
  • REDLINE GOODS LEATHER SHIFT & EBRAKE BOOT
  • GREEN FOOTWELL & CUP HOLDER LEDS
  • BULLITT PEDAL COVERS
ENGINE:
  • BBK CERAMIC LONG TUBE HEADERS
  • BBK OFF-ROAD X PIPE
  • POWDERCOATED GREEN VALVE COVERS
  • POWDERCOATED UPPER INTAKE
  • POWDERCOATED COP COVERS
  • EGR & SAI DELETE
  • COP CONVERSION
  • CUSTOM HAND PAINTED INTAKE PLAQUE
  • ON3 PERFORMANCE BRAIDED COOLANT HOSES
  • JLT RAM AIR INTAKE
DRIVETRAIN:
  • STOCK T45 WITH MGW SHIFTER
  • RAM HDX CLUTCH
  • STEEDA CLUTCH QUADRANT
  • MM FIREWALL ADJUSTER
  • 01 IRS W/ STOCK GEARS
SUSPENSION:
  • H&R RACE SPRINGS
  • 04 BILSTEIN TAKEOFFS
  • MM SUBFRAME CONNECTORS
  • POWDERCOATED STEEDA FRONT SWAY BAR
WHEELS & TIRES:
  • 18X9 BLACK SALEENS
  • 245/35/18 NITTO EXTREME PERFORMANCE N555
  • POWDERCOATED CALIPERS W/ HAND PAINTED LETTERING
  • BLACK ZINC COATED DIMPLE & SLOTTED ROTORS
  • CERAMIC BRAKE PADS
Here's a couple shots of some of the custom touches:
SublimeRT
'94 Cobra Rio Red w/ black interior
Performance
-302 Based SBF.  Displacement, heads, & internal components to be determined
-Carburated
-Naturally aspirated
-Pump gas
-Complete aftermarket fuel system including tank.  Specifics TBD
-Tremec TKO600 transmission.  Modified with Road Race .082 5th gear
-Engine/trans relocated rearward in chassis
Suspension
-Front suspension moved forward 5-6" to increase wheelbase
-Modified/converted Maximum Motorsports tubular front suspension to SLA with coil-overs
-Stock MacPherson strut towers removed in favor of tubular steel front end in cojunction with the factory frame rails, tied into the cage, along with completely smoothed engine bay
-8.8 solid rear axle
-3-link rear suspension with coil-overs
-Manual 4 wheel disc brakes.  Master cylinder, calipers, and rotors TBD
Exterior
-Custom steel widebody
-Front:  1.5" wider each side at center of wheel arch - 3" total wider at front wheel centerline
-Rear:  2" wider each side at center of wheel arch - 4" wider total at rear wheel centerline
-Rear end/bumper/tail panel widened 3" total to meet up and blend in with widened rear quarters
-Doors widened 3/4" at rear edge, starting at the front of the door, to blend in with widened rear quarters
-Enlarged/smoothed quarter panel scoops
-Custom steel rocker panels
-Custom duck tail rear spoiler
-Shaved exterior stock door handles and locks, replaced with custom door handles for smoother look
-Shaved antenna
-HID retrofitted headlights
-Full respray inside and out, top to bottom
Interior
-Custom gauge cluster with Speedhut gauges
-Center console deleted
-Quick-release steering wheel
-Kirkey Road Race aluminum seats relocated rearward
-Pedals, shifter, and steering wheel extended rearward to accomodate relocated seat
-DOM tube full cage with NASCAR style door bars with integrated rear coil-over mounts, transmission crossmember and driveshaft safety loop, seat mounts, and front coil-over mounts
-Modified stock doors and door panels to accept NASCAR door bars and retain factory style door handles and power windows
-2"x3" steel rectangle full length subframe connectors
-Custom sheet metal floor
-Custom sheet metal trunk floor and rear wheel tubs
-Cage to body gussets throughout
Wheels/Tires
-Wheel style, size, and manufacturer TBD, but I like 18" wheels of the 5 spoke variety.  Somewhere around 18x12/13 rears, 18x11 fronts.
-Tire size and manufacturer TBD.  Somewhere in the neighborhood of 335/345 rears, 315 fronts
95opal
Performance:
Engine:
Dart SHP Machined Block
FordStrokers/RPM 4340 Forged Steel 3.250 Crankshaft -
INTERNAL
FordStrokers/RPM 4340 Forged Steel H Beam Connecting
Rods 5.400
Wiseco 2618 Forged Pistons (14cc, Inline) 4.030
Wiseco GFX Ring Package
Clevite 77 H Main Bearings
Clevite 77 H Rod Bearings
Dart Coated Cam Bearings
Screw in Oil Galley Plugs
Fel Pro Rear Main Seal
ARP Main Studs
Freeze Plugs
Cam Bolt
Cam Retainer Plate
SA Gear Billet Timing Chain w/Torrington Bearing
Melling Oil Pump M68
ARP Oil Pump Bolts
Moroso Oil Pump Pick up 24519
ARP Billet Oil Pumpshaft
Fel Pro 1 Piece Pan Gasket
Morel link bar lifters
FTI prepped AFR 195 competition heads
 Comp cams 1.6 Ultra Pro Magnum rockers
FTI ported holley systemax
FTI custom blower cam
Accufab 75mm t body
Pmas 95mm MAF
Deca 80# injectors
Polished 8 rib Vortech si renegade package with Mondo valve
Duel nozel Snow performance stage 2 meth injection
Zex 100 shot wet kit
Custom sumped 19 gallon RCI fuel cell 10AN feed 8An return
Aeromotive A1000 pump with A1000 regulator
BBRC billet fuel rails
MSD 6al
Relocated MSD coil
SCT 4 banck chip
Mezier remote mount water pump
custom smoothed bay
wire tuck
Brake line tuck
ABS dele3te
 custom built fan shroud and core cover
Promotion built tr3650 race version (1000hp)
Stifflers trans crossmember and driveshaft safety loop
Pro 5.0 shifter
Suspension:
Team z auto x K-member
team z Auto x tubular A arms
MM2 Race series coilovers
Wilwood  14" 6 piston calipers
Wilwood Polished tandem master cylinder and proportioning valve
Wilwood 13" 4 piston rear calipers
MM manual brake conversion
MM Manual steering shaft
Flaming river quick ratio manual rack
Steeda front and rear sway bars
energy suspension end links
Steeda bump steer kit
MM caster camber plates
Team z mini tub kit
Qa1 rear coil overs
Steeda lower control arms
Steeda double adjustable upper arms
built and narrowed ( 6") 3.73  8.8 rear with Custom bracing and CHE axle  brace
Stifflers fit system
Stifflers spyder bracing
Stifflers K-member brace
20x12  & 19 x 9 custom forged wheels
345/25/20 &  275/30/19 nitto invos
Exterior:
full saleen  s281 speedster package
shaved emblems
Saleen tail light bezels
wiper delete with smoothed cowl panel
modified 04 cobra mirrors
Interior:
Custom covered Saleen Recaros
Custom rear seat delete with 12" fosgate subs
In dash Ipad mini
Saleen light bar
 Full custom covered interior
Custom built instrument cluster with full autometer gauges
Custom built center console with custom built switch panel
Billet pedal covers
That's the basics as I have just started on tackling the interior, photobucket is acting up this morning so whatever pics I included is all I can get to at the moment lol
Let the best build win!!
Guest
