Prokiller
February ROTM Winner - 95opal
This month we had our Build Thread theme and I think we had some great competition here.  Sadly we only had 3 to choose from but that just made it even harder to choose.  In the end, as always, we have a winner.  This goes to a personal friend of mine that really deserves the recognition he receives.  He has taken an immaculate show winner and striped it down to it's bare bones and rebuilt it to something truly incredible. once it's done of course.  So raise your glasses and cheers to an awesome guy and fantastic build!
95opal
Performance:
Engine:
Dart SHP Machined Block
FordStrokers/RPM 4340 Forged Steel 3.250 Crankshaft -
INTERNAL
FordStrokers/RPM 4340 Forged Steel H Beam Connecting
Rods 5.400
Wiseco 2618 Forged Pistons (14cc, Inline) 4.030
Wiseco GFX Ring Package
Clevite 77 H Main Bearings
Clevite 77 H Rod Bearings
Dart Coated Cam Bearings
Screw in Oil Galley Plugs
Fel Pro Rear Main Seal
ARP Main Studs
Freeze Plugs
Cam Bolt
Cam Retainer Plate
SA Gear Billet Timing Chain w/Torrington Bearing
Melling Oil Pump M68
ARP Oil Pump Bolts
Moroso Oil Pump Pick up 24519
ARP Billet Oil Pumpshaft
Fel Pro 1 Piece Pan Gasket
Morel link bar lifters
FTI prepped AFR 195 competition heads
 Comp cams 1.6 Ultra Pro Magnum rockers
FTI ported holley systemax
FTI custom blower cam
Accufab 75mm t body
Pmas 95mm MAF
Deca 80# injectors
Polished 8 rib Vortech si renegade package with Mondo valve
Duel nozel Snow performance stage 2 meth injection
Zex 100 shot wet kit
Custom sumped 19 gallon RCI fuel cell 10AN feed 8An return
Aeromotive A1000 pump with A1000 regulator
BBRC billet fuel rails
MSD 6al
Relocated MSD coil
SCT 4 banck chip
Mezier remote mount water pump
custom smoothed bay
wire tuck
Brake line tuck
ABS dele3te
 custom built fan shroud and core cover
Promotion built tr3650 race version (1000hp)
Stifflers trans crossmember and driveshaft safety loop
Pro 5.0 shifter
Suspension:
Team z auto x K-member
team z Auto x tubular A arms
MM2 Race series coilovers
Wilwood  14" 6 piston calipers
Wilwood Polished tandem master cylinder and proportioning valve
Wilwood 13" 4 piston rear calipers
MM manual brake conversion
MM Manual steering shaft
Flaming river quick ratio manual rack
Steeda front and rear sway bars
energy suspension end links
Steeda bump steer kit
MM caster camber plates
Team z mini tub kit
Qa1 rear coil overs
Steeda lower control arms
Steeda double adjustable upper arms
built and narrowed ( 6") 3.73  8.8 rear with Custom bracing and CHE axle  brace
Stifflers fit system
Stifflers spyder bracing
Stifflers K-member brace
20x12  & 19 x 9 custom forged wheels
345/25/20 &  275/30/19 nitto invos
Exterior:
full saleen  s281 speedster package
shaved emblems
Saleen tail light bezels
wiper delete with smoothed cowl panel
modified 04 cobra mirrors
Interior:
Custom covered Saleen Recaros
Custom rear seat delete with 12" fosgate subs
In dash Ipad mini
Saleen light bar
 Full custom covered interior
Custom built instrument cluster with full autometer gauges
Custom built center console with custom built switch panel
Billet pedal covers
That's the basics as I have just started on tackling the interior, photobucket is acting up this morning so whatever pics I included is all I can get to at the moment lol
Congrats Rich! I've been a big fan of your car for many years. Your old shaved bay was one of the first that really caught my eye and a big inspiration for my own. The car's latest iteration will be better than ever and is going to be in a league of its own.
Thanks for the noms and votes peeps its been a long slow journey.
Well deserved Rich! This car will be off the charts when it's finished, can't wait to see it in person sometime. :2thumb:
Thanks Dan, Im sure youll see it more than likely just in time for me to see all the updates you've done to the riosnake.
Thanks sublime glad to inspire and the plans for your car have me thinking long and hard about my fox project. So it seems the inspiration has been flipped lol
