Prokiller
March ROTM Voting - Open to All
March ROTM
22 members have voted
  1. 1. Who should win this month?
    • 69clark
      14
    • Orange 94
      5
    • copmagnet
      0
    • Blackmage
      3
Little late this month again but hey, it's a short month in February so cut me some slack.  I got 2" of snow that turned over to freezing rain last night which condensed the snow to .5" of solid ice.  oh joy.  well it's almost 1PM and it's all melted and the driveway is even dry in places.  Thank goodness for the increased sun angle!  Spring is coming folks.  just not fast enough it seems.  hopefully by the time i write up a voting thread i'll be able to share some fresh green pictures. here's hoping!
This month I wanted to offer up anything and everything to be nominated and we got a lot of diverse submissions.  In the end we have a fox, two engine swappers, and a new edge.  pretty diverse if you ask me.  all awesome in their own right.
69clark
- ride tech air ride
- 14 Alcon brakes.
- 6" narrowed rear
- 18x7 and 20x12 budniks with 345 rear tires
- team z mini tubs
- team z k member
- Stifflers fit system, k member brace, spider kit, and tranny crossmember
- 03 cobra motor with 2.3 whipple
- sullivan valve covers
- smooth bay
- a1000 pump and 60lb injectors
- megasquirt
- sparco chrono road seats
- auto meter gauges
- old air ac system
- wings west 93 cobra style side side skirts and rear valance
- SVO sail panels
- t56 tranny with mcleod RXT clutch
a5261794226b9f2dd90eaee14ea698e4_zps9d7c
Orange 94
Engine
4.2 v6 (1998 F-150)
M112 Supercharger w/2.93 pulley
Water Methanol Injected
SSM adapter Plate
Mild ported split port heads and intake
Comp Cams 259HR115 cam
Comp Cams 26918 valve springs
Scorpion 1.73 roller rockers
Lightning 90mm MAF
C&L boost pipe
Walbro 255lph pump
Cobra Blue 39lb injectors
94 3.8 v6 stock headers
94 3.8 v6 25% underdrive pulleys
Double roller timing chain
Stock polished valve covers
MSD Coil
Drivetrain
T5 transmission (95GT)
King Cobra clutch
Stock clutch cable
Triple hook quadrant/ locking firewall adjuster
Mac shifter
8.8 fox diff assembly 3.73 gears
Interior
00’ Mustang interior
Boost gauge
Billet pedals, turn signal, defrost, temp controls, headlight control, Ebrake
Fog light switch
Hidden antenna
Alpine stereo
Collection of Pool Ball shifter knobs (favorite: orange #5)
LED Swap - gauges, hvac, dome.
Innovate Wideband
Dual gauge column pod
Exterior
Cobra bumper
Cobra R hood
Depo black diamond headlights
Depo chrome diamond corners
Cobra fog lights
Stock horizontal taillights
Wingless
Antenna removed
Passenger door keyhole removed
Bullitt Wheels 9" front 10" rear
255/35ZR18 Hankook Venture Plus front
275/35ZR18 Kumho rear
Monster extended open ended forged steel titanium finish Lugs
Paint: 94 Ford “Orange” - used on pickup trucks
LED Swap - License plate
Vanity plate - NO PULP
Suspension
HAL Kmember
MM CC plates
Eibach Pro- kit springs
Tokico D Spec Shocks Struts
Front FRPP Control Arms
AM UCA and LCA
Exhaust
Mac Cat Back w/polished tips
Pacesetter H-pipe
Gutted Cats
copmagnet
Performance:
.020 over teksid block
Manley -11 cc pistons
Eagle H beam rods
Clevite 77 h series main and rod bearings
tss billet oil pump gears in a FRPP housing
canton windage tray
9 thread C heads
98 cobra cams
FRPP timing system
ARP main studs
ARP side bolts
ARP rod bolts
ARP head studs
On3 70mm turbo
steeda tri ax
4.30 gears
FRPP 31 spline diff
moser 31 spline axles
Braided brake lines
Suspension
Bilstein HD front's with strange coilovers
Bilstein rears with H&R SS springs
metco upper and lower control arms
upr tubular K member
upr tubular A arms
Exterior:
Blanket
Pillar and FRPP boost gauge
bumper Styrofoam
Interior:
Big bag
Wheels:
18" saleen repros with HTRz II tires.
Blackmage
93 Mark VIII long block
98 Cobra Intake
97 Cobra intake Cams
IMRC Delete
EGR Delete
COP Swap - 03/04 Cobra Valve covers
Fuse Box Relocation
Battery Relocation - Taylor Box
03 Cobra manifolds
O/R H-pipe into stock mufflers
K&N Filter
00 Cobra R Brembo calipers
Stainless Steel braided brake lines
Spec Stage 2 clutch
99 Cobra T45
Steeda Tri-Ax
4.10 gears
FRPP Carbon disc trac-lok rebuild
Aerostar Aluminum D/S
SCT X3 Tuner
-Suspension
Cut Ford C-Springs
Steeda front & rear sway bars
KYB AGX struts
MAximum Motorsports CC Plates
SR Upper & Lower control arms
FRPP Strut Tower Brace
Maximum Motorsports FLSFC
Maximum Motorsports Solid Steering Rack Bushings
-Exterior
96 Cobra Hood
Dark tinted cobra headlights
5% tinted windows
99 mustang spoiler
tinted taillights
Front pony delete
Violet pearl in black paint
Sequential and Chase taillights by Meter4it
HID's 6000k
-Interior
Car is 248a optioned, meaning its basically a GTS:
-No power windows, no power seats, no rear defrost, no fog lights, no spoiler, V6 seats, basic radio, no ABS, no trunk release button
FR500 steering wheel
FRPP shift knob
Bullitt pedal covers
Cobra gauge cluster
LED's in cluster
Automete Voltage and Oil gauges
AEM Wideband AFR gauge
Gray GT floor mats and Charcoal carpet
Alpine MRP-F300 Amplifier
Kicker KS68 speakers
-Wheels/Tires
18x9 and 18x10 GodSpeed wheels
5/16inch wheels spacers
275/35/18 Michelin Pilot Sport 2
295/30/18 Michelin Pilot SportCup
11D5B622-964C-4036-B8BA-7CA90DD7E3AA_zps
07E97D3D-750F-438D-9304-48C6C3FB4641_zps
Let the voting commence!
Guest
