Alex302 Posted August 23, 2015 Report Share Posted August 23, 2015 Found a once in a life time deal and i jumped at them. They where a little rough but I spent some quality time sanding and waxing and got them looking good. Link to comment Share on other sites More sharing options...
RedTwilight Posted August 23, 2015 Report Share Posted August 23, 2015 I'm not much of a fan of the export tails personally. But I think they look pretty darn good on a yellow stang. Link to comment Share on other sites More sharing options...
Prokiller Posted August 24, 2015 Report Share Posted August 24, 2015 did they come with the wire harnesses as well? Link to comment Share on other sites More sharing options...
Blackmage Posted August 24, 2015 Report Share Posted August 24, 2015 totally worth it! @Prokiller, i belive on a FB post he said no, he would just make his harness. Link to comment Share on other sites More sharing options...
Prokiller Posted August 24, 2015 Report Share Posted August 24, 2015 i had to make my own as well so if you need help let me know. Link to comment Share on other sites More sharing options...
Josh@RideTech Posted August 24, 2015 Report Share Posted August 24, 2015 I guess it's because I've never had an SN... but what did these tails come on? I've only seen a few sets of them before. Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted August 24, 2015 Moderators Report Share Posted August 24, 2015 I guess it's because I've never had an SN... but what did these tails come on? I've only seen a few sets of them before. Cars exported to Japan or Europe from 94-96, where amber turn signals are a requirement. 97-98 cars had the vertical tails. Link to comment Share on other sites More sharing options...
Josh@RideTech Posted August 24, 2015 Report Share Posted August 24, 2015 Cars exported to Japan or Europe from 94-96, where amber turn signals are a requirement. 97-98 cars had the vertical tails. Ah, good to know. Makes sense Link to comment Share on other sites More sharing options...
Alex302 Posted August 25, 2015 Author Report Share Posted August 25, 2015 i had to make my own as well so if you need help let me know.Any help is good. The issue i have is the 04 body harness but i think i have a good plan. How did you do it? Link to comment Share on other sites More sharing options...
Prokiller Posted August 25, 2015 Report Share Posted August 25, 2015 i had to add another bulb in place and disconnect a wire from the others. i'll find my wiring diagram tonight. Link to comment Share on other sites More sharing options...
Alex302 Posted August 25, 2015 Author Report Share Posted August 25, 2015 i had to add another bulb in place and disconnect a wire from the others. i'll find my wiring diagram tonight.cool ty sir Link to comment Share on other sites More sharing options...
410sn95 Posted August 25, 2015 Report Share Posted August 25, 2015 i had to add another bulb in place and disconnect a wire from the others. i'll find my wiring diagram tonight. In for the diagram. Link to comment Share on other sites More sharing options...
Alex302 Posted August 27, 2015 Author Report Share Posted August 27, 2015 went to the junk yard yesterday and got a trunk wiring harness to run the extra wires, i want it to look as factory as possible ill post some pics here soon Link to comment Share on other sites More sharing options...
Prokiller Posted August 27, 2015 Report Share Posted August 27, 2015 so its not so much a diagram as it is directions.... first off here's a great install from cythar. this outlines everything else besides making your own harness:http://www.chythar.net/mustang/mustang_94-95_export_taillight_installation.html now for the harness. i'm pretty damn sure this is how i wired mine in but i kinda want to pull my harness to double check now the more i think about it. don't want you to get to cutting and then realize i told you wrong. you'll need to cut out the signal wire from one of the existing bulbs. the signal wires are different on each side. left is light green/orange stripe where as the right side is orange with light blue stripe. the turnsignal bulb will only be the signal wire and ground. the other two bulbs with be brown and ground. it's easiest to just extend from the cut brown wire for the turn signal bulb to add that in and then splice in another ground. hardest part is working in the tight area. you don't want to add a lot of wiring back there but if you don't add enough you won't be able to lock/spin the bulbs in place. obviously the reverse light you leave alone. Link to comment Share on other sites More sharing options...
Alex302 Posted August 29, 2015 Author Report Share Posted August 29, 2015 got my lights wired today. i went to the u-pull-it and got a trunk and light harness to make it look factory, im not a fan of messy wiring. i add i pig tail to the light harness to bring the brake signal that i tapped from the 3rd brake light wire and add the turn signal bulb.i had to cut the brake signal wire under the dash to get a clean turn signal only to the new light bulb i added in turn i had to put a LED style flash relay to make it work. Link to comment Share on other sites More sharing options...
RedTwilight Posted August 29, 2015 Report Share Posted August 29, 2015 Looking Good! Link to comment Share on other sites More sharing options...
ttocs Posted August 29, 2015 Report Share Posted August 29, 2015 anyone ever cut out the knock-out area on the bottom of the standard light and put a light in it? Link to comment Share on other sites More sharing options...
Alex302 Posted August 29, 2015 Author Report Share Posted August 29, 2015 Ive seen it done before. Link to comment Share on other sites More sharing options...
Sleeperstang1994 Posted September 2, 2015 Report Share Posted September 2, 2015 these lights look awesome on your car. just one more thing i'm envious of! Link to comment Share on other sites More sharing options...
Steve-Oh Posted September 4, 2015 Report Share Posted September 4, 2015 Damn they cleaned up really well! Nicely done. Link to comment Share on other sites More sharing options...
