Orange 94
Orange 94's Track Build
Nice score on the GT . You got all kinds of projects on the go right now . You really stripped that shell lol . The GT is already looking way better then the original purchase date
@Orange 94 Do you have a link to where you purchased the LED bulbs for the gauge cluster from? I'm looking to do the swap I've purchased from Super Bright LED's before but at $5 a bulb I figured I might be able to do better. Thanks!
On 12/8/2016 at 6:43 AM, Prokiller said:
have you had the frame checked out for straightness yet?
Car is good and straight, just noticed repair when taking interior out.
Ebay seller is jtechnowcom
I got the 6 pack of 5 x 5050 SMD LED White Super Bright. I haven't installed them yet in the new edge, but these are the ones I have in the 94. Was very happy with them.
These are the ones I bought for mine.  looks like they're out of stock, but they were $6.99 for 10x of them.
https://www.amazon.com/gp/product/B00B1ENJ7K/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
265DDA7E-47E6-47B2-A759-DB669F0084B4_zps
Thanks gentlemen! Found a 10-pack for $10. Good enough!
when you put them in, double check they turn on before you completely install it back in the dash.  some of the bulbs might not turn on, and need to be pulled out and turned 180 degrees and they will then work.
Not much of an update... the car has been buried under snow and I've just recently found it thanks to the chinooks.
I've been trying to plan the car out some more. Decided to take a step back and drive it how it is for a season. Get some seat time and then focus on improvements. So I'll do the torque boxes, put the interior back in and get some tires before race season. I found out the 17" eagle wheels on the car are square, so I want to run 275 nitto nt01 on all corners for autocross and drag.
Got a new visor for my helmet. Gold on black looks awesome!
32355139836_6e8fe78956_c.jpgIMG_7294 by Richard Brown, on Flickr
I also got some new lug nuts since the ones that came with the car have these shitty locks. I wish there were more options for 1/2" lug nuts, I don't really trust any of the aluminum ones on the market so I decided on forged steel. Trying to find nice looking ones in Canada is a challenge, couldn't find monster lugs that I have on the orange car so I thought I'd try gorilla this time.
32244114172_3111d4cda3_c.jpgIMG_7437 by Richard Brown, on Flickr
32274013671_3eb3f128d1_c.jpgIMG_7435 by Richard Brown, on Flickr
Found a used Corbeau RRS locally :)
Decided to get reclining seat for now. Can't stand the stock seat position.
33606152572_9b5cb6c85b_c.jpgIMG_8032-2 by Richard Brown, on Flickr
Struggling to find time for the car with the new job and a bunch of other changes. Will be getting going on this car this weekend though.
Finally started to dive into this car.
32990682903_70acc03e55_c.jpgIMG_9225 by Richard Brown, on Flickr
33418959800_dc2df5efff_c.jpgIMG_9219 by Richard Brown, on Flickr
I knew upon purchase that the upper torque box had been torn out and somebody had tried to repair it. Upon disassembly I found out its much worse than expected and basically non repairable as somebody just globed a bunch of weld over everything. Time to cut everything out and put the Wild Ride S-Box in. 3000hp capability is a "bit" over kill, but do it right the first time!
The lower torque box reinforcements went in though!
And yes that is a hole in the floor... only spot of rust on the entire car. It looks like there was an exposed hole and moisture got in and sat under the rear seat. So fixing that too.
32960554424_b3418a1e0a_c.jpgIMG_9211 by Richard Brown, on Flickr
32990731863_bc7c9e9bfc_c.jpgIMG_9209 by Richard Brown, on Flickr
Then finally the side scoops have been taken out. They looked like ass so I just want to sand and prime them while I have access. These are way harder to pull out than the 94-98 scoops! Hate how they're not even functional like my 94 (only year that had functional scoops for sn95).
32990665553_50c7431ec8_c.jpgIMG_9220 by Richard Brown, on Flickr
Well progress today!
Not sure if I've posted before, but got some new factory seatbelts. Current ones will hardly retract at all. Wish ford did a better job at designing these...
34239529141_097cbb8d8d_c.jpgIMG_0588 by Richard Brown, on Flickr
Rear end was taken out last week.
33559638013_c48bacc1b7_c.jpgIMG_0591 by Richard Brown, on Flickr
Picked up my Wild Rides upper control box plate. Nice and beefy!
34211997002_4834071ae1_c.jpgIMG_0590 by Richard Brown, on Flickr
33559644063_c7c0802a40_c.jpgIMG_0589 by Richard Brown, on Flickr
Removed the old junk.
33985866140_c6219eddbd_c.jpgIMG_0592 by Richard Brown, on Flickr
Here's the damage. Some of it was caused when taking out, but you can see the poor attempt at repairs. The welds to the actual car were even uglier... My dad and myself are definitely not welders, but this is junk and not fixed correctly. Also took measurements and yeah it was out a decent amount paired to the other side.
34328858786_af425bb3d7_c.jpgIMG_0593 by Richard Brown, on Flickr
34370287105_f04ed49551_c.jpgIMG_0635 by Richard Brown, on Flickr
34370266785_3b41d027de_c.jpgIMG_0639 by Richard Brown, on Flickr
34370271935_7cd8afa326_c.jpgIMG_0637 by Richard Brown, on Flickr
Cleaning up the car and welding the holes up. Sound deadening took forever to remove... Ready to install the plate.
33559610243_a42a426375_c.jpgIMG_0598 by Richard Brown, on Flickr
34239482221_9ac36c078c_c.jpgIMG_0595 by Richard Brown, on Flickr
33559601913_64d4820c33_c.jpgIMG_0629 by Richard Brown, on Flickr
That Wild Rides piece definitely looks beefy. I always intended to do one of those then ended up doing the IRS and don't use the upper control arm boxes at all now lol. Keep up the great work!
Well May long weekend sucked for me, have literally been sick for the entire thing. A bit got done on the car though. I'm really pushing to have this on the road for next weekend, going to attempt to drift it... excited and nervous to learn.
apologize for the phone pics, I at least edited them though.
I order some MRT hood struts, these were one of my favorite mods on the other car. No more bumping the prop and having the hood fall on your head. Unfortunately, MRT packaged 2 RH fender brackets and no LH bracket. So waiting on that to install them.
34447816830_026f687cef_c.jpg20170518_182916 by Richard Brown, on Flickr
The wild rides upper torque box is installed. Not the most recent photo of underneath, I think this was just when it was bolted in.
34447804320_29b1922b67_c.jpg20170518_184147 by Richard Brown, on Flickr
34447741450_fb4cbc58ba_c.jpg20170522_184932 by Richard Brown, on Flickr
One of the brake lines had a hole, so the entire line is being replaced. I need to also replace the fuel filter and relocate a couple cables. Then the rear end can go in.
33990975144_634d37c8b6_c.jpg20170522_125923 by Richard Brown, on Flickr
34701881921_5420af1205_c.jpg20170519_190241 by Richard Brown, on Flickr
The front bumper was bugging me. Removed the chicken wire, added some yellow tint to the fog lights and fitted the bumper on better. Was nervous I was going to find a bunch of surprises behind the bumper, but was actually in good shape.
34701875141_7c23c60dc9_c.jpg20170519_190344 by Richard Brown, on Flickr
33990988404_faf9b949d3_c.jpg20170519_193214 by Richard Brown, on Flickr
Well have had the car on the road for a couple days! Took it to Rocky Mountain Drift Club yesterday, more on that once I edit the photos!
Here's how the car sits now!
35080731422_9a62d86926_c.jpgIMG_2567 by Richard Brown, on Flickr
34858879380_0003f74186_c.jpgIMG_2569 by Richard Brown, on Flickr
35205779606_1f89071c28_c.jpgIMG_2575 by Richard Brown, on Flickr
34436943673_725974f6fc_c.jpgIMG_2572 by Richard Brown, on Flickr
35080721242_d37908874d_c.jpgIMG_2568 by Richard Brown, on Flickr
35116118811_a7c2db23df_c.jpgIMG_2582 by Richard Brown, on Flickr
35205770926_319621bd86_c.jpgIMG_2576 by Richard Brown, on Flickr
34858806820_329ab5c973_c.jpgIMG_2585 by Richard Brown, on Flickr
As I said, went to Rocky Mountain Drift Club on the weekend! While I wasn't really "drifting" - more looping out, burning tires and destroying the track markers everywhere - It was a BLAST though! Can't wait to go again and practice more.
Anyways, I got my girlfriend to snap a couple pics with my camera!
34863200320_1650cd210e_c.jpgIMG_3279 by Richard Brown, on Flickr
34863205370_0a25f56a1c_c.jpgIMG_3270 by Richard Brown, on Flickr
35210388216_7c3f3dff07_c.jpgIMG_3271 by Richard Brown, on Flickr
35085660262_a51e6e51e2_c.jpgIMG_3510 by Richard Brown, on Flickr
34407247594_c51057f5f0_c.jpgIMG_3512 by Richard Brown, on Flickr
34864082190_f3e26a1e85_c.jpgIMG_3553 by Richard Brown, on Flickr
34407243574_194931abb9_c.jpgIMG_3521 by Richard Brown, on Flickr
34864287980_3d8fb52cc3_c.jpgIMG_3282 by Richard Brown, on Flickr
35251244575_e3f3532b18_c.jpgIMG_3287 by Richard Brown, on Flickr
35085843492_4178b8f450_c.jpgIMG_3289 by Richard Brown, on Flickr
34864274530_b89b27dcdb_c.jpgIMG_3292 by Richard Brown, on Flickr
35085822182_73bb33ebbf_c.jpgIMG_3294 by Richard Brown, on Flickr
35121514611_c0e3dc5167_c.jpgIMG_3295 by Richard Brown, on Flickr
35085811942_2774d354b0_c.jpgIMG_3296 by Richard Brown, on Flickr
35121507771_222ce399af_c.jpgIMG_3297 by Richard Brown, on Flickr
35085800762_5a49860eac_c.jpgIMG_3298 by Richard Brown, on Flickr
34407429654_b8dca0bcbc_c.jpgIMG_3301 by Richard Brown, on Flickr
34407424214_c534bb2445_c.jpgIMG_3303 by Richard Brown, on Flickr
34407419174_1ed31c3548_c.jpgIMG_3319 by Richard Brown, on Flickr
Edited by Orange 94
  • Like 1
18 hours ago, thetrex said:
Remembering to turn off the Trac Control is one of the most annoying things in the world. Now I keep post it notes and a pen in the console to remind me!
Yes it is! looks like I can turn it off with a tuner or dallas mustangs has a controller.
Or just wait for your ABS unit to die.... then it's always off!
Well since I blew up the orange car and my truck needs AC work, I guess I'll be driving this car for the summer and it'll have to do some daily driver duty.
Might as well make it look a little nicer! Work Kiwami wheels from the other car!
35469187241_c4ef110e04_c.jpgDSCF3357 by Richard Brown, on Flickr
35469177581_79073a0334_c.jpgDSCF3358 by Richard Brown, on Flickr
34758060364_2f165627c1_c.jpgDSCF3368 by Richard Brown, on Flickr
On 12/6/2017 at 8:33 AM, Blackmage said:
Car is for sale now isnt it?
Yes, it is sell it sells. If not then I have no problem keeping it. Just didn't have as much free time as I thought.
On 10/8/2016 at 9:01 PM, Orange 94 said:
30202432005_da2a7b98d7_c.jpgIMG_9709 by Richard Brown, on Flickr
Started to move the car. Then the tractor ran out of fuel, so we went for lunch. When we came back the rain had cleared so we just decided to tear it apart in the yard.
My 2nd Car was a TA just like this one!
my dad and I painted it white, with told lower valance .  was a fun/good looking car.
Ur wheels - good on any Stang IMO.
Looks like a fun project, or two!  the 56 will be sweet as well.
Does changing the rear to a 3 link mess up the class you're put in at the track?
Always like a good build and know you do good work :drink_to_that:
