330CubeGt
Official Weight Reduction List
Actual numbers are from Either from 330CubeGt (Me) or 96SOHC. Everything on this list was put on an actual scale.Numbers show either the weight of a part, or weight saved by moving to a lighter part.
Hopefully this helps give you guys an idea of the actual weight of the items your wanting to remove from the car to drop weight before you actualy remove them.
This way you can Decide if its worth it, so now you don't have to play the guessing game wondering what each part weighs.
Drivers seat Leather = 48Lbs
Passenger seat Leather = 38Lbs
Rear seat Leather (top half) = 30Lbs
Bottom Rear seat = 15Lbs
Sounds deadening (Remove w/Torch and Scraper) = 45-50Lbs
Under Carpet Insulation = 20Lbs
Door Panels = 8Lbs (each)
Extra metal out of front bumper (Center) = 8Lbs (Kept most of it)
Stock Front Sway Bar w/links = 13.5Lbs
Going to front coil over setup = 20Lbs
Going to lighter front seats with manual sliders = 20Lbs
CD Player Head Unit = 5Lbs
Window Motor = 8Lbs
Rear End Dog bone = 10Lbs
Metal plate under steering column = 3.5Lbs
Wind shield washer tank = 1.5Lbs (empty) & 8Lbs (full)
Passenger side air bag = 9Lbs
Drivers side air bag = 3Lbs
Air bag sensors and module = 3Lbs
Hood latch w/cable etc = 2-3Lbs
Cruise control (In Fender) w/cable = 2-3Lbs
Glove Box = 4Lbs
Trunk Lining with spare tire cover = 14Lbs
Spare tire = 25Lbs
Jack and tire iron = 8Lbs
Smaller battery = 10Lbs
Mach 460 Amp Rack = 6Lbs
Mach 460 Speakers = 2.25Lbs (each)
6 disk changer = 2Lbs
Rear Seat belts = 5Lbs
Sun Visors with harness = 2.5Lbs
E-Brake Assembly w/cable = 7.5Lbs
Black boxes behind rear tires w/brackets = 3Lbs
Grille insert and Radiator cover = 2Lbs
Mott bar and bumpstop bracket = 9Lbs
Fog Lights and brackets = 6Lbs
Rear Bumper support brackets = 6Lbs
Factory Spoiler = 9Lbs
Strut tower brace = 8Lbs
Complete Front Bumper support = 17Lbs
Quad Shocks w/brackets = 8Lbs
Rear Sway Bar = 8.5Lbs
Convertible K-Member brace = 17Lbs
Firewall blanket = 15Lbs
Door Bars = 8Lbs
Dead pedal = 1Lbs
Tailpipes = 20Lbs
Evap Canister = 5Lbs
EGR and DPee = 4Lbs
Rear Bumper = 25Lbs
Convertible top pump/motor/cylinders = 12Lbs
A/C Complete = 30Lbs
ABS Pump Delete = 14Lbs
99-04 Brake Calipers = 10Lbs Vs. 14Lbs (94-98 style)
Wiper motor and linkage = 6Lbs
Heater core/A/C box/ fan = 19Lbs
Bumper suppor mounts w/wind deflectors = 5.5Lbs
Stock A-Arms 30 Lbs, Tubular A-Arms = 15Lbs
Hydro-boost and master cylinder assembly = 17Lbs
Power steering pump 10 Lbs, Delete pulley = 1.2Lbs
Power steering lines and Res = 5.5Lbs
Lock mechanism,window motor,wiring harness = 12Lbs
Gut underside of Trunk, Trunk will weight = 20-25Lbs
Few Lbs Misc Nuts/Bolts and Removed Metal???.
Stock e7 heads = 48-50Lbs (each) VS Aluminums = 27-30Lbs (each)
If you have personally weighed an item that you don't see on the list feel free to share your information!!!
Edited by Brian
Cleaned up post, adding information
Ahh thats why i get for looking for the first letter "D" for dog bone lol Thats why i missed it. Thanks for pointing that out!
My 98 5.4 Car was 2750lbs with out me or gas in it, Only thing it really had was a/c and a radio that played throught the 460 tweeters in the doors lmao. Even went with some sweet roll up windows :)
Damn, thats fox body area as far as weight. I wanted mine to be under 3000 with me in it but I didn't want to drop the a/c compressor or ps :/... It was time consuming to drop that much weight but its actualy worth it imo
