Schiffy Posted May 11, 2013 Report Share Posted May 11, 2013 Looking good!!!Sent from my secretary!!! Link to comment Share on other sites More sharing options...
Det_Riot Posted May 11, 2013 Report Share Posted May 11, 2013 Looking real good man! Love me a clean cobra! Link to comment Share on other sites More sharing options...
95riosnake Posted May 12, 2013 Report Share Posted May 12, 2013 Great work so far! Those taillights the PO had on the car were face palm city, looks 1000000000000x better with stock tails!Also nice work on the shifter gasket! Link to comment Share on other sites More sharing options...
Casper95svt Posted May 12, 2013 Author Report Share Posted May 12, 2013 Thanks everyone Link to comment Share on other sites More sharing options...
Casper95svt Posted May 15, 2013 Author Report Share Posted May 15, 2013 As I was cleaning my Balancer ( Crank pulley ) I discovered my radiator was leaking and crusted up on the passengers side near the plastic tank. Its an aftermarket parts store kinda radiator. So I opted for a bigger more efficient radiator. MIshimoto from American Muscle. Link to comment Share on other sites More sharing options...
Casper95svt Posted May 15, 2013 Author Report Share Posted May 15, 2013 Link to comment Share on other sites More sharing options...
Casper95svt Posted May 27, 2013 Author Report Share Posted May 27, 2013 Welllll..... I came home for MD weekend. Was going to take the Cobra for a quick ride but couldn't. I found this, two puddles on top of the front timing cover. Looked under and it was running the perimeter of the oil pan and the sway bar. So I decided to just tear into the motor and replace some parts. Found it to be the Thermostat housing, pulled the bolts and found the gasket to have black silicone on the lower portion of it. Looks like someone tried to fix it before. Remove the radiator, hoses, thermostat housing, deleted the oil cooler because its a rusty piece of junk. Removed all the a/c components. Remove the smog pump, and all pipes to the exhaust and heads. Figured out the size for the block off is a 5/8-11, so im going to make two plugs on the lathe at work and block off the heads. Use a piece of the Smog hose and a hose clamp combined with a bolt plugging it off on the h-pipe. Removed spark plugs and wires and cap and rotor. Pcv valve, mesh screen and rubber grommet. Removed the serp belt, and a/c compressor. Removed the waterpump, and the upper right hand side bolt snapped off in the block. Wasn't happy about that. So decided to go further into it. Pulled the alternator to replace it and scrap the smog pump and the ear for the front of the alternator broke off. I will need a replacement. Only found one on ebay and guy wants an arm and a leg for it. Anyone on here have one for sale?? Removed the front cover and drilled out the bolt and tapped all the holes and cleaned off the gasket. Will junk the factory oil pan as well, and gasket. Sent an order to Late Model Resto Oil PanOne piece gasketPoly Motor mountsNew 94/95 timing coverGasketsNew Idler pulleySerp beltA/C Delete pulleySmog delete pulleyFactory oil pump and gasketARP oil pump shaftRoyal Purple oil and FL1ABalancer/Crank pulley with timing pointer and new bolt and washer Link to comment Share on other sites More sharing options...
Casper95svt Posted May 27, 2013 Author Report Share Posted May 27, 2013 Link to comment Share on other sites More sharing options...
Det_Riot Posted May 27, 2013 Report Share Posted May 27, 2013 hope you replaced that timing chain while you were in there! That'd be a pain to have it go out after you put it all back together. Link to comment Share on other sites More sharing options...
Schiffy Posted May 27, 2013 Report Share Posted May 27, 2013 Still got the ac stuff? Not sure if the pushrods and modulars AC stuff is the same, but Hunter (copmagnet)needs an AC line when his underhood fire took one out.Tapatalk made me do it! Link to comment Share on other sites More sharing options...
Casper95svt Posted May 27, 2013 Author Report Share Posted May 27, 2013 hope you replaced that timing chain while you were in there! That'd be a pain to have it go out after you put it all back together.Not yet, was planning on getting one from the parts store before I button it up.- - - Updated - - -Still got the ac stuff? Not sure if the pushrods and modulars AC stuff is the same, but Hunter (copmagnet)needs an AC line when his underhood fire took one out.Tapatalk made me do it!Im not sure either, but I have every single piece of the a/c still and would be willing to give it away just require money for shipping. Link to comment Share on other sites More sharing options...
Det_Riot Posted May 28, 2013 Report Share Posted May 28, 2013 Not yet, was planning on getting one from the parts store before I button it up.Good call. If you think you might do a cam swap later, it would be worth it now to get one with different keyways for adjusting your cam timing Link to comment Share on other sites More sharing options...
Casper95svt Posted May 28, 2013 Author Report Share Posted May 28, 2013 Good call. If you think you might do a cam swap later, it would be worth it now to get one with different keyways for adjusting your cam timingJust ordered one from American Muscle. They have pretty much next day shipping. Its a Ford Racing and was like 95 bucks. I would do a cam now, but I heard these computers don't like cams. Not sure if its true, this is my first Sn95 5.0. But I am planning on running the Hellion Turbo on this, and everyone tells me it loves the factory cam. So ill keep it I guess. Link to comment Share on other sites More sharing options...
Det_Riot Posted May 28, 2013 Report Share Posted May 28, 2013 Ahhh, good call! yah the stock cams are actually real good with turbo kits, hell look at forcefed, he's got about 2 or 3 turbo kits under his belt on stock cams Link to comment Share on other sites More sharing options...
copmagnet Posted May 28, 2013 Report Share Posted May 28, 2013 Not yet, was planning on getting one from the parts store before I button it up.- - - Updated - - -Im not sure either, but I have every single piece of the a/c still and would be willing to give it away just require money for shipping.I'm down for that, if you have it, its a single hard line that runs from the firewall to the radiator shroud. it runs right over the manifolds/headers. Link to comment Share on other sites More sharing options...
Casper95svt Posted May 28, 2013 Author Report Share Posted May 28, 2013 Okay. I travel for the Navy and im in CT right now. But will be home on Friday. I will snap a pic for you. Its in good condition. Would beable to ship it Monday. Ill be in touch. Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 Link to comment Share on other sites More sharing options...
Casper95svt Posted May 24, 2014 Author Report Share Posted May 24, 2014 Jeez....I gotta update this. Link to comment Share on other sites More sharing options...
Det_Riot Posted May 24, 2014 Report Share Posted May 24, 2014 Jeez....I gotta update this. Yes, yes you do!Sent from my XT1080 using Tapatalk Link to comment Share on other sites More sharing options...
Blackmage Posted May 30, 2014 Report Share Posted May 30, 2014 Jeez....I gotta update this. ugh white.. looks so damn good Link to comment Share on other sites More sharing options...
Casper95svt Posted May 30, 2014 Author Report Share Posted May 30, 2014 I actually just sold it back to the original owner. : / Looking for a 03/04 Cobra now. Time to move on to big boy status. Link to comment Share on other sites More sharing options...
Brian Posted May 30, 2014 Report Share Posted May 30, 2014 Well damn, that sucks.... Link to comment Share on other sites More sharing options...
Blackmage Posted May 30, 2014 Report Share Posted May 30, 2014 I actually just sold it back to the original owner. : / Looking for a 03/04 Cobra now. Time to move on to big boy status.well what the poop. as long as its white, i approve then. Link to comment Share on other sites More sharing options...
Det_Riot Posted May 30, 2014 Report Share Posted May 30, 2014 I actually just sold it back to the original owner. : / Looking for a 03/04 Cobra now. Time to move on to big boy status.As long as you still hang out that's fine by me!Sent from my XT1080 using Tapatalk Link to comment Share on other sites More sharing options...
Casper95svt Posted May 30, 2014 Author Report Share Posted May 30, 2014 Yeah...it's tough not having it around. But I'll be happy with my next Cobra. My first choice is white..If not black with black 18" Saleens and red brembos will look fancy too. I like blue too. But whites my favorite. Link to comment Share on other sites More sharing options...
Blackmage Posted June 4, 2014 Report Share Posted June 4, 2014 white with some black looks steller, or just a nice set of chrome rims too Link to comment Share on other sites More sharing options...
