White95
Post your engine combination!!! [Pushrods]
EZ6M-6015-G351 SVO 4-bolt main block (4.040" x 4.00 = 410 cu in)
- Eagle ESP 4340 crank/ h-beam rods
- SRP/JE Pistons (-19 cc dished / 10.8:1 ratio)
- ARP rod bolts, ARP main studs
- internally balanced
- 0 oz balance SFI balancer
- Canton 7 qt oil pan
Procomp 210 cc heads (freshly rebuilt and CNC ported)
- EPW 1.6 ratio RR
- Trick Flow stage 3 cam
- Comp Cams linked bar, roller lifters
- Comp Cams pushrods
- ARP head bolts
- Edelbrock valve covers
Trick Flow Specialties R intake
- 75 mm throttle body
- #42 injectors
- Aeromotive fuel rails (related AN fittings)
- AEM, externally mounted fuel pressure regulator (black braided lines and black fittings)
- custom CAI
Updated July 7, 2014 new pictures soon
Fordstrokers forged 347 stroker, 10.6:1 CR
Scat forged crank
Scat forged I-beam rods
Probe SRS forged flat top pistons
Holley SysteMax heads, converted to 7/16 stud mount
Holley SysteMax intake, smoothed and powder coated, custom intake plaque
Fabricated Valve covers
Anderson N61 Cam
Scorpion 1.6 roller rockers (7/16" stud mount)
Comp Cams Lifters
Trick Flow Pushrods
SA Gear Billet Timing Chain
28oz SFI balancer
ARP Main Studs
Probe Main Girdle
Canton 7qt road race oil pan clearanced for 94/95
Accufab 75mm Race Fox Body TB conversion
Ford Racing 42lb injectors
Russell fuel lines
ARP fasteners throughout
CSR -20an swivel water neck
Procharger D1SC
Race Mart 50mm BOV
Custom built piping/power pipe
Procharger sheet metal 3 core race intercooler
SCT BA-2600 MAF
Edited by 95riosnake
I dont have an engine anymore:sour:
Old combo:
306
afr165s
Fti custom cam
holley systemax
30lbs
70mm tbody
pmas 95mm maf
100shot
Was a fun street combo and Im sure Im gonna miss the simplicity of it all but then again rolling 70mph burnouts will quickly take my mind off it hahaha
**Fox Lake Built 306 Short Block**
- DSS Forged pistons
- Scat I Beams
- New Stock Crank (im cheap)
- ARP Bolts
**What I had in the garage**
- TFS Stage 1 Cam
- TFS Upper and Lower Intake
- Comp Cams Timing Chain
- TFS Lifters
- Ford Racing X303 Heads with Upgraded Springs
- SVO B351 1.6 RR
- Ford Racing Hardened Pushrods
- Melling Oil Pump/ pickup tube
- Ford Racing 24# Injectors
- C&L intake with 76mm Mass Air
- Pro Products 75mm TB
- Ceramic Coated Shorties
- All ARP Fastners through out
lightning maf, anderson power pipe, 75mm pro-products tb, ported 94 cobra upper/lower with 3/8" spacer and arp bolts, trick flow twisted wedge 170cc heads with svo 1.6 RR and trick flow stage 1 cam, BBK shorty headers, magnaflow high-flow catted X-pipe, dynomax side exhaust system, 3 bank chip.
Wanting to put a bottle on top now.
Pics? ... I seen that intake u been working on, looks nice
Sent from my EVO 3D using tapatalk
Some nice combos in here. Guess I'll post up my slow ass combo.
.030" over 302, 306 ci, 8.5:1 custom pistons, forged I beam rods, forged eagle crank, std volume oil pump and h code race bearings. Heads are box stock edelbrock Vic jr. Cam is a off the shelf blower/turbo cam from comp with .550 lift. Intake is a TFs track heat ported to accept an 80mm accufab fb. Have a cxracing intercooler setup on it, set up for blow thru, and a vortech v1 s trim making about 14psi on a good day. Using a stock flywheel, harmonic balancer and foxbody front drive. Engine is cooled by the stock sn95 fan and a mishimoto radiator.
Edited by Mikey94gt
351W Out of a 95 Cobra R
- Custom CNC Ported 234HR Trick Flow High Port Heads
- 2.055 X 5/16 Super Alloy Intake Valves
- 1.60 X 5/16 Super Alloy Exhaust Valves
- Lunati LSX Dual Valve Spring Kit
- TFS Hardened Guid Plates For 5/16 Push Rods
- ARP Pro Series 7/16 Rocker Arm Studs
- FTI Push Rods
- Custom Grind FTI Camshaft
- 605/565 lift
- Edelbrock Victor EFI Intake
- Accufab 75MM Throttle Body
- FMS #36LB Injectors
- PMAS 95MM Mass Air Meter
- Trick Flow 1.7 Roller Rockers
- ARP Head Studs
Edited by Venom351R
Stock 302 short block
AFR 185 58cc
TFS 1
Holley Systemax intake
BBK 75mm TB converted to foxbody
ford racing push rods
TFS lifters
comp cams timing chain
mac unequal shorties
BBK orr road H-pipe
Flows
30lbs injectors (looking for 42s to convert to E85)
Ebay CAI (soon to be gone)
so many nice builds here for sure.
Stock shortblock
Kenne Bell 2.2/Flowzilla
GT40 lower
AFR 165cc heads
Steeda #19 cam
Crane/Cobra 1.7 RR
TFS 6.25" Hardened pushrods
ARP Head studs
Melling high volume oil pump
FRPP 42lb injectors
90mm Lightning MAF
Pro-Products 70mm TB/intake elbow
Walbro 255lph fuel pump
Stant 180° t-stat
Smog/EGR deleted
1" phenolic intake spacer.
Oldish pic:
Edited by OnyxCobra
Damn 95riosnake. Dayum.
I've since moved on from my SN95 and its big Windsor, but it was:
422 cubic inch SBF:
1969 Production 351W Engine Block
SCAT 4340 Forged 4.1" Stroke Crankshaft
Oliver Billet 6.2" Connecting Rods
Ross custom 39cc Pistons
Clevite Bearings
Hellfire Piston Rings
Melling High Volume Oil Pump
Moroso 7 quart Oil Pan
Crane (Rollmaster) Billet Timing Chain
Flowtech Induction custom grind camshaft
Brodix M2 Track 1 CNC Cylinder Heads
Comp Cams Pro Magnum 1.6 ratio Roller Rockers
Comp Cams hardened Pushrods
Trick Flow "R" Intake Manifold, custom finish
Accufab 90mm Throttle Body
ARP hardware throughout the Engine
Ford Motorsport Valve Covers, custom finish
Pioneer SFI Spec 28 oz Harmonic Balancer
Accufab 1 3/4" Mid-Length Headers w/3" custom stainless exhaust
Paul.
I still have that upper intake, and my one-of-a-kind crank, water pump, and alternator pulleys. For some reason I haven't sold them even though I don't have a car to put them on. :P I have over 100 hours of work into the upper intake alone. For real.
Paul.
If you ever find it in yourself to sell the water pump pulley, let me know ;)
I believe you completely about the amount of time you had in the upper. Back in the day I was determined to mirror polish my stock cobra upper... A few days in, it ended up smoothed and painted silver... I didn't have the patience, and I usually have a LOT of patience, lol.
I spent dozens of hours sanding, then had it cut and welded, then more sanding, then professional polishing, which polished a hole in it (doh!), then more cutting/welding, then more sanding, then more professional polishing, then copper plating, then nickel plating, then triple chrome plating. Same for all the accessory brackets and pulleys. It took forever.
Stock long block other than ported E7's
Ported upper and lower intakes
Custom turbo kit
86mm turbo
60lb injectors
Twin walbro 255's
1" phenolic spacer
Auto lite 24's
Megasquirt EMS
Devils own water meth injection(yet to be installed)
Msd ignition
Aode transmission
Rebuilt using red clutches
New brazed drum
New j-mod valvebody
No 1-2,2-3 springs
B&M ratchet shifter(yet to be installed)
Basic stuff
Sent from my iPhone
351W block
Eagle 393 crank
Eagle I beam rods
Stock 351 roller cam
Keith Black domed pistons
P&P E7 heads
Summit dual plan intake
Summit carb
This is in my F250 for pulling my car. When my modular decides its done, then this engine will be getting freshened up, better heads, cam, intake, and stuffed in my car
Stock block/crank/rods 306
SRP forged pistons
XE274HR cam (.555/.565 lift, 274/282 duration, 112 LSA)
GT40P heads
* 1.90/1.54 valves, chromoly retainers
* 10 degree locks
* CraneCams dual valve springs (.575 lift)
* CraneCams stud mount conversion
* FMS 1.6 stud mount roller rockers
* FMS black/red valve covers
3" crank pulley
RPM Air-Gap intake manifold
Holley 750 double pumper
No AC/Smog/PS
BBK shorty headers
Bassani catted x-pipe (previous owner of mid-pipe hollowed out the cats)
Dynomax 18" race bullets, through LX stainless tips
Stock T5 trans
Pro 5.0 shifter
Spec Stg 2 10" clutch kit (will soon be upgrading to a Centerforce DF 10.5" setup)
Stock 7.5" rear w/ 3.08 gears
Edited by SVT Rob
-DSS 331
-AFR comp 185s
-AFM B21 cam
-Edelbrock performer RPM intake
-70mm throttle body
-pro-m 80mm maf
-42# injectors
-bbk ceramic long tubes
-dr. gas o/r x-pipe
-dynomax race bullets
-vortech supercharger w/2.95 pulley
-smog, EGR, A/C deleted
Mondo/crazy/budget 302 build on my 5.0 Cobra before I started on a 351, then sold everything and wound up with a modular 8 months later.
-Stock block honed in my garage
-Stock rods
-KB116 dome pistons
-Stock crank
-Edel RPM heads 2.02/1.60 valves
-Comp XE270HR-112
-1.7 rockers
-Cobra intake ported by tmoss
-Tuned by Craig Radovich of Radical Racing in Atco, NJ
Including the tune that was all done for about $2600, almost all parts used off the corral classifieds.
I have 2500 wrapped up in mine
393 Stroker kit
eagle crank
Eagle rods
Keith black domed pistons
Ported e7 heads
351w roller cam
Summit dual plane intake
Holley 600 carb
One hell of a pulling machine
Alright time to let the cat out of the bag....Heres the new setup lol
331 Liberator Dar Shortblock
Dart SHP Machined Block
FordStrokers/RPM 4340 Forged Steel 3.250 Crankshaft -
INTERNAL
FordStrokers/RPM 4340 Forged Steel H Beam Connecting
Rods 5.400
Wiseco 2618 Forged Pistons (14cc, Inline) 4.030
Wiseco GFX Ring Package
Clevite 77 H Main Bearings
Clevite 77 H Rod Bearings
Dart Coated Cam Bearings
Screw in Oil Galley Plugs
Fel Pro Rear Main Seal
ARP Main Studs
Freeze Plugs
Cam Bolt
Cam Retainer Plate
SA Gear Billet Timing Chain w/Torrington Bearing
Melling Oil Pump M68
ARP Oil Pump Bolts
Moroso Oil Pump Pick up 24519
ARP Billet Oil Pumpshaft
Fel Pro 1 Piece Pan Gasket
Moroso 7qt Oil Pan - 20511
FTI custom cam
FTI prepped AFR Renegade 195 competition heads
FTI ported Holley systemax2
aeromotive A1000 pump
Aeromotive A100 regulator
60# injectors
Vortech @16psi
backed by a tko 600
^ Awesome Rich!
What breed of vortech might this be? I'm going to guess T-trim?
.For this season it will be an SI trim, maybe next year an upgrade if need be. I think ill be pretty satisfied for a bit as Ill still have the 100 shot on top if I ever need it. I will also be running a meth set up to help keep my iats down. I dont plan on to much seat time this season as Im expecting to be working out all the unexpected bugs, so I really dont see any changes for the near future but ya never know. All in all it should hit 700+ on the juice :tennis:
Edited by 95opal
