iRoush
N/A Dyno Numbers
Post your N/A Dyno Numbers here! Make sure to attach a mod list and the dyno sheet as proof or your dyno run will not count on the list! The list will use the average between HP and TQ to determine who is on top because as we all know, Torque wins races and Horsepower wins shows so they are equally important!
1.) iRoush - '99 Roush S2 - 387RWHP/385RWTQ
2.) revhead347 - '95 GT - 371RWHP/395RWTQ
3.) Broncoerci - '03 GT - 334RWHP/415RWTQ
4.) iRoush - '99 Roush S2 - 357RWHP/358RWTQ
5.) Venom351R - '94 Cobra - 344RWHP/347RWTQ
6.) Alex302 - '95 GT - 338RWHP/350RWTQ
7.) 01yellercobra - '01 Cobra - 326RWHP/355RWTQ
8.) itsblue95 - '95 GT - 310RWHP/316RWTQ
9.) Duff Daddy - '96 GT - 304RWHP/310RWTQ
10.) iRoush - '99 Roush S2 - 272RWHP/288RWTQ
Edited by iRoush
1999 Roush Stage 2 - 272RWHP/288RWTQ
Mod List:
5.0 Livernois Stroker Rotating Assembly
HP292S Cams
JLT RAI
Accufab Plenum
Roush 75mm T/B
Mac O/R H-Pipe
Dynomax Super Turbo Side Exit Mufflers
Aluminum Driveshaft
Trick Tuners 91 Oct. Dyno Tune
Mod List:
MMR 600 shortblock
-’98 teksid aluminum block
-13.7:1 compression ratio
-Flat top pistons w/ notches
-MMR windage tray
MHS stage 3 ported heads
-Decked .030 over
MHS stage 4.5 bullet cams
-245/243 duration
-108 lobe seperation angle
-550/540 lift
-Ford gt camshaft followers
Steeda underdrive pullies
Accufab plenum
Roush 75mm throttle body
JLT ram air intake
FRPP 42# injectors
Lightning maf
KMS torker 340lph fuel pump
Mac longtube headers
Mac o/r h-pipe
Dynomax super turbo side exit exhaust
Fidanza aluminum flywheel
Spec stage 2 clutch
FRPP aluminum driveshaft
FRPP 3.73 gears
Tuned for ethanol (e85)
Comp 270 Cams
Ported Patriot heads
Pi intake
Trick Flow plenum
Frpp throttlebody
JLT "Duff Daddy Custom" intake with Lightning Maf
Walbro 255 bump
38lb injectors
BBk Shortie heads, off road H with Magnaflow stainless muffler
This was dynoed on drag radials so they are a little lower then if it was on street tires...
ahh screw it heres my old combo. 351W AFR 185 heads ( 72 cc combustion chambers ) TFSR intake, FTI Camshaft. 8:4 compression ratio due to the heads which were more suited for boost. New numbers with the new combo in a few weeks....
If I were you Id only plan on staying on that top spot for a few more weeks, I might have something for you :biggrin:. Then Im going to work on putting some distance on the top spot for the N/A 1/4 list
don't worry I'll take it right back in September :P
We'll see about that :mod (1): You and duff going to let a Pushrod sit at the top of the 1/4 list as well :boxing::boxing::boxing::boxing:
drag racing isn't my thing road racing is so get after duff for that quarter time lol. Besides that, there's no pushrods anywhere near the podium for NASA road racing ;)
2003 Centennial GT 334.9 rwhp 415.6 rwtq
Mods: MHS stage 3 ported heads
Comp 262 cams (degree'd)
Mac ceramic long tubes
Accufab 70mm TB/Plenum
JLT True CAI
24LB injectors
MGW shifter & Zoom clutch
FRPP aluminum DS
Moser 31 spline axles w/ 3.73's & rebuilt explorer diff
MM extreme duty LCA's
