RedTwilight Posted October 4, 2017 Report Share Posted October 4, 2017 4 hours ago, White95 said: So, I did a thing.... Picked up some 03/04 Cobra heads Sweet! But what are you going to do with the "B" intakes now? Link to comment Share on other sites More sharing options...
White95 Posted October 5, 2017 Author Report Share Posted October 5, 2017 6 hours ago, RedTwilight said: Sweet! But what are you going to do with the "B" intakes now? I have one sold and I’m going to use the short runner intake for the foreseeable future. The b head engine will be dropped in as-is until I can have the terminator stuff turn key. unless my ADD kicks in, right Will? @LWARRIOR1016 1 Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted October 5, 2017 Moderators Report Share Posted October 5, 2017 Link to comment Share on other sites More sharing options...
White95 Posted October 5, 2017 Author Report Share Posted October 5, 2017 1 hour ago, LWARRIOR1016 said: We will make this happen 1 Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted October 5, 2017 Moderators Report Share Posted October 5, 2017 6 minutes ago, White95 said: We will make this happen Absolutely 1 Link to comment Share on other sites More sharing options...
RedTwilight Posted October 5, 2017 Report Share Posted October 5, 2017 You have a good set of cams in the B heads to use for the Termi swap. Or is the add going to kick in and go with some custom ground cams? 1 Link to comment Share on other sites More sharing options...
White95 Posted October 7, 2017 Author Report Share Posted October 7, 2017 How’s this sound @RedTwilight? Proposed new combo: Mach 1 Intake/stock TB/JLT/card MAS BBK long tubes Diamond pistons (flat top, 10.9:1) 2003 Cobra heads/stock cams Boss rods Forged 96 Cobra crank Teksid block Appropriate windage tray Boundary oil pump/billet gears Worth noting? Off road x/bassani catback Billet flywheel 1 Link to comment Share on other sites More sharing options...
RedTwilight Posted October 7, 2017 Report Share Posted October 7, 2017 11 minutes ago, White95 said: How’s this sound @RedTwilight? Proposed new combo: Mach 1 Intake/stock TB/JLT/card MAS BBK long tubes Diamond pistons (flat top, 10.9:1) 2003 Cobra heads/stock cams Boss rods Forged 96 Cobra crank Teksid block Appropriate windage tray Boundary oil pump/billet gears Worth noting? Off road x/bassani catback Billet flywheel I like it! Nice list. So be a nice little build. Is this still temporary until the Eaton swap? Will the Eaton swap be temporary until the Coyote swap? LOL You decided not to use the intake cams from the "B" heads? What windage tray are you thinking of using? I'm planning to use the GT500 windage tray myself. Aluminum flywheel? 11" or 10.5"? I've been running an 11" with a Fidanza alum. flywheel and really like it. Go ahead and add a head cooling mod too. Will definitely be worth it since you plan on tracking the car. Link to comment Share on other sites More sharing options...
White95 Posted October 7, 2017 Author Report Share Posted October 7, 2017 9 hours ago, RedTwilight said: I like it! Nice list. So be a nice little build. Is this still temporary until the Eaton swap? Will the Eaton swap be temporary until the Coyote swap? LOL You decided not to use the intake cams from the "B" heads? What windage tray are you thinking of using? I'm planning to use the GT500 windage tray myself. Aluminum flywheel? 11" or 10.5"? I've been running an 11" with a Fidanza alum. flywheel and really like it. Go ahead and add a head cooling mod too. Will definitely be worth it since you plan on tracking the car. This is in fact temporary until the Eaton swap happens which is why it’ll be 10.9:1. This officially puts the Coyote idea in the shelf indefinitely. I’m giving William the heads with cams for a 5.4 project he’s brewing. I believe that the GT500 windage tray will work with minor trimming to clear the oil pickup? 10.5” clutch for now.. I do have the head cooling mod in place 👌🏻 Link to comment Share on other sites More sharing options...
Dkblue98gt Posted October 7, 2017 Report Share Posted October 7, 2017 The Exedy lightweight flywheel would allow you to use a 10.5 or 11 inch clutch. 1 Link to comment Share on other sites More sharing options...
RedTwilight Posted October 7, 2017 Report Share Posted October 7, 2017 3 hours ago, White95 said: This is in fact temporary until the Eaton swap happens which is why it’ll be 10.9:1. This officially puts the Coyote idea in the shelf indefinitely. I’m giving William the heads with cams for a 5.4 project he’s brewing. I believe that the GT500 windage tray will work with minor trimming to clear the oil pickup? 10.5” clutch for now.. I do have the head cooling mod in place 👌🏻 Yeah the GT500 windage tray only requires a little trimming for the pickup tube. It's nice because it also includes the pan gasket all in one piece. 2 hours ago, Dkblue98gt said: The Exedy lightweight flywheel would allow you to use a 10.5 or 11 inch clutch. I've got the Fidanza flywheel and it too allows both 10.5" and 11" clutches. There are probably others as well. 1 Link to comment Share on other sites More sharing options...
Prokiller Posted October 9, 2017 Report Share Posted October 9, 2017 +1 for fidanza. granted mines on a silly pushrod, but its a very nice piece. i've even switched out the friction surface already. 1 Link to comment Share on other sites More sharing options...
White95 Posted October 9, 2017 Author Report Share Posted October 9, 2017 3 hours ago, Prokiller said: +1 for fidanza. granted mines on a silly pushrod, but its a very nice piece. i've even switched out the friction surface already. Ha.. Well, some of the time I miss my silly pushrod engine.. Link to comment Share on other sites More sharing options...
RedTwilight Posted October 9, 2017 Report Share Posted October 9, 2017 4 hours ago, Prokiller said: +1 for fidanza. granted mines on a silly pushrod, but its a very nice piece. i've even switched out the friction surface already. 1 hour ago, White95 said: Ha.. Well, some of the time I miss my silly pushrod engine.. That's why I have both! 1 Link to comment Share on other sites More sharing options...
White95 Posted October 9, 2017 Author Report Share Posted October 9, 2017 3 hours ago, RedTwilight said: That's why I have both! That fucking green thing kills me LOL Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted October 10, 2017 Moderators Report Share Posted October 10, 2017 19 hours ago, White95 said: Ha.. Well, some of the time I miss my silly pushrod engine.. Dont even start with this again, we all know that youll sell it at the drop of a hat and start over. 1 Link to comment Share on other sites More sharing options...
White95 Posted October 10, 2017 Author Report Share Posted October 10, 2017 1 hour ago, LWARRIOR1016 said: Dont even start with this again, we all know that youll sell it at the drop of a hat and start over. Hi, my name is Josef and I’m a buildaholic. 1 Link to comment Share on other sites More sharing options...
White95 Posted October 23, 2017 Author Report Share Posted October 23, 2017 See, I knew buying those C heads was a good move: Apparently there was a leaking head gasket: Swapped the doors with Space Ghost: Also, removed the spindles to have the tie rod mounting holes bored out to 5/8" for the MM bolt on, bump steer kit 1 Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted October 23, 2017 Moderators Report Share Posted October 23, 2017 That valve looks like ass. The C heads better not look like that... 1 Link to comment Share on other sites More sharing options...
White95 Posted October 24, 2017 Author Report Share Posted October 24, 2017 9 hours ago, Evilcw311 said: Nothing a lil duct tape and job weld couldn’t fix!!!! ;-) Hun’ad mile an hour duct tape bruh!! Link to comment Share on other sites More sharing options...
White95 Posted October 24, 2017 Author Report Share Posted October 24, 2017 12 minutes ago, Evilcw311 said: I had the perfect meme for ya, but I can’t post it......... :-( Post it in my build thread on SN95F Link to comment Share on other sites More sharing options...
RedTwilight Posted October 24, 2017 Report Share Posted October 24, 2017 That valve mod is worth easily 25hp per cylinder. Helps pull in extra air! LOL Link to comment Share on other sites More sharing options...
White95 Posted October 25, 2017 Author Report Share Posted October 25, 2017 Spindles modified for bumpsteer kit: @LWARRIOR1016 painstakingly cleaned a clean engine block LOL Seems like I recall saying I wouldn't have another engine built, period. No way, no how.. Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted October 25, 2017 Moderators Report Share Posted October 25, 2017 You wont build another one......after this one 1 Link to comment Share on other sites More sharing options...
White95 Posted October 25, 2017 Author Report Share Posted October 25, 2017 31 minutes ago, Evilcw311 said: What did you have to do to the spindles?? Had to punch the tie rod end hole out to 5/8” to accommodate the bump steer kit. Link to comment Share on other sites More sharing options...
White95 Posted October 25, 2017 Author Report Share Posted October 25, 2017 1 hour ago, LWARRIOR1016 said: You wont build another one......after this one or my ADD KICKS IN Link to comment Share on other sites More sharing options...
Blackmage Posted October 26, 2017 Report Share Posted October 26, 2017 those heads look mint hah 1 Link to comment Share on other sites More sharing options...
White95 Posted October 30, 2017 Author Report Share Posted October 30, 2017 Plugging away!! Link to comment Share on other sites More sharing options...
White95 Posted November 8, 2017 Author Report Share Posted November 8, 2017 Have the next few weekends off and should have some meaningful updates for your viewing pleasure. 1 Link to comment Share on other sites More sharing options...
White95 Posted November 8, 2017 Author Report Share Posted November 8, 2017 More parts!! 1 Link to comment Share on other sites More sharing options...
Number Tew Posted November 9, 2017 Report Share Posted November 9, 2017 So many valves! Link to comment Share on other sites More sharing options...
White95 Posted November 9, 2017 Author Report Share Posted November 9, 2017 4 hours ago, Number Tew said: So many valves! So little time! Link to comment Share on other sites More sharing options...
White95 Posted November 24, 2017 Author Report Share Posted November 24, 2017 Once the latest round of parts on order ship, I’ll just lack the Diamond pistons to assemble the short block. Can’t wait to hear this thing run again and see how different it feels with 129 fewer cubic inches. Link to comment Share on other sites More sharing options...
Number Tew Posted November 24, 2017 Report Share Posted November 24, 2017 Das mini motah Link to comment Share on other sites More sharing options...
White95 Posted November 25, 2017 Author Report Share Posted November 25, 2017 18 hours ago, Number Tew said: Das mini motah For cereal... At least the valvetrain geometry will be correct the first time... 1 Link to comment Share on other sites More sharing options...
White95 Posted December 16, 2017 Author Report Share Posted December 16, 2017 Worked a LOT of overtime and bought a LOT of parts! Eaton Swap parts: 2004 Cobra engine cover: Gaskets galore: Pair of these expensive bastards: These were cleaned up, had a 5 angle valve job and some minor bowl work done: Picked up a used throttle body to clean up: Throttle cable bracket (cable is in a box) New hard ware for the Mach Intake: No pictures yet but I ordered my pistons also!!!! 2 Link to comment Share on other sites More sharing options...
White95 Posted December 16, 2017 Author Report Share Posted December 16, 2017 Going to drop off the Intake, cam covers, idler bridge and timing cover off to be painted by a local friend. I’m torn between graphite or black. I want something that looks all business like this: Link to comment Share on other sites More sharing options...
Prokiller Posted December 18, 2017 Report Share Posted December 18, 2017 graphite. you see black all time. 1 Link to comment Share on other sites More sharing options...
White95 Posted December 18, 2017 Author Report Share Posted December 18, 2017 2 hours ago, Prokiller said: graphite. you see black all time. 2 Link to comment Share on other sites More sharing options...
ThomasW Posted December 18, 2017 Report Share Posted December 18, 2017 Graphite fo sho! 2 Link to comment Share on other sites More sharing options...
