Rolocut
Engine porn..... no really look
when you said engine porn "no really" i was half expecting to see a camshaft being shoved into a vageeeeeeeeeeeeeen.
But this is much more easy on the eyes :drool: lol
Hahaha I can make that happen
On going project, 94 cobra, r block, tfsr225, hp efi, vortech ys
Instagram [MENTION=584]Rolocut[/MENTION]
i hope you have a doctor near by. those cam lobes are gonna hurt like a mofo! lmao
Nothing a little lube won't take care of. One lobe at a time ☺️??
Instagram @<a href="http://www.sn95source.com/member.php?u=584" target="_blank">Rolocut</a>
lmao, the visual is just not a comforting one when i think of installing a camshaft into a pushrod motor...
Just like a large ribbed condom on one of those days with a really really hard one ??? ??
What/where are you going to put your vac tree? getting my car back today and will be plotting the engine bay out now.
What's a vac tree?
The spot the main vac line ran into and then split it out to all the other small areas?
I don't have any of that. I'm hydro boost and I will have 1/4 inch aluminum bungs welded in custom elbow with push to connect lines to connect to fuel pressure regulator wastegate and blow off and meth. I don't use vacuum trees or reg vacuum lines just because with boost they can blow off or suck closed
Ah had not thought about that but then The one I just got is an aluminum version that says its made for a turbo. Was just curious I am cleaning up my bay now too and trying to get idea of what is needed. let the pron continue.
that's the first time i've seen that bracket for the pulleys. where'd you find that at?
The kurgan blower brace?
You know I just get stuck staring at pics of your car forever , I really want that kurgan blower brace , you're the first person I've ever seen with this fancy contraption
That fancy contraption is big money lol. It def works though because when I tried to take it off to polish it with belt tensioned it wouldn't come off and when I took tension off the belt it slid right off. Def a nice looking functional way to save blower and crank bearings while being able to crank the belt tight
Instagram @rolocut
That's fine big money is ok in my books , when it can save you big money down the line
Exactly. After all the issues I had last season I wasn't taking any precautions
Instagram @rolocut
Yea I seen it's 600 with hardware ... Which I think is fair and necessary when spinning a blower at high psi
Yeah, price went up a little bit but that's about right
Instagram @rolocut
Yea I just found a old thread when they came out and based my guess price off that . I figure with a big cog drive and 15lbs it's good added insurance on my part not to mentions I like shiny engine shit
Hahaha... Agreed.. But they don't come shiny.. I spent a few 5 hours sanding smooth and polishing it
Instagram @rolocut
Instagram @Rolocut
Rolocut,
Do you drive much on the street with this setup?  If you have, have you gone through any bearings in the brace?  Just curios.
I have modified 1st gen Kurgan Brace on my Windsor YSi setup. I did the brace because I was getting bracket flex with a YSi in the standard 94-95 bracket and I didn't want to go the route of fox acc. and timing cover to run Renegade brackets. I haven't blown through any bearings yet but have a few extras just in case.
I also don't put many miles on the car.  But the miles I do are all street miles with a manual. So lots of abrupt RPM changes.
As you said, it does work. My before and after data logs confirm that.
Rolocut,
Yeah, this is only a street car, I never had any issue with bearings yet, only 800 mi on set up. Mine of course in an auto. I didnt even try it without it. I just know the pulley set up i use is agressive and i need the tightest belt possible to prevent slip.
Very cool.  Car and motor setup look great.
