F8L GT
Build starts now
Heading after work to go pick up a teksid 4v. Things as happening a little sooner than I thought after finding it on craigslist for 150. My plan is to break 11s with under $1k invested. I think the cams might break me since I'm deciding to go new grinds rather than regrinds for a tighter LSA
Don't mind the grease and free top of the cylinders nor the dirt, but I was surprised to see the amount of hash marks left on the cylinder walls. Especially since he told me the car it came out of had 121k miles. Going to clean up the cylinder walls and inspect better, take better pics
Sent from my HTC One using Tapatalk
Looking good mike! Any other changes for the car? Trans, suspension weight reduction?
Only other change will be tires. Don't know if this will be done this summer but will be for next. So there may be a tubular k done by then too
Good stuff! 11's for ~$1k is damn impressive, if anyone could pull that off it's you :2thumb:
The original budget was set with using Luis's sponsored stage2 regrinds. But since we have decided to go with a set of new billet cams with tighter LSA and split the cost. So budget might get blown by a couple hundred
Going to start pulling my engine so I can swap things to the Teksid. More than likely clean up my front cover and mill the unneeded bosses off and weld up the unneeded holes
Good luck man, hope you hit the 11's you're looking for
Thanks. I have no doubts that out will happen. It's just a matter of how far into the 11s I get. I sold the b heads so that adds a little more to the budget
nice......if you don't mind me asking is there much of a market for B heads? Or is it mainly the C's that everyone wants?
No, there really is zero market for b heads. I got lucky and found someone who needed a set.
Need to wait for front tires to come so I can lift the car back up to remove trans bolts
Ah gotcha!  I actually do the same thing with jackstands to get the wheels off lol.
Got the oil pump on, afterwards I found a canton windage tray for $50 so I have that coming
Little downer moment. Pulled transmission drain plug and one of the slider dog teeth fell out. Glad I found it now instead of getting stuck between 2 gears down the track
Nice, that will look good under the hood. Did i miss what the top end of the motor is going to be?
I thought I had it posted but I guess not. The heads are stage 3 ported and polished pi heads with 1mm larger intake valves, high lift springs, and titanium retainers. The cams are going to be custom ground with big duration
Nice. I'm guessing you will be sitting a little over 11-1 compression with that bottom end? Should be a huge difference after it's done.
