Solar Posted February 22, 2014 Report Share Posted February 22, 2014 Ok, so as a reminder, although I may not know much mechanically, I may understand much what you explain. Ok, so here is the issue. The first issue on the issue is that it doesn't happen every time.. Occasionally, when starting my car I notice a hesitant start and if I don't tap on the gas it will stall out. It almost feels like when you turn on the key and kind of let it go before being able to fully start. It just bogs down. The worst part is that it I may be turning the car on and off all day and it may happen sometime in between. I did a battery test at work and it states "Bad & Replace" but the battery is not even 15 months old (Duralast) and I don't actually have voltage issue while driving. And on the battery test, it was more than 60% on life and charge. Any thoughts on going about this? I looked on the interwebz but haven't found anything similiar. Link to comment Share on other sites More sharing options...
Det_Riot Posted February 22, 2014 Report Share Posted February 22, 2014 What are mods on your car? Any cel? I believe its possible your starter could be on the way out or a cell in your battery could be dead.Sent from my XT1080 using Tapatalk Link to comment Share on other sites More sharing options...
Solar Posted February 22, 2014 Author Report Share Posted February 22, 2014 No mods to the actual motor. Hell, I am even running on my BAMA tune on stock with just the rear gear ratio adjustment. Starter was my other thought but I want to make sure the battery is not solely the problem. Link to comment Share on other sites More sharing options...
Det_Riot Posted February 22, 2014 Report Share Posted February 22, 2014 For shits and gigs, try turning off your bama tune and doing it bone stockSent from my XT1080 using Tapatalk Link to comment Share on other sites More sharing options...
Solar Posted February 22, 2014 Author Report Share Posted February 22, 2014 may have to run it like that for a while. Cause it isn't everytime that I have that problem. Also, had the same tune and mods since October 2012...why affecting now? Link to comment Share on other sites More sharing options...
Det_Riot Posted February 22, 2014 Report Share Posted February 22, 2014 Idk lol just throwing ideas outSent from my XT1080 using Tapatalk Link to comment Share on other sites More sharing options...
Solar Posted February 22, 2014 Author Report Share Posted February 22, 2014 May give it a trySent from my HTC One using Tapatalk Link to comment Share on other sites More sharing options...
330CubeGt Posted February 24, 2014 Report Share Posted February 24, 2014 Why are we asking what mods are done to the car?No body asks what do the actual volts look like with car off? Link to comment Share on other sites More sharing options...
01yellercobra Posted February 25, 2014 Report Share Posted February 25, 2014 Have you tried cleaning the IAC?Misspelling brought to you by tapatalk Link to comment Share on other sites More sharing options...
