Prokiller
September ROTM Voting - Pushrods
September ROTM
21 members have voted
  1. 1. Who is our Pushrod winner?
    • Steve-oh
      16
    • forcefedhatch
      0
    • Yeahloh95
      3
    • Musturd
      2
I'm having writer's block for this month.  I want to talk about how the leaves would be changing and the nights getting colder but this whole summer has been mild.  At least for us up in the northeast.  Usually we would hit the 90s pretty much all of August but we've barely hit above 85 on the hottest days.  definitely some crazy weather.  Don't get me wrong i'm not complaining about the perfect weather we've been having but it certainly doesn't put me in the fall mood.  Normally i would be so sick of the hot weather that i would be begging for some cool winds to break.  This month was supposed to be about yesteryear's mustangs and how the changing of the leaves would signify the dieing off of the older technology.  These days any car show you go to is chock full of S197's and coyotes galore.  The pushrod fox or sn95 is harder and harder to come by.  The new parts aren't coming around that often anymore as more and more coyotes run the streets.  And really, who can blame them?  that's where the big market is now and if it keeps the Mustang going strong why not?  Today though we remember and tribute our older technology brothers with a Pushrod themed Ride of the Month.  Let the best engine win!
STEVE-OH:
Performance:
  • Ford Racing 427W crate motor
  • 4.125 bore / 4.00 stroke
  • SCAT forged crank & I-beam rods
  • Forged Mahle pistons 10.5:1
  • Hydra roller cam .576/.600 ; 242/248
  • FRPP Aluminum “Z” heads 2.02 intake / 1.60 exhaust
  • Ford EFI distributor, MSD cap/rotor
  • Edlebrock Victor upper/lower
  • BBK 75MM throttle body
  • C&L intake tube
  • FRPP 90MM L-MAF
  • MSD 6A box
  • Aeromotive rails, braided lines from firewall, FRPP 47lb'ers and a 255 Walbro
  • BBK shorties, rigged up off-road “h”, Flowmaster exhaust
  • FRPP 4.10 gears
  • ...and a basically stock T-5 Transmission!
  • Tuning by Keith Varin (The Mk2)
Suspension:
  • Maximum Motorsports K-member, A-arms, rear lower adj. control arms, front coilover kit & CC plates
  • Blistein front struts with Hypercoils & Bilstein rear shocks with H&R Supersports
  • Steeda full length subframe connectors
  • Steeda bump steer
Exterior:
  • H.O. Fibertrends 3.5” Cobra R hood
  • Export rear tailights
  • DEPO projector headlights (matching sidemarkers) de-chromed and painted black
  • “Poxenham” front tow hook
Interior:
  • Pioneer AVIC double din swap
  • Autometer Lunar gauges
  • Push button start (inactive)
  • Crappy factory seats
  • SVT rear seat delete / sub & amp mount (made by yours truly)
Wheels / Tires:
  • GT500 replicas: 18x9 front /18x10 rear
  • Pirelli P-Zero Rosso's: 265/35 front ; 315/30 rear
Forcefedhatch:
Performance
Gt40p heads
comp cams dual springs with retainers and 10*locks
explorer intake
cold air intake
bbk fuel pressure regulator
165* thermostat fans set on at 100% of the time
tubular headers
bbk off road H-pipe
flowmaster super 44's w/ 4 " tips,
Rebuilt rear end with 03-04 friction and steels in the trac-loc (carbon fiber)
hardened Yukon axles
3.73 gear
Rebuilt AODE with hardened shafts, alto red friction and steels, reverse mechanical diode,4r70w gear set, J-mod valvebody, spring mods done on 1-2,2-3 shift..
Suspension
Complete prothane bushing master kit with steering rack and sway bar bushings included
KYB gr2's all around
ford racing caster camber plates
H&R super sports with 1 coil removed on all 4 corners
Exterior shaved emblems and spoiler
plasti dip
bullitt gas cover
03-04 cobra headlights
mach 1 grill delete
mach 1 chin spoiler
gt hood scoop
gt rear bumper (was a V6, these items weren't included onto the car)
Interior is all stock just re dyed, and carbon fiber gauge cluster trim
Wheels are 18x9 and 18x10 bullitts 295's rear and 255's up front
Yeahloh95
Performance:
stock short block with afr 165s comp
blower cam
holley system max intake
vortech s trim making 15lbs makes about 500 to the wheels
bbk long tubes
h pipe
flowmaster cat back with magnaflow 3.5"tips
trans and clutch are both stock with a hurst billet shifter
fms alum driveshaft
Suspension:
d and d k member and control arms and 175lb coil overs
rear is metco lowers with double adj uppers and qa1 coilovers with 150lb springs
Exterior:
full saleen kit with s281 molded in wing, LED 3rd brake light and license plate surround
carbon fiber canards
cervinis cobra r hood with full custom airbrushed graphics
03 cobra mirrors with modified bases
Interior:
recaro srd seats
carbon faced auto meter gauges
all billet switches
and my own RSD
full alpine stereo with dvd and JL speakers thru out with 2 10"s in the trunk all finished out in suede
Wheels/Tires:
18x8 and 18x10 ze-forged with nittos 245/45/18 and 285/35/18s
every piece of alum on the car is polished down to the ac compressor and all the brake calipers
Musturd
Performance:
Dart iron eagle 331 stroker
Edelbrock performer rpm heads
Comp 272hr cam
Edelbrock victor 5.0 intake
Csr electric water pump
Vortech s trim with cog drive at 15 lbs
42lb injectors
Pro m maf
Anderson motor sports power pipe
G force t5
BBK long tube headers
BBK off road x pipe
Aeromotive fuel pressure regulator
Aeromotive stealth 340lph fuel pump
Flownaster cat back exhaust
Act 6 puck clutch
Act sfi spec fly wheels
B&M pro ripper shifter
Fms aluminum drive shaft
Suspension :
Upr tubular k member and control arms
Upr pro series rear suspension
Strange Coilovers front and rear with 175lb springs
Through floor subframe connectors
MM 6pt cage with swing outs
Cobra brakes front and rear
8.8 31 spline track lock
Factory ten axles
3:73 gears
Exterior :
Oem Cobra front bumper
Oem Cobra hood
Oem cobra rear bumper
Shaved trunk holes and passenger door lock
Kill switch in rear rear key hole on the trunk .
Interior :
Acura rsx seats
Mm 6pt cage with swing outs
Auto meter monster tach
Battery relocation
Wheels and tires
Bogart d10's
Fronts 165/65/15
Rears Mickey Thompson 28x12.50-15
0EA239B9-20D0-4511-812E-2C98D427C0DF_zps
C8735813-361B-4121-A3BD-43F2E4AC299B_zps
I'm in the middle of redoing a bunch of stuff in the engine bay
7B91730A-6681-4B16-A299-2630D10A8F66_zps
Let the voting begin!!
I hope old Abraham Zapruder had his camera handy when Troy pulled the 95 out of the garage, rare to see it in the wild!
I kid... gonna have to give this some thought, all are badass cars in their own ways.
Agreeeed! Show vs strip vs street vs swap! All spectrums here
Decided that Troy gets my vote, I've inspected the details of the car many times and no stone is left unturned. Even though he needs to drive it more (like I have any room to talk  :rolleyes:  ) it's one hell of a machine.
If only he had shut the damn hood all the way, that would be an awesome pic...
Guest
