Lazer_Red Posted June 27, 2017 Report Share Posted June 27, 2017 I bought a exedy mach 400 clutch and want to know what everyone thought about the pilot and throw out bearing that came with the clutch. I usually use Ford racing parts but I figured I could save the money and use the ones I have. What do you think? Thanks Kris Link to comment Share on other sites More sharing options...
Lazer_Red Posted June 27, 2017 Author Report Share Posted June 27, 2017 Can this be moved to drive line please? Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted June 29, 2017 Moderators Report Share Posted June 29, 2017 A lot of people have had issues with aftermarket bearings. Ive used aftermarket pilot bearings in everything but the throwout bearings have a tendency to make noise. If you want to try it and would be ok if you had to pull the trans again, then go for it. Even after all this, at the end of the day, the Ford bearings have even made noise before. Link to comment Share on other sites More sharing options...
Number Tew Posted June 30, 2017 Report Share Posted June 30, 2017 Noise is not typically the issue with aftermarkets, it's them blowing up and causing damage to the trans. I have personally seen 3 vehicles disabled (one being mine) by aftermarket TOB's. My car was with about 100-200 miles on the TOB. Pulled it, popped in a Ford TOB, no problems since. Many thousands of miles on the build. Make sure to use Motorcraft, not Ford Racing. Link to comment Share on other sites More sharing options...
Lazer_Red Posted June 30, 2017 Author Report Share Posted June 30, 2017 I ended up buying the Ford racing throw out and pilot bearing. Thanks Kris Link to comment Share on other sites More sharing options...
Number Tew Posted July 1, 2017 Report Share Posted July 1, 2017 You may not want to do that. While they may be better than some aftermarket ones, they are still made in China with less quality control than Motorcraft parts. Link to comment Share on other sites More sharing options...
Lazer_Red Posted July 10, 2017 Author Report Share Posted July 10, 2017 On 7/1/2017 at 4:27 PM, Number Tew said: You may not want to do that. While they may be better than some aftermarket ones, they are still made in China with less quality control than Motorcraft parts. Thanks for the reply, if I start heading any noise or problems then I will get the motorcraft unit. I have already bought and installed the Ford racing's parts. Thanks Link to comment Share on other sites More sharing options...
Number Tew Posted July 11, 2017 Report Share Posted July 11, 2017 No problem Link to comment Share on other sites More sharing options...
