ThomasW Posted April 16, 2018 Author Report Share Posted April 16, 2018 Now that all the T1’s and firewall panels are done, i can make my own stuff. My cowl panel is done, mostly. Still a bit of waviness to it, i’ll probly wetsand and clear it one final time. I also separate the splitter from the front bumper and trimmed it. Now i need to do some sanding to smooth it out, then skin it in CF. 3 Link to comment Share on other sites More sharing options...
ThomasW Posted April 23, 2018 Author Report Share Posted April 23, 2018 Stuck at home with a head cold and clogged sinus’, so may as well do something fun to work the cold out. Final coats of clear on my firewall panel: Painted the front bumper: Put the car back in the garage and put it on jackstands under the suspension so i can put the subframe connectors on and start replumbing the brake system as well as some rust cleanup and undercar coating on the bottom side. I’ll probly swap the solid axle out for the irs before taking it off the stands. 4 Link to comment Share on other sites More sharing options...
95riosnake Posted April 25, 2018 Report Share Posted April 25, 2018 That copper color sprinkled into the CF weave is going to look killer on the car when it's finished. I love how the chin/splitter is shaping up also. I would love to see what you'd come up with for a 94-98 cobra front bumper. 1 Link to comment Share on other sites More sharing options...
ThomasW Posted April 27, 2018 Author Report Share Posted April 27, 2018 Installed the foglights and bezels on the bumper last night: Also relocated the proportioning valve and started running new brake hard lines. They could be better, but they wont be visible, so im not to worried about it. I spent all day together working on replacing the rusted rocker panels on my truck, got one side about 1/2 wayish done. Tomorrow its supposes to rain and the truck doesnt fit in the garage, so i’ll spend the day finishing the brake lines and install the subframe connectors on the mustang. 1 Link to comment Share on other sites More sharing options...
RedTwilight Posted May 11, 2018 Report Share Posted May 11, 2018 Is that the paint from thecoatingstore.com? How have you liked it so far? Does it cover well or seem a bit thin/translucent? I'm looking at some base/clear from them. The price og $340.00 seems to good to be true for a gallon of base, clear, and the reducer and activator. I just don't want a cheap paint that sprays on thin and doesn't have the coverage. Link to comment Share on other sites More sharing options...
ThomasW Posted May 13, 2018 Author Report Share Posted May 13, 2018 On 5/11/2018 at 9:53 AM, RedTwilight said: Is that the paint from thecoatingstore.com? How have you liked it so far? Does it cover well or seem a bit thin/translucent? I'm looking at some base/clear from them. The price og $340.00 seems to good to be true for a gallon of base, clear, and the reducer and activator. I just don't want a cheap paint that sprays on thin and doesn't have the coverage. It is! I really like the stuff so far. It sprays well and the coverage is pretty godd. The copper gets 1 light coat and is then left to flash, then 2 medium wet coats and that is all. Clear normally gets 4-5 coats for the extra shine. 1 Link to comment Share on other sites More sharing options...
ThomasW Posted July 3, 2018 Author Report Share Posted July 3, 2018 Been crazy busy with work, but the past few weeks ive made some progress: Underside of the car was cleaned and a rust sealer/prevention primer and black paint applied. I also recoated the wheel wells with a rubberized undercoating: I also painted the hood and mirror caps: Sprayed a test panel for the possibility of some ghost racing stripes: Removed the IRS from ole red the donor car: Then i finished bending and installing new rear brake hardlines and stuffed the irs into the project car: Here is what the car looked like just prior to installing the irs: Then i started installing the Front Cobra brakes onto the IRS. A custom bracket, minimal trimming of the dust shield (I’ll likely make new ones from CF or something) and a littl grinding of the ridges on the top of the cobra calipers and it fits like a glove: I also ordered Everything needed to run 14” GT500 brembo’s up front. Based on my research and some measurement, its looking Very possible i’ll be able to use my 17” FR500’s. 1 Link to comment Share on other sites More sharing options...
ThomasW Posted July 3, 2018 Author Report Share Posted July 3, 2018 13 minutes ago, Evilcw311 said: What are you doing for the e-brake? Who needs a e-brake? Lol i’ll use an aircraft hydraulic parking brake. Basically its like a line lock, but mechanically actuated. Link to comment Share on other sites More sharing options...
RedTwilight Posted July 3, 2018 Report Share Posted July 3, 2018 Nice update! I've been wondering where you've been. Good to see you're still working away on the stang! What side mirrors are those? '05 and later? They fit pretty well if so. Link to comment Share on other sites More sharing options...
Supporting Member seijirou Posted July 3, 2018 Supporting Member Report Share Posted July 3, 2018 Did you make the brackets for the rear brakes or are they available somewhere? Link to comment Share on other sites More sharing options...
ThomasW Posted July 3, 2018 Author Report Share Posted July 3, 2018 40 minutes ago, RedTwilight said: Nice update! I've been wondering where you've been. Good to see you're still working away on the stang! What side mirrors are those? '05 and later? They fit pretty well if so. They are MMD’s from american muscle. Ive never seen them in person, so it fit perfect with the concept of this build. Haha Link to comment Share on other sites More sharing options...
ThomasW Posted July 3, 2018 Author Report Share Posted July 3, 2018 12 minutes ago, seijirou said: Did you make the brackets for the rear brakes or are they available somewhere? Currently.. neither. Lol i machined up a spacer to verify the needed bracket thickness with the caliper bracket tightened. Now i need to pull the whole thing apart so i can draw up the Bracket in Cad and have them machined. Link to comment Share on other sites More sharing options...
Supporting Member seijirou Posted July 3, 2018 Supporting Member Report Share Posted July 3, 2018 10 minutes ago, ThomasW said: Currently.. neither. Lol i machined up a spacer to verify the needed bracket thickness with the caliper bracket tightened. Now i need to pull the whole thing apart so i can draw up the Bracket in Cad and have them machined. Gotcha. I will definitely be following with interest! Link to comment Share on other sites More sharing options...
ThomasW Posted July 4, 2018 Author Report Share Posted July 4, 2018 Swapped the stock suspension over into ole red. Then pulled the UPR tubular suspension into the garage. I’ll like add some reinforcement gussets and tubes to this thing to beef it up. Theres also rust alread pushing through the paint, so it’ll have ti get cleaned up and painted again. I also picked up a used stock shifter boot and cut all the sewn seams. I used it for a template to cut some pieces out of this faux CF embossed leather. I also was looking at upholestry threas and found a color that’ll go well with the car: 2 Link to comment Share on other sites More sharing options...
Prokiller Posted July 5, 2018 Report Share Posted July 5, 2018 i doubt you'll be able to fit the 17" gt500s. and depending on the bracket you'll be using, the offset will give you a problem. when i put my vintage venom kit on, i was able to fit the 18" gt500s i had, but it was very close. Link to comment Share on other sites More sharing options...
ThomasW Posted July 5, 2018 Author Report Share Posted July 5, 2018 3 hours ago, Prokiller said: i doubt you'll be able to fit the 17" gt500s. and depending on the bracket you'll be using, the offset will give you a problem. when i put my vintage venom kit on, i was able to fit the 18" gt500s i had, but it was very close. I’ll be making my own bracket as im trying to limit the need for a spacer between the hub and rotor. Im unsure if its possible, but thats kind of part if the fun. Link to comment Share on other sites More sharing options...
ThomasW Posted July 9, 2018 Author Report Share Posted July 9, 2018 (edited) Edited July 9, 2018 by ThomasW 1 Link to comment Share on other sites More sharing options...
ThomasW Posted July 10, 2018 Author Report Share Posted July 10, 2018 Its just a small upgrade..... 2 Link to comment Share on other sites More sharing options...
ThomasW Posted July 18, 2018 Author Report Share Posted July 18, 2018 Bracket design for the GT500 brakes are done: Rear Bracket design is done as well and the files for both have been sent to my machinist buddy. Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted July 19, 2018 Moderators Report Share Posted July 19, 2018 Not that I have GT500 brakes, but I want a set of each! Link to comment Share on other sites More sharing options...
RedTwilight Posted July 19, 2018 Report Share Posted July 19, 2018 2 hours ago, Psychorugby said: Not that I have GT500 brakes, but I want a set of each! +1 Link to comment Share on other sites More sharing options...
ThomasW Posted July 19, 2018 Author Report Share Posted July 19, 2018 10 hours ago, Psychorugby said: Not that I have GT500 brakes, but I want a set of each! 7 hours ago, RedTwilight said: +1 Yall are killing me! Lol The machinist buddy is all on board with doing many sets, im waiting on a phone call from him when he gets off work so i can clarify some stuff for him and he’ll likely get the first set of brackets done, hopefully this weekend. Link to comment Share on other sites More sharing options...
ThomasW Posted July 20, 2018 Author Report Share Posted July 20, 2018 14 minutes ago, Evilcw311 said: I wonder if these are the same brackets to use the s550 brake calipers. I’ve messaged that Pete guy on his site and directly on the forums and he refuses to respond to people who aren’t his “buddies”. I won’t order stuff from someone who can’t even respond and answer simple questions. It may work. If someone wants to send me a loades caliper to try out, i can. If they dont fit, i can see if making a bracket that would fit would be possible. Link to comment Share on other sites More sharing options...
Supporting Member seijirou Posted July 21, 2018 Supporting Member Report Share Posted July 21, 2018 I too want a set of each. Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted July 21, 2018 Moderators Report Share Posted July 21, 2018 Well hell, I’ve got an irs also and need to upgrade brakes. I guess I’ll hop on this bandwagon. Could you get some prices for us? Link to comment Share on other sites More sharing options...
ThomasW Posted July 21, 2018 Author Report Share Posted July 21, 2018 (edited) On 7/19/2018 at 8:43 AM, Psychorugby said: Not that I have GT500 brakes, but I want a set of each! 51 minutes ago, LWARRIOR1016 said: Well hell, I’ve got an irs also and need to upgrade brakes. I guess I’ll hop on this bandwagon. Could you get some prices for us? 4 hours ago, seijirou said: I too want a set of each. On 7/19/2018 at 11:11 AM, RedTwilight said: +1 On 7/19/2018 at 8:43 AM, Psychorugby said: Not that I have GT500 brakes, but I want a set of each! 22 hours ago, Evilcw311 said: I wonder if these are the same brackets to use the s550 brake calipers. I’ve messaged that Pete guy on his site and directly on the forums and he refuses to respond to people who aren’t his “buddies”. I won’t order stuff from someone who can’t even respond and answer simple questions. Machinist buddy came back and quoted the wrong material for these things.. i’ll get back with a price once he figures it out. Edited July 21, 2018 by ThomasW 1 Link to comment Share on other sites More sharing options...
Supporting Member seijirou Posted July 21, 2018 Supporting Member Report Share Posted July 21, 2018 Oh okay, well I'm down unless it changes dramatically. Just need to know where to send the $. Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted July 21, 2018 Moderators Report Share Posted July 21, 2018 And if your really interested in the s550 calipers, I’ll try to grab one and send it to you. You want pads and all? Link to comment Share on other sites More sharing options...
ThomasW Posted July 21, 2018 Author Report Share Posted July 21, 2018 27 minutes ago, LWARRIOR1016 said: And if your really interested in the s550 calipers, I’ll try to grab one and send it to you. You want pads and all? I have had more than one person express interest on using the S550 calipers. If the interest is truely there, i have no problem looking to see if its possible. Link to comment Share on other sites More sharing options...
ThomasW Posted July 23, 2018 Author Report Share Posted July 23, 2018 9 minutes ago, Evilcw311 said: I’d be down for the s550’s. I bought these and thought I’d be getting the set of brackets from the other place but the serious lack of communication, almost feels downright like s refusal to communicate. If if I remember correctly his was the same as his gt500 brackets but you had to use spacers. Last I had seen he was gonna try to start making a set that didn’t need the spacers but that was a long time ago and that’s what I can’t get him to respond about. Obviously it would be preferable to not add additional spacers if not needed on something like brakes. If lwarrior can’t grt those to you for some reason then let me know and I could see about shippOmg mine. Yea the 3/4” spacer is what killed it for me just buying stuff from the other guys. I have a tubular front suspension with under 1k miles and really didnt want to spend $250 to replace the A arms for fox length arms. We’ll see what Lwarrior has to say and figure it out from there. I believe the other guys have used the S550 calipers with their current bracket/spacer setup, but it appears that the caliper needed the webbing between the mount ears on the caliper removed. Far more work than i would want to do. Link to comment Share on other sites More sharing options...
ThomasW Posted July 27, 2018 Author Report Share Posted July 27, 2018 The wife sewed up a shift boot for me: also pulled the body harness and ecu harness from the donor: swapped the pedal box over: And now that the GT500 brake bracket design is complete, i painted the front brake calipers: Link to comment Share on other sites More sharing options...
White95 Posted July 27, 2018 Report Share Posted July 27, 2018 Keep up the good work brother! Link to comment Share on other sites More sharing options...
ThomasW Posted July 28, 2018 Author Report Share Posted July 28, 2018 Got the fuel pressure gauge installed and wired up with the rest of the A pillar gauges: Got almost all of the interior associated with the dash reinstalled after swapping the dash harness from the red car onto the original dash for the white car. I also installed the computer and pcm harness. Then i needed to route all of the wiring from the gauges through the firewall. Typically i would have just cut a slit in the rubber boot near the hydroboost. This time, i had a hole where the hood pop cable goes through the firewall, so i enlarged that hole and used it for the pass through for the boost, electric fuel pressure, wideband, oil pressure and water temp. Then looped it all up and used a velcro tye to hold it out of the way. Then just to see what it looked like. I bolted the painted brembo’s up to the bracket. I had alread rebagged and sprayed the rotor with oil to prevent rusting, so i didnt bother pulling it back out. The Brembo logo isnt noticeable from a distance which is exactly what i was shooting for. Link to comment Share on other sites More sharing options...
droptoppony Posted July 28, 2018 Report Share Posted July 28, 2018 It's like building it at the factory when it's disassembled like this. Link to comment Share on other sites More sharing options...
ThomasW Posted July 28, 2018 Author Report Share Posted July 28, 2018 17 minutes ago, droptoppony said: It's like building it at the factory when it's disassembled like this. Yes it is.. just way longer of a process. Link to comment Share on other sites More sharing options...
ThomasW Posted July 28, 2018 Author Report Share Posted July 28, 2018 Interior is mostly done... and thanks to two kids, it needs vacuumed again already: also the hydroboost, AC dryer and engine harness plug mounts all done. Im still undecided if im going to tuck the engine harness plug. 2 Link to comment Share on other sites More sharing options...
ThomasW Posted August 3, 2018 Author Report Share Posted August 3, 2018 (edited) Wire tuck is complete for the body harness’. Also got the remainder of the brake hard lines routed. Edited August 3, 2018 by ThomasW Link to comment Share on other sites More sharing options...
ttocs Posted August 3, 2018 Report Share Posted August 3, 2018 are you sure there is enough clearance for the wheels/tires when they are on there, compressed and turning? Link to comment Share on other sites More sharing options...
ThomasW Posted August 3, 2018 Author Report Share Posted August 3, 2018 5 hours ago, ttocs said: are you sure there is enough clearance for the wheels/tires when they are on there, compressed and turning? Should be as long as i dont go 4x4 in the thing Link to comment Share on other sites More sharing options...
ThomasW Posted August 25, 2018 Author Report Share Posted August 25, 2018 (edited) Some stuff has been arriving for the past week or two. Some front Bilstein’s showed up, so thay completes the damper package. I also got all the stuff for the AN hose hydroboost conversion. I also got a tap and some -8 orb to 8an male fittings to convert the valvecovers to AN line breathers. Also picked up a Mishimotor power steering reservoir. Its a nice piece, but it has an O-ring seal and no vent, which i was surprised to see. Oh well, nothing a drill bit cant fix. Haha Some random box showed up today with some S550 calipers. It appears that they will fit my adapter bracket with just slight mods to the caliper and the same mods to the spindle. I am amazed at the size differences from 94-04 cobra, GT500 and S550 calipers. Its crazy! I then got all the teflon washers put on the metric to AN adapters and installed those: I also started routing the ptfe hoses from the hydroboost into the fender well area and cutting them over length so i know i have enough hose to work with. Here is a photo of the P/S reservoir and where i hope to put it. Its a tight fit, but it should work. I also got a roll of 1kg Black ABS plastic for the 3D printer, so now i need to draw up and print some AN hose separators. Edited August 25, 2018 by ThomasW 1 Link to comment Share on other sites More sharing options...
