Defiant Posted January 23, 2018 Report Share Posted January 23, 2018 Just transferring the main posts from another forum. '00 GT 5 speed with suspension/brake/engine mods Needs a rear spacer I know I know.. stock headlights installed. PO had some ricey chromies in there. Nothing like that brand new gloss! went wingless for a while began removing this heavy sound system the box was so large it doesn't fit thru the opening. The PO cut out the sheet metal behind the seats so it can fit that way, and it was still real tight hack wiring that I resoldered because only 1 speaker was functional... fixed removing stock T45 shifter new pivot cup put in (from a Jeep!) steeda tri-ax installed and new shift boot put on trunk officially cleaned up new fuel filter some nice detail work short burst Link to comment Share on other sites More sharing options...
Defiant Posted January 23, 2018 Author Report Share Posted January 23, 2018 custom key setup, no more bs separate key and fob removing stock gauge cluster to install new termi cluster Link to comment Share on other sites More sharing options...
Prokiller Posted January 23, 2018 Report Share Posted January 23, 2018 the key is very intriguing. how well does it fit into the ignition? Link to comment Share on other sites More sharing options...
Defiant Posted January 23, 2018 Author Report Share Posted January 23, 2018 4 hours ago, Prokiller said: the key is very intriguing. how well does it fit into the ignition? I removed the plastic cover on the ign switch so it fits fine. 1 Link to comment Share on other sites More sharing options...
