Moderators LWARRIOR1016 Posted August 27, 2019 Moderators Report Share Posted August 27, 2019 Hell yeah! Glad to see it running again. Can I ask why you originally used expoxy vs welding the intake? Link to comment Share on other sites More sharing options...
TTSALEEN Posted August 27, 2019 Author Report Share Posted August 27, 2019 39 minutes ago, LWARRIOR1016 said: Hell yeah! Glad to see it running again. Can I ask why you originally used expoxy vs welding the intake? Sure. Back in 2008 Starnes Racing told me they could modify it from the Navigator to the Ford GT style location ports. They didn't tell me how, but it wasn't cheap. I understand from talking to Mel @ Fastlane that using epoxy is not uncommon, but most engine builders use it sparingly and in very thin coats. My intake had thick spots of it where the ports were reshaped, which I assume is alot easier to do with epoxy than trying to weld in and grind down aluminum. Mel actually ground all the old out and put a very thin layer of new epoxy in it and then reshaped the ports to work. Car runs great, so it should be good to go now. I plan to pull the engine this winter and freshen it up since after 11 years it is about time. Ryan Link to comment Share on other sites More sharing options...
TTSALEEN Posted September 4, 2019 Author Report Share Posted September 4, 2019 So all my prep for Mustang week 2019 was a waste as most of yall's was too. Got a new set of rear wheels - Bogart RT 15x10" with 6.5" backspace. Took them to MacFab Beadlocks to get a beadlock installed. Couldn't decide between polished (like I have on my 16's) or black so I chose both. LOL. The black look real nice! Also mounted a new set of 275-60-15 M/T ET Street Radial Pro tires on it. Seems to hook real good on the street from a roll. Can't wait to go to the track and try it out soon! 1 Link to comment Share on other sites More sharing options...
TTSALEEN Posted September 9, 2019 Author Report Share Posted September 9, 2019 Pic frpm Saturday at work. And after I drove it over to Buckly's house and tried to launch it in front of his house. LOL. Got a little outta shape,but still sent it. HAHA. 4 1 Link to comment Share on other sites More sharing options...
TTSALEEN Posted September 20, 2019 Author Report Share Posted September 20, 2019 Link to comment Share on other sites More sharing options...
TTSALEEN Posted September 20, 2019 Author Report Share Posted September 20, 2019 So here's the latest update - The stupid Quick6 firmware update did NOT fix my ERROR problem during the burnout. Upon my burnout, the car displayed OSS ERROR and transbrake would not work just like before. I had to turn off car and restart to clear the problem. Next I am on the new 275 radials. These hook pretty good, but my car still twists so bad that it unloads the car and spins. I really need to get a rollcage installed and a antiroll bar along with updated shocks/struts to help this thing out. Lastly, I still have a problem with a flutter/surge at higher rpm. Gonna do a leakdown/compression check first but I think maybe my 11 year old valvesprings are weak. Slowly trying to get this thing ironed out! Went a best of 6.1 @ 117mph last night with a terrible 1.54 sixty foot time and the above issues on the lower boost (pump gas) tune up. 1 Link to comment Share on other sites More sharing options...
Yeahloh95 Posted October 4, 2019 Report Share Posted October 4, 2019 glad to see you have it out and hitting the track again with it . 1 Link to comment Share on other sites More sharing options...
TTSALEEN Posted October 7, 2019 Author Report Share Posted October 7, 2019 Found a problem in my ignition system. My MSD coils that are over 12 years old, have some rotted connections. I attribute this to some water/moisture getting in there over the years. So a new set of coils and a new set of spark plug wires later and the car seems to be running stronger. I also installed a MSD Tach adapter to feed a clean RPM signal to my Quick 6 trans controller. So far no OSS Error codes anymore while doing a burnout. True test will be next time I goto the track. Had my new tuner riding shotgun watching the laptop and doing datalogs. She had no fear. Better than some grown men that have sat in that passenger seat. LOL Link to comment Share on other sites More sharing options...
Yeahloh95 Posted October 10, 2019 Report Share Posted October 10, 2019 she did great glad you found your problem 1 Link to comment Share on other sites More sharing options...
TTSALEEN Posted November 4, 2019 Author Report Share Posted November 4, 2019 Well after putting it off for way too long, I finally had a 6 point rollbar installed into the TTSaleen. This came about while I was also performing some rearend suspension modifications and stiffening up the chassis. I took the car to Jason Brazzel in Cove City, NC for the work. He did a great job fabbing up the rollbar for me to still allow my leather seats front/rear to fit. He also built new full length subframe connectors and tied the rollbar thru the floor into them. I added an antirollbar to the car which attaches under the rearend to allow me to retain the tailpipes (street car!). Hopefully with these changes, the car will not flex as bad, be safer, and allow me to get more of this power to the ground. 3 Link to comment Share on other sites More sharing options...
TTSALEEN Posted November 9, 2019 Author Report Share Posted November 9, 2019 Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted November 9, 2019 Moderators Report Share Posted November 9, 2019 Man! All that work, just to find more problems. That truly sucks. What you said was clear as day, it hooked up and left hard, you needed more power at the launch. Great work though, I’m looking forward to seeing it sorted out. 1 Link to comment Share on other sites More sharing options...
ttocs Posted November 10, 2019 Report Share Posted November 10, 2019 you did not even have sub frame connectors yet? I am willing to bet you will notice a difference going from that to fully caged lol.... Link to comment Share on other sites More sharing options...
TTSALEEN Posted November 10, 2019 Author Report Share Posted November 10, 2019 2 hours ago, ttocs said: you did not even have sub frame connectors yet? I am willing to bet you will notice a difference going from that to fully caged lol.... I had maximum motorsports subframe connectors. Jason cut those out and made his own which he tied into the rollbar (cut holes thru the floor). Check out my latest video from today. Link to comment Share on other sites More sharing options...
TTSALEEN Posted November 11, 2019 Author Report Share Posted November 11, 2019 1 Link to comment Share on other sites More sharing options...
TTSALEEN Posted December 26, 2019 Author Report Share Posted December 26, 2019 Link to comment Share on other sites More sharing options...
TTSALEEN Posted December 30, 2019 Author Report Share Posted December 30, 2019 On 12/26/2019 at 3:02 PM, Evilcw311 said: Those look awesome!!!! What did you ever decide to do about the trans controller issues? Sent from my iPhone using Tapatalk I talked to US Shift and ran a separate input for RPM signal to their control box. But not had a chance to test it at the track to see if it fixed the shifting yet. With the turbo upgrades, I also have a new boost controller to install with CO2 that I haven't done yet. Once I get all these things done, I hope to get a track outing in the books soon to see how the car will react. 1 Link to comment Share on other sites More sharing options...
TTSALEEN Posted January 2, 2020 Author Report Share Posted January 2, 2020 Link to comment Share on other sites More sharing options...
TTSALEEN Posted January 15, 2020 Author Report Share Posted January 15, 2020 Link to comment Share on other sites More sharing options...
TTSALEEN Posted January 21, 2020 Author Report Share Posted January 21, 2020 Link to comment Share on other sites More sharing options...
TTSALEEN Posted January 21, 2020 Author Report Share Posted January 21, 2020 1 Link to comment Share on other sites More sharing options...
TTSALEEN Posted January 30, 2020 Author Report Share Posted January 30, 2020 Link to comment Share on other sites More sharing options...
TTSALEEN Posted February 11, 2020 Author Report Share Posted February 11, 2020 (edited) Edited February 11, 2020 by TTSALEEN 1 Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted February 11, 2020 Moderators Report Share Posted February 11, 2020 Did I hear you say the Mach 1 was down for the count? What’s up with that? Link to comment Share on other sites More sharing options...
TTSALEEN Posted February 11, 2020 Author Report Share Posted February 11, 2020 2 minutes ago, LWARRIOR1016 said: Did I hear you say the Mach 1 was down for the count? What’s up with that? Link to comment Share on other sites More sharing options...
Moderators LWARRIOR1016 Posted February 11, 2020 Moderators Report Share Posted February 11, 2020 Oh no! That sucks. Sorry to hear that man. I do like the idea of increased compression and bigger blower though lol. Next thing you know, you’ll be shooting for 1k rwhp on this one. That could be your title for the next thread, “Mild built Mach 1, only 1k rwhp”. 1 1 Link to comment Share on other sites More sharing options...
RedTwilight Posted February 13, 2020 Report Share Posted February 13, 2020 On 2/11/2020 at 10:44 AM, LWARRIOR1016 said: Oh no! That sucks. Sorry to hear that man. I do like the idea of increased compression and bigger blower though lol. Next thing you know, you’ll be shooting for 1k rwhp on this one. That could be your title for the next thread, “Mild built Mach 1, only 1k rwhp”. It could be known as the Mach 1K then. 2 Link to comment Share on other sites More sharing options...
TTSALEEN Posted February 13, 2020 Author Report Share Posted February 13, 2020 14 minutes ago, RedTwilight said: It could be known as the Mach 1K then. You just won the internet on that one today! 😄 1 Link to comment Share on other sites More sharing options...
TTSALEEN Posted February 17, 2020 Author Report Share Posted February 17, 2020 Link to comment Share on other sites More sharing options...
White95 Posted February 17, 2020 Report Share Posted February 17, 2020 Ruh roh.. Good catch before it became a potentially more serious issue! Link to comment Share on other sites More sharing options...
TTSALEEN Posted March 23, 2020 Author Report Share Posted March 23, 2020 Link to comment Share on other sites More sharing options...
TTSALEEN Posted March 30, 2020 Author Report Share Posted March 30, 2020 Link to comment Share on other sites More sharing options...
TTSALEEN Posted April 10, 2020 Author Report Share Posted April 10, 2020 (edited) Edited April 10, 2020 by TTSALEEN Link to comment Share on other sites More sharing options...
TTSALEEN Posted April 10, 2020 Author Report Share Posted April 10, 2020 6 minutes ago, Evilcw311 said: Dude so sorry to hear that about your dad. You two look a lot alike. Did they at least let some of the brothers in to do his final rights at the funeral? Sent from my iPhone using Tapatalk We could only have 20 total people at the funeral home and the grave site. His brothers were there, but had to keep their distance. It sucks they way it works these days due to Coronavirus. There was no military presence due to this as well. Link to comment Share on other sites More sharing options...
TTSALEEN Posted April 27, 2020 Author Report Share Posted April 27, 2020 Link to comment Share on other sites More sharing options...
TTSALEEN Posted April 30, 2020 Author Report Share Posted April 30, 2020 Link to comment Share on other sites More sharing options...
TTSALEEN Posted October 6, 2020 Author Report Share Posted October 6, 2020 Video might be boring for some, but for others here's how I pulled the engine from the TTSaleen. I figured after 12 years it was time to freshen it up with rings/bearings/seals, etc. Link to comment Share on other sites More sharing options...
White95 Posted October 22, 2020 Report Share Posted October 22, 2020 Can’t wait for the results. Link to comment Share on other sites More sharing options...
