Reaperstang79 Posted August 23, 2012 Report Share Posted August 23, 2012 Is it hard to do an A/C delete? ..I have been thinking about doing it for a while, mostly because I never use my A/C and not to mention it doesnt work anyway lol.Not hard, I know someone sells a kit (can't remember the vendor) that I basically a bracket with an idler pulley that les you use your stock belt. Te bracket just replaces your ac compressor. Link to comment Share on other sites More sharing options...
MMR Posted August 23, 2012 Report Share Posted August 23, 2012 Thanks Erik, I am aware of the delete kit, it was more the process of getting all the pumps and tubing out. Link to comment Share on other sites More sharing options...
Reaperstang79 Posted August 23, 2012 Report Share Posted August 23, 2012 Thanks Erik, I am aware of the delete kit, it was more the process of getting all the pumps and tubing out.Thats even easier to do. There are (2) 13mm bolts that hol the lines onto the condensor and then just disconnect the spring locks where the ac accumulator is and then your done!! Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 23, 2012 Author Report Share Posted August 23, 2012 Thanks Erik!! I'm going to delete all the a/c stuff and not even use a bracket with idler. Just going to switch the smooth idler to a ribbed one, the belt will go in front of the tensioner, and then to the crank, that way the tensioner is still doing its job while deleting the a/c system as well. Plus, tons more weight to be taken off, it's not a street car so I don't think I will miss it. Link to comment Share on other sites More sharing options...
MMR Posted August 23, 2012 Report Share Posted August 23, 2012 If you havn't already, then you should check out the weight reduction write up on here, lots of good info. And thanks Erik! :thumb:Edit: Here you go sir!http://www.sn95source.com/showthread.php?647-Official-Weight-Reduction-List Link to comment Share on other sites More sharing options...
MMR Posted August 23, 2012 Report Share Posted August 23, 2012 By the way Luis, if you are going to restore some old parts, then check out: http://www.eastwood.com/ - lots of good stuff on there and all of it is quallity stuff too. Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 23, 2012 Author Report Share Posted August 23, 2012 The main parts I needed to restore was just the tensioner and idlers. I just need to swap the pulley from the tensioner and its good to go. Link to comment Share on other sites More sharing options...
SniveTroll Posted August 23, 2012 Report Share Posted August 23, 2012 this is what im using to delete the A/C in mine. mine is 8-rib also. Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 23, 2012 Author Report Share Posted August 23, 2012 Going to bypass the a/c or delete pulley and go directly to the crank after the tensioner. Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 24, 2012 Author Report Share Posted August 24, 2012 Well I havent gotten the bolts yet so I sent Nick from MHS a message asking whats up, he said he missed it and sent them out today. Mistakes happen I suppose but I've already been waiting 2 weeks for them. Hopefully they will be here soon. Link to comment Share on other sites More sharing options...
WildWillyWalker Posted August 24, 2012 Report Share Posted August 24, 2012 Could you post up pictures of the cooling mods you do please (when you do them)? I've seen a couple different things. Are the 5.4's bad like the 4.6 4vs where the #8 cylinder would get hot and the valvetrain would tap? Link to comment Share on other sites More sharing options...
SniveTroll Posted August 24, 2012 Report Share Posted August 24, 2012 Lately Nick's team has been in the slump. i understand the workload being swamped. Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 25, 2012 Author Report Share Posted August 25, 2012 So I finally found a guy that does AMAZING work on customizing long tube headers. I will be running stock logs for the mean time so that is going to bring my expected power level by a lot. My budget for those headers is $1200 so hopefully he stays within that budget. I know the other company already makes them but they were for the 2v so I'm not exactly sure if they will fit perfect on my car or not. Link to comment Share on other sites More sharing options...
MMR Posted August 26, 2012 Report Share Posted August 26, 2012 For $1200 he better know what he is doing. :biggrin1: Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 26, 2012 Author Report Share Posted August 26, 2012 Yeah, some expensive headers arent they? Link to comment Share on other sites More sharing options...
MMR Posted August 26, 2012 Report Share Posted August 26, 2012 Dumb question; can't he just take the measurements off the 2v headers you had before? Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 26, 2012 Author Report Share Posted August 26, 2012 I didn't have long tubes in the 2v. Link to comment Share on other sites More sharing options...
MMR Posted August 26, 2012 Report Share Posted August 26, 2012 You didn't?Did Nate take them off again or something?http://3.7mustang.com/vb/f56/domin8s-5-4l-build-thread-install-started-post-409-a-233782/index24.html Link to comment Share on other sites More sharing options...
MMR Posted August 26, 2012 Report Share Posted August 26, 2012 You didn't?Didn Nate take them off again or something?http://3.7mustang.com/vb/f56/domin8s-5-4l-build-thread-install-started-post-409-a-233782/index24.html Link to comment Share on other sites More sharing options...
Reaperstang79 Posted August 26, 2012 Report Share Posted August 26, 2012 Damn, $1200 is a lot but in the end your car will be one of a kind. Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 26, 2012 Author Report Share Posted August 26, 2012 Thanks man. The stock logs are going to hold me back a ton but don't have the cash to shell out for some long tubes. Link to comment Share on other sites More sharing options...
Reaperstang79 Posted August 26, 2012 Report Share Posted August 26, 2012 Thanks man. The stock logs are going to hold me back a ton but don't have the cash to shell out for some long tubes.I hear you man. Did you get your credit card stuff fixed?? Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 26, 2012 Author Report Share Posted August 26, 2012 Not yet, I've been doing really small jobs in cash to get me by for the mean time. Link to comment Share on other sites More sharing options...
Reaperstang79 Posted August 26, 2012 Report Share Posted August 26, 2012 Not yet, I've been doing really small jobs in cash to get me by for the mean time.Damn bro, but at least that's getting you by. Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 27, 2012 Author Report Share Posted August 27, 2012 Since I have the engine out and valve covers easily accessible, what wrinkle paint should I get? Thinking about black but don't think the covers will "Pop" under the hood because its too dark. Maybe Ford Blue in wrinkle paint? Link to comment Share on other sites More sharing options...
MMR Posted August 27, 2012 Report Share Posted August 27, 2012 don't know why my post was removed?am I not allowed to link to another forum? Link to comment Share on other sites More sharing options...
Reaperstang79 Posted August 27, 2012 Report Share Posted August 27, 2012 Since I have the engine out and valve covers easily accessible, what wrinkle paint should I get? Thinking about black but don't think the covers will "Pop" under the hood because its too dark. Maybe Ford Blue in wrinkle paint?Mine will be black with the powered by Svt cop covers. That will stand out even with my black car. The ford blue powder coat is awesome if you can find it. Now as far as wrinkle paint-I'm not sure!! Link to comment Share on other sites More sharing options...
MMR Posted August 27, 2012 Report Share Posted August 27, 2012 Ford Blue FTW! Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 28, 2012 Author Report Share Posted August 28, 2012 I got my head bolts already and torqued everything down. I may be putting the engine into the Mustang sooner than I had thought. Link to comment Share on other sites More sharing options...
iRoush Posted August 28, 2012 Report Share Posted August 28, 2012 Awesome. I have an e-boner right now Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 28, 2012 Author Report Share Posted August 28, 2012 Lol, it might go in as soon as Friday afternoon after class. I have to port a blower, plenum, and throttle body for a Lightning on Saturday and Sunday is my one actual day off. If not Friday then Monday for sure. I need to find some headers first, need stock logs. Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 29, 2012 Author Report Share Posted August 29, 2012 Engine goes in tomorrow. Link to comment Share on other sites More sharing options...
SniveTroll Posted August 29, 2012 Report Share Posted August 29, 2012 I'm e-stoked. This is a major achievement.Sent by smoke signals Link to comment Share on other sites More sharing options...
Det_Riot Posted August 29, 2012 Report Share Posted August 29, 2012 damn dude you're making huge headway on this project! Link to comment Share on other sites More sharing options...
iRoush Posted August 29, 2012 Report Share Posted August 29, 2012 my e-penor is tingling again :look: Link to comment Share on other sites More sharing options...
Luis@OrtizPerformance Posted August 29, 2012 Author Report Share Posted August 29, 2012 Lol, I still need to buy and install stock headers. It would be way easier to install the headers when the engine is out but I'm Ortiz and Ortiz says the engine is going in tomorrow. The o/r x pipe is out anyways so installing the headers with the engine in wont be too bad. Plus, my tubular front end suspension will make it easier anyways. I just don't like having my engine out taking a TON of space. Link to comment Share on other sites More sharing options...
iRoush Posted August 29, 2012 Report Share Posted August 29, 2012 LOL. very nicely put. Link to comment Share on other sites More sharing options...
MMR Posted August 29, 2012 Report Share Posted August 29, 2012 Ortiz FTW Link to comment Share on other sites More sharing options...
Reaperstang79 Posted August 29, 2012 Report Share Posted August 29, 2012 Fuckin awesome bro!! Need some pics of the engine going in!! Link to comment Share on other sites More sharing options...
MMR Posted August 29, 2012 Report Share Posted August 29, 2012 Fuckin awesome bro!! Need some pics of the engine going in!! This^^ Link to comment Share on other sites More sharing options...
