Jeemee Posted January 25, 2013 Report Share Posted January 25, 2013 My ebrake light on my dash stays on all the time unless I'm accelerating. Anyone know how to fix it? If I can't find the problem then I'll just unplug the sensor. Anyone know where it is? On the handle or the actual brake! Any help much appreciated. Sent from my Samsung Note using Tapatalk 2 Link to comment Share on other sites More sharing options...
F8L GT Posted January 25, 2013 Report Share Posted January 25, 2013 Have you checked the brake fluid in the reservoir? Link to comment Share on other sites More sharing options...
Det_Riot Posted January 25, 2013 Report Share Posted January 25, 2013 Have you checked the brake fluid in the reservoir?Probably this. After my brake swap it was kinda low and that was my problem Link to comment Share on other sites More sharing options...
Jeemee Posted January 25, 2013 Author Report Share Posted January 25, 2013 Really? Never even crossed my mind. I'll give it a look. If that isn't it, any of you know where the connector is? Wow, brake fluid haha. Duh. Sent from my Samsung Note using Tapatalk 2 Link to comment Share on other sites More sharing options...
F8L GT Posted January 25, 2013 Report Share Posted January 25, 2013 Switch is under the brake lever Link to comment Share on other sites More sharing options...
Jeemee Posted January 25, 2013 Author Report Share Posted January 25, 2013 Thank you!Sent from my Samsung Note using Tapatalk 2 Link to comment Share on other sites More sharing options...
Drake Posted January 25, 2013 Report Share Posted January 25, 2013 Yeah if it's too low definitely lights up the dash Link to comment Share on other sites More sharing options...
fry Posted February 1, 2013 Report Share Posted February 1, 2013 The connector under the center console is a pain, it'll definitely make the light come on during accelerating/braking/turning because it moves around if its not sitting just right. If you're not sure which wire it is, you can pull the center console out and move the wires around the e-brake, the connector will make the light come on and off so it's easy to tell which one it is. Link to comment Share on other sites More sharing options...
SniveTroll Posted February 2, 2013 Report Share Posted February 2, 2013 Ebrake - the contact under the lever comes loose. Stamped metal lever.Sent by smoke signals Link to comment Share on other sites More sharing options...
