the.greg Posted March 13, 2013 Report Share Posted March 13, 2013 After I installed my built transmission I realized how aged and torn my lower shift boot had become and figured it was time to upgrade. I ordered a new shift boot and set about the easy install.Tools needed: 8mm socket, 13mm socket, I used a 1/4 ratchet and a short extension to make the job easier.Step 1: Remove shift knob by turning counter-clockwise.Step 2: Gently pull shifter bezel outwards and disengage the cig lighter harness by pulling it apart.Step 3: Remove the two 13mm bolts that hold the shifter handle to the shifter base.Step 4: Remove four 8mm bolts holding down the lower shift bootStep 5: Pull out lower shift boot and its metal retaining frame. Separate metal frame from boot.These staples hold the frame and boot together, remove staples and install frame on top of new shift boot.Step 6: Reinstall new boot and install the metal frame on top. Secure with four 8mm bolts.Step 7: Reinstall shifter handle with two 13mm bolts. Note(I have a Cobra Bob shift handle gasket on mine)Step 8: Reattach cig lighter harness and reattach shift boot/ shift bezel.Step 9: Reattach shift knob. Done, enjoy your fresh new shift boot! Link to comment Share on other sites More sharing options...
reivaxtorres Posted March 13, 2013 Report Share Posted March 13, 2013 Where did you get the new boot? Mine is trash and wouldn't mind a new one Link to comment Share on other sites More sharing options...
Det_Riot Posted March 13, 2013 Report Share Posted March 13, 2013 http://www.sn95source.com/showthread.php?t=2305 Link to comment Share on other sites More sharing options...
reivaxtorres Posted March 13, 2013 Report Share Posted March 13, 2013 Haha, thank you sir Link to comment Share on other sites More sharing options...
