smallblocksn95 Posted April 21, 2013 Report Share Posted April 21, 2013 So I deleted my air pump garbage today, and have 2 questions. 1: where does the green vacuum line that goes to the egr go? And 2: where does the white vacuum line go to after leaving the passenger inner fender? I don't have Alyssa's car here to check. Thanks Link to comment Share on other sites More sharing options...
64bit_Tuning Posted April 21, 2013 Report Share Posted April 21, 2013 Link to comment Share on other sites More sharing options...
smallblocksn95 Posted April 21, 2013 Author Report Share Posted April 21, 2013 What is the large can in the picture, what color is its line, and what does the other end of its line attach to?also, can I remove the air injection bypass solenoids? Link to comment Share on other sites More sharing options...
64bit_Tuning Posted April 21, 2013 Report Share Posted April 21, 2013 You can remove all of it IIRC. You just need to make sure you don't create a vac leak at the manifold. Link to comment Share on other sites More sharing options...
smallblocksn95 Posted April 21, 2013 Author Report Share Posted April 21, 2013 Ok, these lines are driving me nuts. Link to comment Share on other sites More sharing options...
64bit_Tuning Posted April 22, 2013 Report Share Posted April 22, 2013 It's really not that complex big guy. Link to comment Share on other sites More sharing options...
smallblocksn95 Posted April 22, 2013 Author Report Share Posted April 22, 2013 Lol been a busy weekend, with little sleep Link to comment Share on other sites More sharing options...
smallblocksn95 Posted April 23, 2013 Author Report Share Posted April 23, 2013 Does the can and one way check valve have to be hooked up? Link to comment Share on other sites More sharing options...
revhead347 Posted April 23, 2013 Report Share Posted April 23, 2013 The best part is when you get rid of all that emissions rubbish, you can use those mounting studs for other things under the fender.Kurt Link to comment Share on other sites More sharing options...
smallblocksn95 Posted April 23, 2013 Author Report Share Posted April 23, 2013 this is how i have it right nowboth air pimp solenoids are still hooked up electrically, the only hose that looks ratty are the one on the CANP solenoid, car feels like its missing on acceleration. did not do this before. first vacuum set up did not either but set CEL. i can't read codes on it Link to comment Share on other sites More sharing options...
