Schiffy Posted August 30, 2013 Report Share Posted August 30, 2013 So I'm swapping rearends with one a little more built, already has gears, ect... Anyways, the car I took it out of was wrecked so we just cut the cable. question is, on my car, how do I reinstall the new one and take off with the okd rearend without killing myself? Link to comment Share on other sites More sharing options...
Blackmage Posted August 30, 2013 Report Share Posted August 30, 2013 If i remember correctly.... underneath the vehicle where the ebrake handle is, disconnect the two cables from that point, and then you should be able to have enough slack to disconnect at the caliper. reverse to put them back on. Link to comment Share on other sites More sharing options...
Duff Daddy Posted August 30, 2013 Report Share Posted August 30, 2013 Its a turn back caliper, so you can unbolt the caliper give some slack and then pop the cable off the coil spring on the caliper. Link to comment Share on other sites More sharing options...
Schiffy Posted August 30, 2013 Author Report Share Posted August 30, 2013 If i remember correctly.... underneath the vehicle where the ebrake handle is, disconnect the two cables from that point, and then you should be able to have enough slack to disconnect at the caliper. reverse to put them back on.Its a turn back caliper, so you can unbolt the caliper give some slack and then pop the cable off the coil spring on the caliper.Thanks fellas Link to comment Share on other sites More sharing options...
Slykin Posted August 30, 2013 Report Share Posted August 30, 2013 Cuss. A lot. Link to comment Share on other sites More sharing options...
Schiffy Posted August 30, 2013 Author Report Share Posted August 30, 2013 Cuss. A lot.I did that with the donor car before we both realized the body was gonna be scrapped and cut it... I won't mention the donor car is/was a '96 Mystic... The one my buddy hit a wall with, rear frame is torn and the pinch weld on the opposite side if the impact is torn. After being under it, I definitely see why they totalled it. Link to comment Share on other sites More sharing options...
