Ford Motorsports Posted January 18, 2015 Report Share Posted January 18, 2015 So I finally got the transmission put in my car and ordered a new set of ET street radial II in a 305/35/18. I have decided to hit the 1/4 mile up the first week of February. Mods are as follows:5.4 DOHC adapter plates and cobra intakeModified pacesetter headersO/r xMagnaflow side exitsJlt30# injectors4.30 gears eaton locker 31 spline mosersAdjustable upper and lowersQa1 k member sway bar removedProbably forgetting some stuff. I am hoping I can hit a 12.4. Car did a best of 12.7@109 with a crappy 1.95 60ft that was with an 01 cobra motor and a stock rear with 3.73s, with busted bushings in the Mac lowers,less longtubes, on nittos. Link to comment Share on other sites More sharing options...
Det_Riot Posted January 19, 2015 Report Share Posted January 19, 2015 You should be able to knock out a 12.4 easy if you an get it to hook better. Work that 60' down to a 1.8 and you should be there! Link to comment Share on other sites More sharing options...
