Ferocious
SN95 Bulb Identification Guide
SN95 Bulb Identification Guide:
**This is for a 1996 Mustang Gt. Bulb #'s may vary depending on the year of your car, but for the most part they will work just fine for the sn95 platform**
Location/stock bulb #
Ash tray arrow_right.png [161]
Automatic transmission indicator arrow_right.png [1816]
Back up light arrow_right.png [3156]
Brake warning arrow_right.png [194]
Check engine indicator arrow_right.png [194]
Directional signal indicator arrow_right.png [194]
Dome light arrow_right.png [562]
Dome light arrow_right.png [906]
Fog/Driving light arrow_right.png [893]
Front sidemarker arrow_right.png [3157A]
Front turn signal arrow_right.png [3157A]
Glove box arrow_right.png [194]
Headlight arrow_right.png [9007]
Hi-beam indicator arrow_right.png [194]
High mount stop light arrow_right.png [912]
Instrument-general arrow_right.png [194]
License plate arrow_right.png [168]
Map light arrow_right.png [FESTOON]
Parking light arrow_right.png [3157A]
Rear sidemarker arrow_right.png [168]
Rear turn signal arrow_right.png [3157]
Seat belt indicator arrow_right.png [194]
Step/Courtesy light arrow_right.png [194]
Step/Courtesy light arrow_right.png [74]
Stop light arrow_right.png [3157]
Tail light arrow_right.png [3157]
Trunk/Cargo area arrow_right.png [906]
Under hood light arrow_right.png [906]
[TABLE=class: grid, width: 925]
[TR]
[TD]Headlight bulb (9007):[/TD]
[TD]Fog light bulb (893):[/TD]
[TD]Dashboard bulb (T10):[/TD]
[TD]Map light bulb (Festoon Style):[/TD]
[TD]Turn signal (3157):[/TD]
[/TR]
[TR]
[TD]miLMgsu22ER4P9-HlszbjHQ.jpg[/TD]
[TD]maW7UsqplBd0hKOImgUukIA.jpg[/TD]
[TD]mAeuwo-u9X7a_lPECpFRvRA.jpg[/TD]
[TD]mTBn1Q4n3f3ZsQChczxXg0g.jpg[/TD]
[TD]mEwWCgogHJCt5Tk6-TJsY5A.jpg[/TD]
[/TR]
[/TABLE]
Edited by Ferocious
This is so helpful! Thank you!! :encouragement:
No problem Liz :)
all of the 168/194s are interchangable, idk what instruments its talking about but the whole gauge cluster takes the 194 bulbs also.
Yeah i don't know why it say's there's different bulbs. I fixed it though, thanks.
Edited by Ferocious
I know that there are LED equivalents.  Can someone post the info on that?
I just go to superbrightleds.com and enter the vehicle, then it gives you clickable links for each bulb that will take you to LED equivalents of those bulbs.
https://www.superbrightleds.com/cat/led-vehicle-replacement-bulbs/vehicle/1994-ford-mustang--/20-772--/
Perfect!
Perfect!
Keep in mind their disclaimer that physical fitment isn't guaranteed. The best bet is to compare dimensions of the new bulb to the current one and the light housing. Sometimes the bulb will plug into the harness, but is too long to fit inside the housing, etc. Takes a little double checking but definitely worth doing.
