D3vst8r96gt Posted August 15, 2012 Report Posted August 15, 2012 (edited) Anyone know or have pics of the lines One of my cel codes is for it and I need to pass emissions.... don't even know what it looks likeThe D3V Edited August 15, 2012 by D3vst8r96gt
Venom351R Posted August 16, 2012 Report Posted August 16, 2012 I know its behind your fender other then that I dont know much more about it other then it keeps a gasoline smell from omitting from the car
D3vst8r96gt Posted August 16, 2012 Author Report Posted August 16, 2012 http://www.latemodelrestoration.com/item/LRS-9653C/1996-98-Mustang-46L-38L-Motorcraft-Charcoal-Vapor-Canisterhere is a pic i guess
D3vst8r96gt Posted August 16, 2012 Author Report Posted August 16, 2012 http://www.latemodelrestoration.com/products/Mustang-Charcoal-Canisters-And-Capsrelevant parts minus the black vaccuum hose
330CubeGt Posted August 16, 2012 Report Posted August 16, 2012 Most common problem with them throwing a CEL that i have had is the Black hose going to it from the engine bay. Some have a red stripe atleast my V6 car does. They normally dry rot and break and cause the light to come on.Purge valve code?
D3vst8r96gt Posted August 16, 2012 Author Report Posted August 16, 2012 Most common problem with them throwing a CEL that i have had is the Black hose going to it from the engine bay. Some have a red stripe atleast my V6 car does. They normally dry rot and break and cause the light to come on.Purge valve code?both hoses were dry rotted .... the one going from the purge valve to the fender hasn;t been replaced cause i can't find where it ends loli cant find my livewire so i cant pull the codes
330CubeGt Posted August 26, 2012 Report Posted August 26, 2012 I just removed the entire canister/lines from my cobra the other day. All the hoses were falling apart, had a code for a purge valve... Its more trouble then its worth. I just bent over the hard line thats in the wheel well that goes to the tank Heads up and ass kickin! Using Tapatalk 2
