  • Announcements
    • Bullitt
      Current Theme Change   08/01/2017
      With the new update to 4.2 we have gained a lot of new features.  I will post more about those later.  With the change though came some problems with our current themes as the creator of those themes has not made the changes that allow us to take advantage of some of the new features.   I will try to clean up the default theme to make it more appealing for the time being.
ttocs
how much space around a sway bar is needed?
ttocs    962
I roughly installed a steeda adjustable sway bar some time ago.  I say roughly because when I was installing it I noticed it was rubbing the sides of my ford racing differential cover on the edges but didn't think it would need much clearancing and decided I would deal with that later.  Well that time is now so I trimmed away the cooling fins that were in the way so there is a hair of space around it but then it got me to thinking of how much space it would need around it while doing its job.  If your not familiar with this set up, you keep the stock sway bar in its location and add brackets to the bottom of the car and it mounts to the axle in addition to the stock sway bar and then has adjustable ends.  Its made to fit nice and tight behind the stock stamped diff cover and left not much room for any billet covers.
I thought it was a light rub and would only take 15 mins to fix but after hours now of marking the diff/dropping the bar/trimming the cover/raising the bar to repeat it all again.  I have not had to gouge out the cover but I am surprised how much I had to take off at the same time...  I took some pics but you can't really see how much space is around it now to be worth posting.  How much space do I need to leave around it to allow it to do its job?
Share this post
Link to post
Josh@RideTech    854
Depending on the bar you're using and what you're doing with the car, it could move a good amount, or it could stay fairly put.  I would think with two bars it would be stiff as hell and wouldn't move much at all...
Share this post
Link to post
Prokiller    2,086
i can't see a panhard bar in your future with that setup.  going to be right in the way.
Share this post
Link to post
410sn95    310
... or watts link.
  • Thanks 1
Share this post
Link to post
