Kyle5.0
Kyle's 95 H/C/I Build
I just started buying some parts so I decided this would be a good time to start a build thread. A little background info on the car:
95 Mustang GT
Aode to T5 swap
Current Mods:
Performance:
FRPP 3.73's
MGW Short throw
BBK o/r H
Magnflow Magnapack mufflers
BBK cai
Suspension:
MM c/c plates
MMR front coilovers w/ Lakewood 90/10 struts
MM adj. rear control arms
Lakewood 50/50 shocks
Eibach lowering springs
Plans:
Junkyard gt40 heads
gt40 intake (have)
F303 cam (purchased)
Trick Flow drop in valve springs (purchased)
Comp Cams timing chain (purchased)
255lph pump (purchased)
Delete a/c and smog
Wire tuck + paint engine bay
Goal is ~260-265hp and run low 13's or hopefully high 12's
The car:
Edited by Kyle5.0
Right on sounds like it should be a good little combo with the work you already have done. With a sticky tire and a good driver it's possible to run 12's with that setup
