smallblocksn95 Posted June 4, 2013 Report Share Posted June 4, 2013 My lightning MAF came in the other day and im trying to find the right harness to use it. most i read about are a 6pin to 4pin. My LMAF has a 4pin rectangle connector on it. CJ is down for maintenance, but as soon as theyre up again ill post a link to the one i think i need Link to comment Share on other sites More sharing options...
smallblocksn95 Posted June 4, 2013 Author Report Share Posted June 4, 2013 http://www.cjponyparts.com/mass-air-meter-adapter-harness-obdi-to-obdii-1994-1995/p/MAMA/ Link to comment Share on other sites More sharing options...
OnyxCobra Posted June 4, 2013 Report Share Posted June 4, 2013 Geez mine looks a lot less complicated than that one Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 Take a picture of youraf connector Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 My lightning MAF came in the other day and im trying to find the right harness to use it. most i read about are a 6pin to 4pin. My LMAF has a 4pin rectangle connector on it. CJ is down for maintenance, but as soon as theyre up again ill post a link to the one i think i needIf yours has a 4 pin already why do you need the connector? Link to comment Share on other sites More sharing options...
64bit_Tuning Posted June 4, 2013 Report Share Posted June 4, 2013 What's the part number on your MAF. Link to comment Share on other sites More sharing options...
smallblocksn95 Posted June 4, 2013 Author Report Share Posted June 4, 2013 Link to comment Share on other sites More sharing options...
64bit_Tuning Posted June 4, 2013 Report Share Posted June 4, 2013 :unamused:That is still a 6 pin rectangular connector. Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 What Mk said. Though there's only 4 pins its still a 6pin connector so yes what you linked is what you need Link to comment Share on other sites More sharing options...
OnyxCobra Posted June 4, 2013 Report Share Posted June 4, 2013 What Mk said. Though there's only 4 pins its still a 6pin connector so yes what you linked is what you needyou sure? One of the connectors in his link looks round, pretty sure they both need to be flat. Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 scratch that, it looked different on my phone Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 Does this look more right?http://www.pmas-maf.com/pigtails-and-adapters.php the 4 pin to oval connector? Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 http://www.jmschip.com/jms-86-93-maf-to-96-04-maf-adapter/ Link to comment Share on other sites More sharing options...
OnyxCobra Posted June 4, 2013 Report Share Posted June 4, 2013 Yeah that's more like it but a hundred bucks?! I paid like $12 for mine. Has to be cheaper somewhere else. Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 http://www.andersonfordmotorsport.com/index.php/427-1.-Adapter.htmltake your pick! lol Link to comment Share on other sites More sharing options...
OnyxCobra Posted June 4, 2013 Report Share Posted June 4, 2013 gettin there... lol Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 idk where you got yours for 12 dollars. mine came with my MAF so i lucked out lol Link to comment Share on other sites More sharing options...
SniveTroll Posted June 4, 2013 Report Share Posted June 4, 2013 you could cut the wires and solder them anew. ive had pigtails not fully connect before. Link to comment Share on other sites More sharing options...
64bit_Tuning Posted June 4, 2013 Report Share Posted June 4, 2013 The one he linked is correct. I'll post a picture with reasoning in a few... Link to comment Share on other sites More sharing options...
Det_Riot Posted June 4, 2013 Report Share Posted June 4, 2013 The one he linked is correct. I'll post a picture with reasoning in a few...Is it because that round connector is the connector that resides inside of the fenderwell? So you'd unplug your old one and plug in that one? Link to comment Share on other sites More sharing options...
64bit_Tuning Posted June 4, 2013 Report Share Posted June 4, 2013 Is it because that round connector is the connector that resides inside of the fenderwell? So you'd unplug your old one and plug in that one?Hey Hey!!! Someone is thinking now.After some deeper digging (now that im off the cellphone) the original adapter that the OP linked IS correct for a 6 pin maf with an integrated IAT. The problem is that the LMAF he linked does NOT have an integrated IAT sensor. He COULD use that harness still, but he would need to pin his stock IAT back into the connector.If you dont want to do any wiring, you can run this.http://www.ebay.com/itm/MAF-Ford-OBD-1-to-OBD-II-Gen-1-Mass-Air-Harness-Adapter-/250861138856?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a687d33a8&vxp=mtr Link to comment Share on other sites More sharing options...
OnyxCobra Posted June 4, 2013 Report Share Posted June 4, 2013 that one on eBay is what mine looks like. Link to comment Share on other sites More sharing options...
smallblocksn95 Posted June 5, 2013 Author Report Share Posted June 5, 2013 Hey Hey!!! Someone is thinking now.After some deeper digging (now that im off the cellphone) the original adapter that the OP linked IS correct for a 6 pin maf with an integrated IAT. The problem is that the LMAF he linked does NOT have an integrated IAT sensor. He COULD use that harness still, but he would need to pin his stock IAT back into the connector.If you dont want to do any wiring, you can run this.http://www.ebay.com/itm/MAF-Ford-OBD-1-to-OBD-II-Gen-1-Mass-Air-Harness-Adapter-/250861138856?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a687d33a8&vxp=mtrThat's what I was scurrilous about, I couldn't tell if they just used a stock photo or if its for integrated IATs. I'm going to have to replace part of my existing harness if I use one like Keith posted, mine has a break in one of the wires. Link to comment Share on other sites More sharing options...
64bit_Tuning Posted June 5, 2013 Report Share Posted June 5, 2013 That's what I was scurrilous about, I couldn't tell if they just used a stock photo or if its for integrated IATs. I'm going to have to replace part of my existing harness if I use one like Keith posted, mine has a break in one of the wires.It'll be easier to just buy the one you linked, and pin in your IAT.- - - Updated - - -That's what I was scurrilous about, I couldn't tell if they just used a stock photo or if its for integrated IATs. I'm going to have to replace part of my existing harness if I use one like Keith posted, mine has a break in one of the wires.It'll be easier to just buy the one you linked, and pin in your IAT. Link to comment Share on other sites More sharing options...
