Sleeperstang1994 Posted June 24, 2014 Report Share Posted June 24, 2014 SO im being lazy. i can and will do the research but i figured i would ask if anyone knew 100%. my car has a complete 98 cobra wiring harness to be installed from bumper to bumper. I recently purchased a parts car that has a 01 cobra dash and haness installed currently. i want to swap. the dash harness and cluster straight into my car. from what i can see plugs are similar. my biggest concern is the 01 uses the new style RCM(restraints control module) where the 98 uses the old style. i can swap the 98 harness into the dash if i need to. any ideas? Link to comment Share on other sites More sharing options...
ttocs Posted June 25, 2014 Report Share Posted June 25, 2014 wires are wires. You can cut them, shorten/extend/change the ends on them as needed. no reason you can't cut one end off and solder the other on. You would need a wire color code or pin-out on the hrns's to be sure they are connected correctly. Link to comment Share on other sites More sharing options...
Sleeperstang1994 Posted June 25, 2014 Author Report Share Posted June 25, 2014 I know I could make it work. I was more interested on if the 98 pcm is compatible with the later style air bag module since the one out of the 01 is newer. I guess I will just try it and see what happens Link to comment Share on other sites More sharing options...
Sleeperstang1994 Posted July 8, 2014 Author Report Share Posted July 8, 2014 if anyone stumbles upon this thread. the swap will not work. both harnesses are to different and the dash harness does not directly interface with the body harness on the 98. Link to comment Share on other sites More sharing options...
copmagnet Posted July 18, 2014 Report Share Posted July 18, 2014 I believe you need the later Pcm to use the later cluster. Link to comment Share on other sites More sharing options...
Sleeperstang1994 Posted July 19, 2014 Author Report Share Posted July 19, 2014 you are correct. i compared my harnesses side to side. not only are the connections different but the 01 uses a completly different RCM. I check with my diagrams at work (im a Ford tech) 01 has a Can bus between the RCM and PCM. 98 alows the air bag module to work independently... for the most part. I was hoping to use the later cluster, but i have all the wiring for the 98 so o well. any one want to but some 01 cobra harnesses?! Link to comment Share on other sites More sharing options...
