Black & Red Posted October 29, 2014 Report Share Posted October 29, 2014 Got this to go with Bullitt springs. Didn't like the exposed bolt in the center and thought if it really bottomed all the way, the bolt head would contact the axle housing. My solution was to use a pan head bolt and then stuff a hard rubber BMW radiator mount (bullet shaped rubber part in center of photo) into the hole in the urethane snubber. This rubber part has to be forced into place with a 13/16" socket, and will stay put. It will prevent the bolt head from ever making contact with the axle. Note that I swapped out the 3/8" bolt for a 6mm x 1.0mm button-head allen with a 3/8" sleeve. This was just some hardware I had laying on the bench and since the snubber sees compressive forces and not shearing forces, I think the fastner is up to the job at hand...FWIW Link to comment Share on other sites More sharing options...
SublimeRT Posted October 30, 2014 Report Share Posted October 30, 2014 Cool deal. Pics installed? I've meant to buy one of these for pretty much every solid axle Mustang I've owned but I always forget. Link to comment Share on other sites More sharing options...
Prokiller Posted October 30, 2014 Report Share Posted October 30, 2014 i'd be really surprised if you ever did actually bottom out with Bullitt springs. they don't lower the car much. good solution though that others can replicate Link to comment Share on other sites More sharing options...
Black & Red Posted October 31, 2014 Author Report Share Posted October 31, 2014 Prokiller: I was shocked how much (stock) pinon snubber contact I had when I switched to Bullitt springs.... Link to comment Share on other sites More sharing options...
OnyxCobra Posted November 1, 2014 Report Share Posted November 1, 2014 I don't think I've ever hit my H&R pinion snubber, maybe the rear bullitt springs are on the soft side. Link to comment Share on other sites More sharing options...
Black & Red Posted November 4, 2014 Author Report Share Posted November 4, 2014 Maybe...I know the Bullitts are linear...sure rides nice now!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Black & Red Posted November 12, 2014 Author Report Share Posted November 12, 2014 This snubber is Da Bomb.... Link to comment Share on other sites More sharing options...
