Det_Riot Posted April 27, 2015 Report Share Posted April 27, 2015 Trying to order everything I need ahead of time for the new motor set up.It has a 7qt moroso oil pan on it without a dipstick, as well as a relocated oil filter.Couple of questions1) What dipstick kit is used for these pans? Just the generic Moroso stick?2) Everything I've read argues whether or not with a 7qt pan you should be running 7 or 8 quarts. 7 all together or 7+1 for valley/filter/etc3) Does the relocated oil filter kit change the capacity of the system or is it negligible? Link to comment Share on other sites More sharing options...
Sho Amo Posted April 28, 2015 Report Share Posted April 28, 2015 Depending on length of line and such, Ive seen as much as 2 quarts extra needed for an oil filter relocation. Link to comment Share on other sites More sharing options...
Det_Riot Posted April 28, 2015 Author Report Share Posted April 28, 2015 Sounds like I should just calculate volume of the lines on the kit and base it off of that. Link to comment Share on other sites More sharing options...
64bit_Tuning Posted April 28, 2015 Report Share Posted April 28, 2015 there is a super simple answer to this. use your stock dipstick and fill until its full. Your initial fill will require more oil than subsequent oil changes. Link to comment Share on other sites More sharing options...
