kucklehead
Cobra irs
99/01 IRS uses the same size pinion flange as the SRA's. The 03/04's use the bigger flange. Your SRA drive shaft might need to be shortened about an inch.
Edited by 01yellercobra
You can just unscrew the sensors from the center section. Don't throw them away though. I've heard Ford wants an arm and a leg for them now.
FWIW, I ran a foxbody aluminum driveshaft when I had the 3650 in the car. It was a tight fit. In order to get it in I had to wiggle the pinion flange on the driveshaft around the pinion nut on the rear end. If the SN95 drive shaft is any longer then the foxbody drive shaft it'll have to be shortened.
Springs are completely different. I have a set of rears if you need them. The shocks will work, but IRS shocks and SRA are valved differently. So I would plan on new shocks at some point.
Easy as long as you have the right tools. I used an angle grinder with a cut off wheel. As for reliability, I've had the same cut springs under my car for over 6 years.
Jesus Christ I cant even be here one day w/ out avoiding you WTF
When I had my whole sig written out it said ERROR Only 3 lines are allowed
Duff <3 Penis :)
Basically. You need like 10 posts to even view it
