MMR Posted July 2, 2013 Report Share Posted July 2, 2013 Okay, so since starting my car up for the first time since febuary, my Airbag light started flashing. I have checked all the fuses and they are fine, according to the cars maunal; when it flashes it means theres a problem with the aribag system...hmm - okay; so after searching alittle around; the cars airbag system consists of driver and passenger airbags, a airbag control module and impact sensors in the front bumper. Since I know ABSOLUTELY nothing about airbag systems, can any of you guys point me in a direction or help me figure out how to fix this? Link to comment Share on other sites More sharing options...
Tony Posted July 2, 2013 Report Share Posted July 2, 2013 hmmmm, try scott (ttocs) he is an electrical genius. maybe pm dude- - - Updated - - -and lol @ attention whore Link to comment Share on other sites More sharing options...
Blackmage Posted July 2, 2013 Report Share Posted July 2, 2013 the amount of blinks should give you a code that you can start tracing back to the main issue. i think these codes are the same for your car..http://www.veryuseful.com/mustang/tech/airBag/airBag95.html Link to comment Share on other sites More sharing options...
MMR Posted July 2, 2013 Author Report Share Posted July 2, 2013 the amount of blinks should give you a code that you can start tracing back to the main issue. i think these codes are the same for your car..http://www.veryuseful.com/mustang/tech/airBag/airBag95.htmlIf flashes 5 times then 2 times, then pause, then 5 times then 2 times and so on..- - - Updated - - -So according to the link you posted, I guess it means code 52? .."Intermittent or Repaired Lost Battery Feed" ..what does that mean in english?- - - Updated - - -hmmmm, try scott (ttocs) he is an electrical genius. maybe pm dude- - - Updated - - -and lol @ attention whore PMéd Link to comment Share on other sites More sharing options...
ttocs Posted July 2, 2013 Report Share Posted July 2, 2013 Not sure what too say here. Start simple and check all the grounds as you should with any electrical gremlin. Link to comment Share on other sites More sharing options...
Schiffy Posted July 2, 2013 Report Share Posted July 2, 2013 Pull the light bulb out, and it'll stop flashing. Problem solved! lmaoTapatalk made me do it! Link to comment Share on other sites More sharing options...
Blackmage Posted July 2, 2013 Report Share Posted July 2, 2013 im pretty sure if you pull the bulb, the actual Air bag module will start beeping instead. Link to comment Share on other sites More sharing options...
MMR Posted July 2, 2013 Author Report Share Posted July 2, 2013 Okay, I figured it out thanks to the link you send, thank you a million times for that - - - Updated - - -This is how you do it, if it happens to you Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time. 4. Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK). 5. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously. 6. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds). Link to comment Share on other sites More sharing options...
ttocs Posted July 2, 2013 Report Share Posted July 2, 2013 what was it? Link to comment Share on other sites More sharing options...
MMR Posted July 2, 2013 Author Report Share Posted July 2, 2013 Airbag clear code connector location: - - - Updated - - -How to short it: Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted July 2, 2013 Moderators Report Share Posted July 2, 2013 Gonna have to try this on my car. I just deal with the lights since my ABS light won't go off either. Link to comment Share on other sites More sharing options...
Blackmage Posted July 2, 2013 Report Share Posted July 2, 2013 what caused it to start flashing though... Link to comment Share on other sites More sharing options...
MMR Posted July 2, 2013 Author Report Share Posted July 2, 2013 (edited) Gonna have to try this on my car. I just deal with the lights since my ABS light won't go off either.It is a little grey connector located under the glove compartment.what caused it to start flashing though...My battery was discharged when I first tried to start the car. Edited July 2, 2013 by MMR Link to comment Share on other sites More sharing options...
SniveTroll Posted July 2, 2013 Report Share Posted July 2, 2013 Delete airbag system and abs. Great ideas. I like it.Sent by smoke signals Link to comment Share on other sites More sharing options...
ttocs Posted July 2, 2013 Report Share Posted July 2, 2013 done that lots of times and never got that err. Link to comment Share on other sites More sharing options...
MMR Posted July 2, 2013 Author Report Share Posted July 2, 2013 done that lots of times and never got that err.That is because I am not as cool as you are Scott Link to comment Share on other sites More sharing options...
kucklehead Posted July 2, 2013 Report Share Posted July 2, 2013 Mine stays on......But thats because I removed my airbags after they deployed last AugustBrought to you by Pornhub Link to comment Share on other sites More sharing options...
MMR Posted July 3, 2013 Author Report Share Posted July 3, 2013 I am on my old phone while I am in Denmark, so excuse the shitty picture quallity. But it is this connector that you have to short, it is located under the glove compartment, you do not have to take the glovecompartment apart or anything. Link to comment Share on other sites More sharing options...
