Sho Amo
Can you use an 03/04 steering shaft in an sn95?
My 94 cobra has some serious steering issues and I'll be diving into diagnosis tomorrow but I wanted to ask if an 03/04 cobra steering shaft fits in a 94/95? I'm betting my slop is coming from the rag joint but I'll know for certain tomorrow. And YES I know there has been lots of threads on the topic which I found by the search but nothing to answer this question. I'm guessing the answer will be a yes since MM sells the same shaft for 94-04 but just want to be certain!
TIA
as far as i know all 94-04 steering shafts are the same. If i am incorrect someone please correct me. The rack in 03/04 is different, however this does not mean there is any difference in the steering shaft.
I'm pretty sure it's the same. I have an 03 column in my car and it's a 96. So I'd have to assume everything does work together
Sent from my iPhablet
Yes, I have one in my car. 03/04 rack and shaft @Sho Amo
Before you buy the shaft, I'd check to see where the slop is at. Have someone rock the wheel back and forth to see if the slop is in the rag joint or in the rack itself
