ttocs
fuel line parts
The only thing you need from them is the hardline adapters, the rest you will have to figure out once you decide on how your going to route the lines. Some peeps do duel feeds and returns, some feed one rail ect ect. First decide on how your going to set it up then buy your hose and fittings according to your set up.
If you're just converting the lines under the hood to stainless, here are the part numbers for the fittings (you'll need hose too obviously)
Blue package
• 5/16 to 6AN hard tube adapter - 640860 - $14.00
• 1/4 to 6AN hard tube adapter - 641300 - $11.98
• Ford Pressure Side EFI x 6 AN - 640900 - $16.44
• Ford Return Side EFI x 6 AN - 640870 - $13.44
Black package
• 5/16 to 6AN hard tube adapter - 640863 $14.36
• 1/4 to 6AN hard tube adapter - 641303 $13.35
• Ford Pressure Side EFI x 6 AN - 640903 $17.40
• Ford Return Side EFI x 6 AN - 640873 $14.40
* Prices may have changed since those part numbers were posted.
If your stock fuel lines need replaced there is, Ford discontinued them and they aren't available anywhere. I searched high and low for them for over a month, then just did the braided lines because I didn't have any other choice.
Also, there have been many accounts of the stock lines starting fires, so that's another thing to keep in mind.
http://forums.corral.net/forums/94-95-tech/897629-94-95-mustang-5-0-gas-fuel-lines-fire-hazard-issues.html
