  • Announcements
    • Bullitt
      Current Theme Change   08/01/2017
      With the new update to 4.2 we have gained a lot of new features.  I will post more about those later.  With the change though came some problems with our current themes as the creator of those themes has not made the changes that allow us to take advantage of some of the new features.   I will try to clean up the default theme to make it more appealing for the time being.
Sign in to follow this
White95
Engine coolant system question
White95    203
Does anyone know if there's way to use the older style radiators with a 4V?  Ever since I came across this picture, I've been determined to replicate it. I know this is a classic Mustang but my 95 ain't getting no younger :lol:
This way I can keep my radiator I bought from @GearGambler and it'll clean up the engine bay some. Any one have any thoughts, concerns?
Quote
The main purpose of the tank is to provide some air space so when the coolant expands it can compress the air instead of running out on the ground. You want the overflow tank higher than the crossover (or even with it) so the air goes in the tank, not in your heads. It's hard to tell from this pic, but the top of the Moroso tank is about 3" higher than the crossover and it runs about 1/2 full.
The cap on the radiator has been cut so it holds no pressure. The overflow from the radiator flows to the degas tank (to a fitting on the back/left side) and down into the thermostat housing through the bottom of the tank, just like the factory setup
Share this post
Link to post
White95    203
Oh, I've got this... Small expansion tank a little higher than the coolant crossover, use the oem hoses with my existing radiator.
Share this post
Link to post
Shifty    92
On 6/22/2017 at 11:28 AM, droptoppony said:
You answered your own question?
HAHAHAHAHA This is great!!! :lolsmiley:
@White95 good job bud!
Share this post
Link to post
White95    203
Thank yew.. Thank yew..
I do think it will work for me!
Share this post
Link to post
White95    203
Fuhgeddaboutit
Share this post
Link to post
White95    203
On 7/28/2017 at 2:18 PM, GearGambler said:
you ever get it finished?
No BUT I'm closer than yesterday!
Share this post
Link to post
