330CubeGt Posted August 15, 2012 Report Share Posted August 15, 2012 New DynoTune Air/Fuel Ratio Lean Shut-Down SwitchFeatures: --Microprocessor contolled --Built in Air/ fuel ratio display(narrow and wideband) --Built in TPS (WOT) Switch --Peak and Min A/F memory during the run --Multiple outputs 12V and Ground --Multiple Trigger input options 12V/Ground/TPS--Programable trip points --Adjustable delay to let lean spikes settle --6 Foot wire harness --Light Weight --12 Volt Operation --Fast response --Super Low Current Draw --Micro Package Mounts Anywhere 1.8" W x 2.4" H x .9" D --Fast response --Super Low Current Draw --Micro Package Mounts Anywhere 1.8" W x 2.4" H x .9" D Link to comment Share on other sites More sharing options...
Musturd Posted August 15, 2012 Report Share Posted August 15, 2012 This things pretty cool Link to comment Share on other sites More sharing options...
copmagnet Posted August 16, 2012 Report Share Posted August 16, 2012 looks just like my window switch. I wonder how it works? does this replace the window switch in a nitrous set-up? shut the car off if it goes to lean? what? Link to comment Share on other sites More sharing options...
330CubeGt Posted August 16, 2012 Author Report Share Posted August 16, 2012 I think you can run the window switch as well, I think this just kills the power to the kit if it goes lean. Guess you could run either or. Or run them both, would be alot of wires to mess with but seems like a nice saftey feature...Heads up and ass kickin! Using Tapatalk 2 Link to comment Share on other sites More sharing options...
ttocs Posted August 16, 2012 Report Share Posted August 16, 2012 how much is it $$$ and how does it shut down the power. Link to comment Share on other sites More sharing options...
330CubeGt Posted August 16, 2012 Author Report Share Posted August 16, 2012 how much is it $$$ and how does it shut down the power.Think there like $135 ish, and the nitrous kits main power probably runs through it after being wired into to O2 if it goes lean it will cut power to the kit... Im not 100%on how it works as im still reading about it aswell Heads up and ass kickin! Using Tapatalk 2 Link to comment Share on other sites More sharing options...
ttocs Posted August 16, 2012 Report Share Posted August 16, 2012 ok so it shuts down the nitrous that makes more sence. Probably just as a wire that connects to a relay to turn off the main power for it when it needs too. Link to comment Share on other sites More sharing options...
Knuckles Posted August 16, 2012 Report Share Posted August 16, 2012 this switch and an window switch would have zero problems being compatible as they do different things. also having more safety switches in your kit is not a bad thing at all. this kit seems like it would be better used on a more race oriented car as most street cars with a small shot dont require a tune and even if you do tune it considering the tune would be for a street car it would likely be fairly safe and fat. if you have the option of getting multiple tunes wether it be a flip chip or a handheld and you can set up a "racing" tune in which you would use race fuel and run it to max capacity with timing and a/f then sure this would be re assurance as weather is obviously always changing and affecting your tune.Knuckles Link to comment Share on other sites More sharing options...
ttocs Posted August 16, 2012 Report Share Posted August 16, 2012 I noteced that my fuel pressure sensor I installed has two pins and one is labeled that it is to drive either a buzzer or light ot warn me if pressure is low. Wonder if I could use that with No2? Link to comment Share on other sites More sharing options...
