Det_Riot Posted October 8, 2012 Report Share Posted October 8, 2012 Well it's again for October ROTM!!! As with the previous month: Voting will run for one week.This is where everyone needs to pay attention because it is easy for you to become confused. Everyone who votes will be posting scores for ALL OF THE CARS instead of casting a vote for one car. That is right, no more polls to look at.So lets run though this is an example:The top 4 cars nominated in this month are the following:Prokiller CompOrangeSN95 OnyxCobra Kyle5.0Each person voting would give each person a score on Interior of the car, Exterior of the car, and Performance Mods.Scores are given on a 1-10 scale, 10 being the highest.So a possible ballet would look like this:Interior/Exterior/PerformanceProkiller: 8/8/7CompOrangeSN95: 8/7/10OnyxCobra: 8/10/6Kyle5.0: 8/9/7 Link to comment Share on other sites More sharing options...
Det_Riot Posted October 8, 2012 Author Report Share Posted October 8, 2012 CompOrangeSN95don't mind my dirty wheels, this was right after unloading the car after a weekend at the trackand a little video 1994 Mustang GTSuspension Hotchkis upper and lower control arms steeda sport springs kyb shocks/struts custom aluminum sway bar bushing/mounts 14" Brembo brakes (front) '08 GT500 Wheels w/ G-force R1 slicks caster/camber plates full sub-frame conectorsMotorford explorer motor w/ carb conversion performer rpm intake/holley 650 carb BBK long tube headers custom side exhaustInterior gutted interior w/ Kirkey Series 47 seats 5 point harnesses custom gauge cluster 6-point cage Steeda wing Link to comment Share on other sites More sharing options...
Det_Riot Posted October 8, 2012 Author Report Share Posted October 8, 2012 Kyle5.0About to go under construction but older picPerformance:AODE to T5 SwapFRPP 3.73'sMGW Short throwBBK o/r HMagnflow Magnapack mufflersBBK caiSuspension:MM c/c platesMMR front coilovers w/ Lakewood 90/10 strutsMM adj. rear control armsLakewood 50/50 shocksEibach lowering springs Link to comment Share on other sites More sharing options...
Det_Riot Posted October 8, 2012 Author Report Share Posted October 8, 2012 (edited) OnyxCobranot quite up to date engine pic:Mods:Engine/Drivetrain:2.2L Kenne Bell Blowzilla/Flowzilla Supercharger 9psiAFR 165cc Cylinder HeadsSteeda #19 CamshaftCrane/Cobra 1.7 Roller RockersTrick Flow Chromemoly 6.25" PushrodsProfessional Products 70mm TB90mm Lightning MAFFRPP 42lb InjectorsMelling High Volume Oil PumpStant 180° T-statFRPP 9mm Plug Wires1" GT40 Phenolic SpacerWalbro 255lph Fuel PumpMac 1 3/4" Longtube HeadersMac offroad ProChamberBorla Stinger CatbackSmog/EGR DeleteSpec Stage 2 Clutch3.55 GearsFRPP 31 Spline DiffMoser 31 Spline AxlesSCT+4 Comp ChipSuspension:Maximum Motorsports K-MemberMaximum Motorsports A-ArmsMaximum Motorsports Coilover KitMaximum Motorsports Bumpsteer Kit (bolt through)Maximum Motorsports Caster/Camber PlatesTokico Illumina Struts/ShocksMaximum Motorsports Adjustable Rear Lower Control ArmsH&R SuperSport Rear SpringsKenny Brown Subframe ConnectorsExterior:Cobra R hoodSmoked headlightsHypercoated Saleen Wheels 18x9/10265/35-18 BFGoodrich KDW295/35-18 BFGoodrich Drag RadialsShorty AntennaCobra Grill EmblemSmoked Bumper Reflectors/3rd Brake Light96-98 Tail Lights with SequencersWindshield Wiper DeleteRedline Tuning Hood Struts6000K HID Headlights and FogsFog Light RewireLED Corner Lights and License Plate BulbsInterior:Custom Suede HeadlinerMGW Headlight and HVAC KnobsChrome Gauge RingsFR500 Steering WheelCobra PedalsLED Gauges, HVAC, Dome, Map and Glove Box Lights Edited October 8, 2012 by Det_Riot Link to comment Share on other sites More sharing options...
Det_Riot Posted October 8, 2012 Author Report Share Posted October 8, 2012 ProkillerOld interior pic but not much has changed so its good enoughEngine: -D.S.S. Super Pro Bullet 331 Stroker block with Series 20 upgrade -Forged D.S.S. Pro-Lite Pistons -Forged D.S.S. H-beam rods -Cast Stroker Crank -Felpro MLS head gaskets -D.S.S. Windage Tray -D.S.S. Main Support Girdle -D.S.S. 7qt. Oil pan with FMS High Volume Oil Pump -Vortech S-trim SQ-V2 (2.95" pulley) -AFM Power Pipe -AFR Competition 185 58cc heads-Trick Flow Stud Mount 1.72 Roller Rockers -Moroso fabricated aluminum valve covers w/ JIC fittings for breather-Moroso breather tank w/ JIC fittings/lines-AFM B-21 Cam (218/226 .542/.542 w/1.7 rocker 272/280 112 108)-FRPP lifters-Edelbrock Performer RPM intake -1" phenolic intake spacer-Stack Racing Polished 70mm Throttle Body -Pro-M 80MM mass air w/ attached filter -42lb FRPP Injectors -Aeromotive Fuel Pressure Regulator -PA Performance 130-amp Alternator-BBK 1 5/8" ceramic coated long tube headers w/ Stage 8 locking header bolts -Dr. Gas 2 1/2" x-pipe -DynoMax race bullet mufflers-Borla duul slant cut round intercooled exhaust tips for side exhaust-255lph intank fuel pump -T-Rex inline fuel pump -MSD Pro-Billet Distributor -MSD coil w/ Ford Motorsports 8mm wires -MSD 6A Ignition system mounted in glove box -Fluidyne Aluminum Radiator -Manual Fan switch -AFM PMS w/ boost controller -Billet Smog Pump Delete-EGR Deleted -A/C Deleted Drivetrain: -Tremec 3550 upgraded with 26-spline input shaft and larger output shaft -Mcleod clutch -Fidanza steel flywheel -Maximum Motorsports Clutch Cable-Steeda Double Clutch Quadrant -AM Firewall Adjuster -Pro 5.0 shifter -Ford Motorsports Aluminum Driveshaft -FRPP Driveshaft Safety Loop Rear End: -Ford Motorsports 3.73 gears -Moser 28-spline axles -Trick Flow Rear Stud Girdle Suspension: -Ford Racing Lowering Springs (I think C's) -KYB Rear Shocks -Cross Drilled and Slotted Rotors -Steeda Aluminum Lower Control Arms -Steeda Adjustable Upper Control Arms -Maximum Motorsports 4-bolt Caster/Camber Plates -BBK Strut Tower Brace-Kenny Brown full length welded in subframe connectors-2003 Cobra Rack (SPR-ZM) Exterior: -Black with blue pearl, ghost blue pearl dual stripes-Cobra R Hood w/ Hood Pins-ABC Exclusives GTR front bumper smoothed on the sides-Roush Side exhaust side skirts-Saleen T1 race spoiler-Export horizontal tail lights-Black Bullit fuel door-Ultra Clear Headlights-Ultra Clear Side Markers -Clear Rear Reflectors -18 x 9 FR500 Hypercoated front wheels-265/35-18 Nitto NT555 Extreme front tires-18 x 10 FR500 Hypercoated rear wheels-305/35-18 Nitto NT555R drag radials-Window Tint -Painted Red Calipers w/ Pony Stickers -Silver Bumper Inserts -Painted Mirrors Interior: -White Face Gauges w/ LED light mod and red needles-Sinus Industries Gauge Ring Bezel-White HVAC panel w/ LED light mod-LED Reverse lights-LED dome lights-LED license plate lights-Autometer 2 gauge pillar pod-Autometer 2 gauge cluster pod -Autometer 2 gauge clock pod converted for wideband-Autometer C2 Boost, Water Temperature, Oil Pressure, Fuel Pressure gauges -Autometer C2 Tachometer w/ UPR Tach Bracket -AFM Uego 2000 wideband sensor (partially installed. Still have to hook up to Tach/PMS)-Bullet interior pieces-AFM Billet Ash Tray Switch Link to comment Share on other sites More sharing options...
MMR Posted October 8, 2012 Report Share Posted October 8, 2012 Almost impossible to choose between...they are all awesome cars Link to comment Share on other sites More sharing options...
Det_Riot Posted October 8, 2012 Author Report Share Posted October 8, 2012 you dont choose brah, you judge! So a possible ballet would look like this:Interior/Exterior/PerformanceProkiller: 8/8/7CompOrangeSN95: 8/7/10OnyxCobra: 8/10/6Kyle5.0: 8/9/7 Link to comment Share on other sites More sharing options...
Ferocious Posted October 8, 2012 Report Share Posted October 8, 2012 [TABLE=class: grid][TR][TD]Car[/TD][TD]Interior[/TD][TD]Exterior[/TD][TD]Performance[/TD][/TR][TR][TD]CompOrangeSN95[/TD][TD]9[/TD][TD]7[/TD][TD]8[/TD][/TR][TR][TD]Kyle5.0[/TD][TD]6[/TD][TD]7[/TD][TD]6[/TD][/TR][TR][TD]OnyxCobra[/TD][TD]7[/TD][TD]8[/TD][TD]8[/TD][/TR][TR][TD]Prokiller[/TD][TD]8[/TD][TD]9[/TD][TD]9[/TD][/TR][/TABLE] Link to comment Share on other sites More sharing options...
MMR Posted October 8, 2012 Report Share Posted October 8, 2012 you dont choose brah, you judge! So a possible ballet would look like this:Interior/Exterior/PerformanceProkiller: 8/8/7CompOrangeSN95: 8/7/10OnyxCobra: 8/10/6Kyle5.0: 8/9/7Yes sir..[TABLE=class: grid, width: 500][TR][TD]Car[/TD][TD]Interior[/TD][TD]Exterior[/TD][TD]Performance[/TD][/TR][TR][TD]Prokiller[/TD][TD]9[/TD][TD]8[/TD][TD]10[/TD][/TR][TR][TD]CompOrangeSN95[/TD][TD]7[/TD][TD]10[/TD][TD]8[/TD][/TR][TR][TD]OnyxCobra[/TD][TD]7[/TD][TD]10[/TD][TD]10[/TD][/TR][TR][TD]Kyle5.0[/TD][TD]7[/TD][TD]10[/TD][TD]8[/TD][/TR][/TABLE] Link to comment Share on other sites More sharing options...
Bullitt Posted October 8, 2012 Report Share Posted October 8, 2012 I will hit this up later after I get settled back in. Just got back into town this afternoon. Good luck to all. Link to comment Share on other sites More sharing options...
Knuckles Posted October 8, 2012 Report Share Posted October 8, 2012 prokiller:6/9/7comporangesn95:5/8/9 onyxcobra:6/7/7kyle5.0:5/7/5 Link to comment Share on other sites More sharing options...
iRoush Posted October 8, 2012 Report Share Posted October 8, 2012 prokiller: 8/9/9comporangesn95: 8/8/8 onyxcobra: 8/8/9kyle5.0: 6/7/6 Link to comment Share on other sites More sharing options...
the.greg Posted October 8, 2012 Report Share Posted October 8, 2012 Prokiller: 8/8/9CompOrangeSN95: 5/7/8OnyxCobra: 7/9/8Kyle5.0: 5/9/5 Link to comment Share on other sites More sharing options...
95riosnake Posted October 9, 2012 Report Share Posted October 9, 2012 [TABLE=class: grid][TR][TD]Car[/TD][TD]Interior[/TD][TD]Exterior[/TD][TD]Performance[/TD][/TR][TR][TD]CompOrangeSN95[/TD][TD]5[/TD][TD]7[/TD][TD]8[/TD][/TR][TR][TD]Kyle5.0[/TD][TD]6[/TD][TD]8[/TD][TD]5[/TD][/TR][TR][TD]OnyxCobra[/TD][TD]8[/TD][TD]8[/TD][TD]8[/TD][/TR][TR][TD]Prokiller[/TD][TD]8[/TD][TD]9[/TD][TD]9[/TD][/TR][/TABLE] Link to comment Share on other sites More sharing options...
Bullitt Posted October 9, 2012 Report Share Posted October 9, 2012 [TABLE=class: grid][TR][TD]Car[/TD][TD]Interior[/TD][TD]Exterior[/TD][TD]Performance[/TD][/TR][TR][TD]CompOrangeSN95[/TD][TD]4[/TD][TD]9[/TD][TD]8[/TD][/TR][TR][TD]Kyle5.0[/TD][TD]8[/TD][TD]9[/TD][TD]5[/TD][/TR][TR][TD]OnyxCobra[/TD][TD]8[/TD][TD]9[/TD][TD]8[/TD][/TR][TR][TD]Prokiller[/TD][TD]9[/TD][TD]9[/TD][TD]9[/TD][/TR][/TABLE] Link to comment Share on other sites More sharing options...
Prokiller Posted October 9, 2012 Report Share Posted October 9, 2012 what's the rules for people in the running? should i not vote this month? only vote for the other guys? Link to comment Share on other sites More sharing options...
Slykin Posted October 9, 2012 Report Share Posted October 9, 2012 [TABLE=class: cms_table_grid][TR][TD]Car[/TD][TD]Interior[/TD][TD]Exterior[/TD][TD]Performance[/TD][/TR][TR][TD]CompOrangeSN95[/TD][TD]5[/TD][TD]7[/TD][TD]7[/TD][/TR][TR][TD]Kyle5.0[/TD][TD]7[/TD][TD]9[/TD][TD]6[/TD][/TR][TR][TD]OnyxCobra[/TD][TD]8[/TD][TD]9[/TD][TD]9[/TD][/TR][TR][TD]Prokiller[/TD][TD]7[/TD][TD]8[/TD][TD]9[/TD][/TR][/TABLE] Link to comment Share on other sites More sharing options...
Det_Riot Posted October 10, 2012 Author Report Share Posted October 10, 2012 erhmmm just give yourself an honest assessment? I know I'd probably be harder on myself than on others so yah I guess just put in votes for yourself too haha Link to comment Share on other sites More sharing options...
OnyxCobra Posted October 10, 2012 Report Share Posted October 10, 2012 Well assuming we build our cars to our own taste, why wouldn't we give our own cars the highest ratings? Link to comment Share on other sites More sharing options...
iRoush Posted October 10, 2012 Report Share Posted October 10, 2012 i say the people who are involved cannot vote. defeats the purpose IMO. Link to comment Share on other sites More sharing options...
Det_Riot Posted October 10, 2012 Author Report Share Posted October 10, 2012 Okay fair enough. Don't vote if you're in the running. Link to comment Share on other sites More sharing options...
MMR Posted October 10, 2012 Report Share Posted October 10, 2012 i say the people who are involved cannot vote. defeats the purpose IMO.Agreed^^ Link to comment Share on other sites More sharing options...
dutch Posted October 10, 2012 Report Share Posted October 10, 2012 Prokiller: 7/8/10CompOrangeSN95: 6/8/8OnyxCobra: 10/10/10Kyle5.0: 8/10/6 Link to comment Share on other sites More sharing options...
JoshHooten Posted October 10, 2012 Report Share Posted October 10, 2012 Prokiller 8/9/10comp o 7/7/9onyx 8/8/10 kyle 9/9/7 Link to comment Share on other sites More sharing options...
Steve-Oh Posted October 11, 2012 Report Share Posted October 11, 2012 [TABLE=class: grid][TR][TD]User[/TD][TD]Interior[/TD][TD]Exterior[/TD][TD]Performance[/TD][/TR][TR][TD]CompOrangeSN95[/TD][TD]6[/TD][TD]8[/TD][TD]9[/TD][/TR][TR][TD]Kyle5.0[/TD][TD]7[/TD][TD]8[/TD][TD]4[/TD][/TR][TR][TD]OnyxCobra[/TD][TD]7[/TD][TD]9[/TD][TD]9[/TD][/TR][TR][TD]Prokiller[/TD][TD]7[/TD][TD]8[/TD][TD]9[/TD][/TR][/TABLE] Link to comment Share on other sites More sharing options...
Det_Riot Posted October 14, 2012 Author Report Share Posted October 14, 2012 To the top! Last day to vote!!! Link to comment Share on other sites More sharing options...
