Det_Riot
October ROTM Winner - ProKiller!
After another close month of voting we have our winner! Congrats Ryan, another well deserved kid!
Prokiller
Old interior pic but not much has changed so its good enough
Engine:
-D.S.S. Super Pro Bullet 331 Stroker block with Series 20 upgrade
-Forged D.S.S. Pro-Lite Pistons
-Forged D.S.S. H-beam rods
-Cast Stroker Crank
-Felpro MLS head gaskets
-D.S.S. Windage Tray
-D.S.S. Main Support Girdle
-D.S.S. 7qt. Oil pan with FMS High Volume Oil Pump
-Vortech S-trim SQ-V2 (2.95" pulley)
-AFM Power Pipe
-AFR Competition 185 58cc heads
-Trick Flow Stud Mount 1.72 Roller Rockers
-Moroso fabricated aluminum valve covers w/ JIC fittings for breather
-Moroso breather tank w/ JIC fittings/lines
-AFM B-21 Cam (218/226 .542/.542 w/1.7 rocker 272/280 112 108)
-FRPP lifters
-Edelbrock Performer RPM intake
-1" phenolic intake spacer
-Stack Racing Polished 70mm Throttle Body
-Pro-M 80MM mass air w/ attached filter
-42lb FRPP Injectors
-Aeromotive Fuel Pressure Regulator
-PA Performance 130-amp Alternator
-BBK 1 5/8" ceramic coated long tube headers w/ Stage 8 locking header bolts
-Dr. Gas 2 1/2" x-pipe
-DynoMax race bullet mufflers
-Borla duul slant cut round intercooled exhaust tips for side exhaust
-255lph intank fuel pump
-T-Rex inline fuel pump
-MSD Pro-Billet Distributor
-MSD coil w/ Ford Motorsports 8mm wires
-MSD 6A Ignition system mounted in glove box
-Fluidyne Aluminum Radiator
-Manual Fan switch
-AFM PMS w/ boost controller
-Billet Smog Pump Delete
-EGR Deleted -A/C Deleted
Drivetrain:
-Tremec 3550 upgraded with 26-spline input shaft and larger output shaft
-Mcleod clutch
-Fidanza steel flywheel
-Maximum Motorsports Clutch Cable
-Steeda Double Clutch Quadrant
-AM Firewall Adjuster
-Pro 5.0 shifter
-Ford Motorsports Aluminum Driveshaft
-FRPP Driveshaft Safety Loop
Rear End:
-Ford Motorsports 3.73 gears
-Moser 28-spline axles
-Trick Flow Rear Stud Girdle
Suspension:
-Ford Racing Lowering Springs (I think C's)
-KYB Rear Shocks
-Cross Drilled and Slotted Rotors
-Steeda Aluminum Lower Control Arms
-Steeda Adjustable Upper Control Arms
-Maximum Motorsports 4-bolt Caster/Camber Plates
-BBK Strut Tower Brace-Kenny Brown full length welded in subframe connectors
-2003 Cobra Rack (SPR-ZM)
Exterior:
-Black with blue pearl, ghost blue pearl dual stripes
-Cobra R Hood w/ Hood Pins
-ABC Exclusives GTR front bumper smoothed on the sides
-Roush Side exhaust side skirts
-Saleen T1 race spoiler
-Export horizontal tail lights
-Black Bullit fuel door
-Ultra Clear Headlights
-Ultra Clear Side Markers
-Clear Rear Reflectors
-18 x 9 FR500 Hypercoated front wheels
-265/35-18 Nitto NT555 Extreme front tires
-18 x 10 FR500 Hypercoated rear wheels
-305/35-18 Nitto NT555R drag radials
-Window Tint
-Painted Red Calipers w/ Pony Stickers
-Silver Bumper Inserts
-Painted Mirrors
Interior:
-White Face Gauges w/ LED light mod and red needles
-Sinus Industries Gauge Ring Bezel
-White HVAC panel w/ LED light mod
-LED Reverse lights
-LED dome lights
-LED license plate lights
-Autometer 2 gauge pillar pod
-Autometer 2 gauge cluster pod
-Autometer 2 gauge clock pod converted for wideband
-Autometer C2 Boost, Water Temperature, Oil Pressure, Fuel Pressure gauges
-Autometer C2 Tachometer w/ UPR Tach Bracket
-AFM Uego 2000 wideband sensor (partially installed. Still have to hook up to Tach/PMS)
-Bullet interior pieces
-AFM Billet Ash Tray Switch
BBBBBBOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
lol, congrats dude! ya already know i love your ride! one of my fav's
