SneakySonBeach
lowering spring noob help
so i am going to try and install a set of lowering springs on my 97 gt. i need schooled on the front end. i know to remove the caliper and sensor. the tie rod and sway bar. how sturdy is the cotter pin in the tie rod? will i need to buy new ones or can they be re-used? and then the strut bolts will drop the control arm and lower the jack. did i miss anything? and when they say pry the spring in, pry it how and where?
You pretty much have it covered. Depending on how many times the pins been taken out will cause it to fatigue and break. They are cheap and readily available so if you want piece of mind then get new ones.
When you lower the control arm down with the jack it should release all the tension in the spring, make sure there's no tension before you go messing with the spring. With the way the arm swings, the back part of the spring will still be seated in the perch some so a little bit of prying with a bar or good old strength will free it.
I think I got it all.
Sent from Space
I never bothered removing the tie rods from the spindle. I always just hang the caliper out of the way, remove the rotor, remove the speed sensor, unhook the sway bar from the control arms, put a jack under the lca, remove strut bolts/nuts at the tower, lower the control arm, compress the strut and tilt it out, push down on the control arm with my foot and pop the spring out. Once you get in there and start working on it you'll see it's not so bad.
What everyone else said. Not sure how safety minded you are but if you want to be safe their a chain around the spring and the control arm encase something goes haywire
i do pretty much the same, brakes off, tie rod end out of the knuckle, two bolts for the strut, and then lower the jack slowly.  my stock springs did not even come close to shooting out, but they did need a little persuasion, i just pushed harder down on the a-arm and pulled on the spring and it popped right out.
i cant get that darn rear control arm bolt out. i got the nut off but the bolt isnt coming out . any tips
you only need to drop the one thats connecting the control arm to the axle tube. i pull the sway bar, then put a jack under the arm, either run the bolt out with the impact/ratchet or hammer it out with a punch. then lower the control arm.
yeah im trying the right one and when i use a hammer it doesnt move at all
Wonder if the bolt is seized to the metal sleeve in the bushing.  if the bolt turns you could try putting a pry bar on the one end of the bolt and put pressure on it as you turn the bolt with a ratchet/impact
If they were rotted like mine you're gonna want new hardware. Don't have to get it from MM but I knew they had them on their website, I'm sure CJ's carries it also.
Sent from Space
i got the front springs in! i will order those bolts and try again soon on the back. when i took her for a spin the front driver side wheel started making sound like thin metal scrapping and when its stopped it doesnt make the noise but when its moving its makes the noise. think it may be the brake pads arent seated right. any ideas guys?
sounds like the dust shield on the back side of the rotor got bent a little.  happens all the time.  You can bend it back without taking anything off, turn the wheel, just reach back there and figure out which part is hitting.
When I did my rear springs I didn't unbolt the control arm at all, I think it's easier that way.  It may be difficult to remove the bolt because the rear suspension tension is holding it.
+1. Unbolt rear shocks and sway bar and the rear end can usually droop and articulate enough to do the springs. Like someone else said though those control arm bolts can get pretty grungy over the years so in your case it's probably not a bad idea to remove/inspect/replace them.
im not sure if my factory springs are short enough to come out. i had to use a pry bar on the front to get the springs out of the control arm. caked in mud and rust. the bottom of both springs snapped off it was bad but i needed new springs
FYI, if you lower 1" or more, you are going to encounter a 'slam' in the rear suspension over some bumps. The Bullitt mustangs had a shorter pinon snubber, but it's obsolete. now. You can remove the bracket for the axle damper weight and gain an inch of travel, or use Maximum Motorsports progressive urethane bumper...HTH
