Prokiller
May ROTM Voting - 2v motors
May ROTM
21 members have voted
  1. 1. Who is our May ROTM Winner?
    • F8L GT
      11
    • Jgib4
      1
    • Ferocious
      9
This month we celebrate our smaller Mod motor brethren with a ROTM devoted to the ever popular 2 valve motor.  We have three stout competitors this month that are all doing something different.  It will be a tough decision i think.
F8L GT
Engine/Drivetrain
-Mark 8 short block
-Ported and Polished PI Heads
-BTR Valve Springs
- Big Duration Cams
-Vic Jr Intake
-SMS Performance Intake adapter
-Professional Products Polish Plenum
- Professional Products Polished 75mm Throttle Body
-Long Tube Headers
-A/C Delete with Short Belt
- SMS Performance Cold Air Intake
-Coyote Fuel Injectors
-Brandon Alsept Tuned
-Fidanza Aluminum Flywheel
-Centerforce Dual Friction Clutch
-Faceplated 3650 Transmission
-FRPP Carbon Diff
-Moser 31 Spline Axles
- 4.56 Gears
-Perfect Launch Diff Cover
Exterior
-Wing Delete
-Mach 1 Chin Spoiler
- Mach 1 Grill Delete
-Tinted Heads/Tails
Interior
-Rear Seat Delete
-Grant Steering Wheel
-Air Bag Delete
-Autometer 5" Tach
-Jegs Oil Pressure Gauge
-Jegs Water Temp Gauge
-AEM Wideband
-Jegs Pistol Grip Shift Handle
-Steeda Tri Ax Short Throw
-Radio Delete
Suspension
-Strange Adjustable Struts
-4 Cylinder Fox Front Springs
- Strange Adjustable Shocks
-Cut Stock Rear Springs
-Team Z Lower Control Arms
-Baseline Relocated Upper Control Arms
-Drag Bag in Right Rear
Wheels/Tires
-Big and Littles with Jegs Sport Star Wheels.
-26x11.5x15 Mickey Thompson ET Drags
Jgib4
Engine:
Npi block
Pi heads (valve job trick flow valve springs) Decked for added compression
Ortiz performance stage 1 cams
SVO blower with 6PSI pulley
70mm tb and CAI
Lightning MAF
Flow tech long tubes and o/r x
SLP LM1
Fuel:
255 pump
30 lbs injectors
Suspension/brakes:
J and M lower control arms
Lake wood 50/50 shocks
FLSFC
Stop tech drilled and slotted rotors and pads
Solid motor mounts
T45 with carbon syncros and billet shift forks, exedy stage 1 clutch
Rear has 373 gears
Saleen replica wheels with BFG 255/45/17 on all 4
Exterior and interior are pretty much stock, besides a short throw shifter and soon to have my wideband hooked up in my vent.
Ferocious
exterior:
- Black housing headlights
- Depo black diamond corners
- Yellow foglights
- Chin spoiler
- Custom front splitter
- Custom side splitters
- Custom rear diffuser
- Custom winglets
- S281 spoiler
- Red calipers
- Gold bumper inserts
- Silver 4.6L badges
- 3" carbon fiber antenna
- Wiper delete
- 5% & 20% tint
- 18"x3.5" exhaust tips
- Gold tuner lug nuts
interior:
- Red gauge cluster lights
- Red map lights
- Red HVAC controls
- JVC audio headunit
- Dual gauge pillar pod
- Oil pressure gauge
- Water temperature gauge
- Black/red suede shift boot
- Red Procar drifters
- CDC light bar
performance:
- Mac cold air intake
- Mac 75mm throttle body
- Trick Flow plenum
- UPR off-road x-pipe
- SLM LM1 resonators
- PI intake
- Spectra premium radiator
- Walbro 155 lph fuel pump
- FRPP high performance spark plugs
- 4:10 gears
drivetrain:
- T-45 swap
- Ford Racing clutch fork
- Steeda short throw shifter
- Steeda double hook quadrant
- SR adjustable clutch cable
- King Cobra style clutch
 suspension:
- Strange front coilover kit
- Strange 10-way adjustable struts
- QA1 10" 300lbs springs
- J&M caster camber plates
- Revo Technica camber kit
- SVE rear lowering springs
- Rear isos removed
- Strange 10-way adjustable shocks
- UPR rear coilover mounting brackets
- J&M lower control arms
- MM pinion snubber
- Rear cobra sway bar
wheels/brakes:
- 18x9.5 Enkei RPF1s
- 18x10.5 Enkei RPF1s
- General Exclaim UHP (275) & (295)
- Kinetic cross drilled & slotted rotors
- Powerstop ceramic brake pads
- Custom tire bomb
Guest
