b.mad@MaddRetros Posted October 17, 2017 Report Share Posted October 17, 2017 (edited) Hello! For those of you who follow the build, you know that I recently got a Tech Sponsorship with Setrab USA! For those who dont follow, now you know lol. So a bit of background, I have a 1994 GT that was a daily driver, now its going to be more track oriented (autocross and road racing). The car was working good, until about the first of this year, when during a canyon run, power steering fluid gushed all over the engine bay. After that, it was downhill from there. Event after event, problems with the pump running dry because of spilled fluid. Had to figure out how to keep the temps low. Tried turning on the oil cooler fans, had to turn off my car in between runs, and had to adjust my driving to the point where I wasnt even trying anymore. One last event, it ran dry, and that was the last of that event. You can see the videos below where the steering locked and prevented me from steering, went straight for the comes. Same video, but different time And another one, but luckily this one was at the end. But you can see how much I had to adjust, brake earlier, and adjust transitions. Overall, bad combo. In racing, heat is probably your #1 enemy/competitor. We didnt help the 23 year old power steering pump by mounting huge and sticky 275's up front, and beating it around the track for about a year straight. It was clear the pump did not want to work anymore. How do you solve the problem? First, you should get rid of that pump, and probably NOT go with an OEM replacement. But, many of us do not have fabrication skills, the time, or the money to do that. Even then, there is no guarantee that it will solve your issue. So what do we do? Just keep breaking pumps and hope we dont crash? There is a solution. Ladies and Gentlemen, I introduce you to the Setrab USA's Oil Cooler Fanpack (Part#FP113M22I). As many of you know, Setrab is a leader in the oil cooler industry, and is used by some brands as an OEM oil cooler. Is your diff oil overheating? Oil? What about your power steering fluid? Cooler is your solution. I wont bore you with the technical details of fluid, heat, blah blah blah. I will save that for the blog. However, I will be going over how to connect and install the cooler, as well as places to install, and reap its benefits. For now, enjoy some shitty pictures I took with my phone at work. Because I was too excited to wait till I got home. Edited November 11, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted October 17, 2017 Author Report Share Posted October 17, 2017 (edited) I know what you guys are thinking. WHAT DOES THIS THING COST?????????????????????? WHY CANT I FIND IT ONLINE??!?!?!?Heres the deal guys, the product has not been released yet, so it is a bit of a waiting game. Which is perfectly fine, because it will give you a chance to save up the MSRP of $289. And it gives you a chance to source your fittings and hoses and get a good price. I will be posting up more information as I go on, but for now, ask questions! Also, I highly recommend that you contact Setrab USA. Call them or email them. We are here to help! http://www.setrabusa.com/consult/index.htmlinfo@setrabusa.com740-625-6228 I decided to make a series of articles to bring awareness to fluid dynamics. Here are the links below:Why Did I Decide to Install a Power Steering Oil Cooler?Installation: Edited November 23, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted October 23, 2017 Author Report Share Posted October 23, 2017 (edited) Product pictures! Edited November 11, 2017 by b.mad 1 Link to comment Share on other sites More sharing options...
Prokiller Posted October 24, 2017 Report Share Posted October 24, 2017 that is really nice looking. Link to comment Share on other sites More sharing options...
Blackmage Posted October 26, 2017 Report Share Posted October 26, 2017 makes me want one, but i know id never actually need it lol Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted October 29, 2017 Author Report Share Posted October 29, 2017 Thanks guys!! soo the time you guys been looking for, i have some things to say about the install. Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted October 29, 2017 Author Report Share Posted October 29, 2017 (edited) So install. When you purchase the oil cooler, you will need to have the M22 -06 AN fittings to fit to the cooler. When installing the AN, you need to take off the plastic covers. Also, you will need O-rings. The AN fittings came with the o-rings so that was easy, but if you do not have them, you need them to prevent leaks. Screw them in and make sure they are tight. Fittings: -Oil Cooler: M22-AN06 Adapter (2) -Hose to oil cooler: -"Hot" Side: 90* AN06 RU(Reuseable hose end) (1) -"Cold" side: 90* AN06 with a 3/8" hose end (barbed) (1) -Rack (low Pressure): I believe i ended up using a modified 5/8"-18 NPT and AN06 RU(Reuseable hose end) (1) -Thermal Switch: Thermal Switch Probe, 180ºF, NPT1/8" and 180* AN06-AN06 adapter. (you can buy this as a kit directly from Setrab USA, part#31-TS180-06). Now the next step is to install the An fittings for the hoses. Since I am going steel braided, I got the fittings for those hoses. Again, Setrab did a good job and supplied that for me.However, if you wish to save some cost, you can use the rubber hoses, you do not have to convert to AN fittings. Nor do you have to convert the fittings on the rack to AN. Realistically, you will only use AN fittings for the cooler. So, how do you accomplish this? By getting a fitting that it AN on one side, and barbed in the other side. Just to give you an idea, to convert to AN fittings and steel braided hoses will cost about $100, for just the low pressure side of the system. Versus $13 for the fitting shown below and you get to reuse your hoses and such. Edited November 11, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted October 29, 2017 Author Report Share Posted October 29, 2017 (edited) Now if you are converting to AN fittings and steel braided hoses, you will need to remove the lines. Contrary to what 90% of the people say, you do NOT need to drop the rack. You do NOT need some fancy multi-angle wrench. I spent more time searching for the damn wrench, then it took to take off the fittings. You'll need to take off the driver front wheel, you will need to remove this plastic thing.Since my bushings are shot, I took off my sway bar. And it freed up a butt ton of space. To take off the sway bar, its 2 bolts on the chassis, and the sway bar link. I only removed one side.Once you got that, you just get some pliers and remove the rubber hoses down below from the metal lines.These tabs. No you don't need to remove the hose from the pump, just slide the pins and take out the hoses.Make sure you have something to catch the fluid.Next, take a 8mm socket and take off the brackets that hold the line to the radiator support. Theres two bolts.Tada. Edited November 11, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted October 29, 2017 Author Report Share Posted October 29, 2017 (edited) If you are using the rubber lines, you can skip this post since it doesn't apply. But if you are going to convert to AN, its easy to get to once you have all that crap out of the way. So how do you take the lines off the rack? Well, first off, you gotta remember what is what. The line on the top is the low pressure. The line below is the high pressure.In this picture, the high pressure line is the one that was removed. The low pressure is the one that was not removed.So i am pretty sure you are dying to know what the secret is. Ready? Once you have all that stuff out of the way, you get your NORMAL 11/16's wrench and break loose the high pressure fitting. Get that out of the way. Next, you take that SAME wrench, and take off the low pressure hose. SIMPLE! Took less than 10 minutes to take off both fittings. Here is a picture of my girlfriend taking off the fittings. She wanted to help.Now that it is off, time to put the low pressure fitting. Putting AN fittings on the line is easy, I will post picture of how to put that together later. But for the AN fitting on the rack, you can use a 90* or 0*. I used a 90*, but i think 0* would have worked better. But whatever. Edited November 11, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted October 29, 2017 Author Report Share Posted October 29, 2017 (edited) Now the next time is mounting the cooler. Originally, I was going to mount it on the lower frame rail. However, that look like too much work, so i mount it just below the headlights. Just because I am on a time crunch, I used the rubber hose for the fluid that exits the cooler, and goes into the low pressure side of the pump. Why? Because the low pressure fittings on the pump is a "nipple" and it will require a lot of work to convert that to AN and i don't have the time at the moment. So i used the rubber hose. When mounting it behind the bumper and under the head lights, you have to worry about two things: 1.) is the bumper going to fit, and 2.) is there going to be enough airflow.Answer to #1:So there are a few advantages of running it in this area, and running this particular fanpack. 1.) The fanpack is small enough to fit where it fit! 2.) you don't have to worry about airflow because you have a 145CFM fan attached to it 3.) if you are worried about airflow, you can duck a hose from the bumper openings. Or you can make your own duct at the high pressure area of the front bumper. You don't even need a lot of ducting because its that close!! That is it for now. More later. Edited November 11, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted October 31, 2017 Author Report Share Posted October 31, 2017 (edited) Apparently, Ford designed the rack fittings so that you are forced to use theirs because not many people make it. So, I was given a metric fitting (my mistake), however, it is a standard fitting. So it went in (kinda hard) and eventually stopped because the thread crossed. So, that fitting is done. Went to the store and picked up another one with the correct thread, however, because its a Ford fitting, it had to be modified so that the fitting is shorter. Because in the rack, the sizing changes (it gets smaller). So the normal an fittings wont work. So basically, machined some of the fitting off so that it stops right before the port gets smaller. Put some thread lock (its better if you have hydraulic sealant, but thread lock worked good), o-ring seal, and a washer, and no leaks! I will get the thread pitch info later today. So unless you want to modify some of the fittings, I recommend that you either dont convert to AN, or get the MM fittings made specifically for the rack.The black is the Setrab fitting (left), middle is the new fitting (notice how it is a lot shorter), and right is the stock fitting. I cut off the hard line. I need to really clean under the car....But no leaks! Edited November 11, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted October 31, 2017 Author Report Share Posted October 31, 2017 (edited) To cut and put together a stainless steel hose is pretty easy. To cut, I recommend that you wrap where you are going to cut in tape, AND put a zip tie on that area to avoid fraying the line. I used a dremel with a cut off wheel to cut the line. Worked decently. Now to put the fitting. First you will put the end that goes to the hose. Make sure you get it all the way in there. You can twist to help you. Once it is in there, you screw in the fitting. So here is where it gets tricky because you are literally shoving the fitting into the hose. So as you screw in the hose, the hose will start sliding out. So you need to apply a pushing pressure so that the hose doesnt slide out. After that is done, time to wire the thermal switch, which is pretty easy. The fanpack has two cables, black and red. Black goes to ground, red goes to one of the two prongs on the thermal switch. The other prong on the thermal switch is also a positive connection, so it goes to the constant 12v supply.You need to use a min of 18 gauge awg wire.TADA!!! Edited November 11, 2017 by b.mad Link to comment Share on other sites More sharing options...
95riosnake Posted November 1, 2017 Report Share Posted November 1, 2017 Are those rubber or teflon lined braided lines? For power steering you need to be using teflon lined braided stainless. Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted November 3, 2017 Author Report Share Posted November 3, 2017 On 11/1/2017 at 3:17 AM, 95riosnake said: Are those rubber or teflon lined braided lines? For power steering you need to be using teflon lined braided stainless. Good question. I trust that Setrab know what they are doing, but I can double check Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted November 11, 2017 Author Report Share Posted November 11, 2017 (edited) Just another update, I ended up switching one of the mounting of the cooler so that it sits leveled to avoid any deficiency in the efficiency. Also, I removed and tighten all the fittings, and as of this weekend, NO LEAKS! Cant wait to try this out. Edited November 23, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted November 13, 2017 Author Report Share Posted November 13, 2017 (edited) Sneak pic of some of the pictures I will featuring on the two articles I will be posting on my site. Edited November 13, 2017 by b.mad Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted November 13, 2017 Moderators Report Share Posted November 13, 2017 On 11/3/2017 at 5:51 PM, b.mad said: Good question. I trust that Setrab know what they are doing, but I can double check So not to beat a dead horse, but did you confirm those were teflon lines (they don't look it). Setrab, I am sure knew what they were doing, but you made the lines, correct? Don't want to see your power steering blow on the track is all. Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted November 18, 2017 Author Report Share Posted November 18, 2017 On 11/13/2017 at 6:41 AM, Psychorugby said: So not to beat a dead horse, but did you confirm those were teflon lines (they don't look it). Setrab, I am sure knew what they were doing, but you made the lines, correct? Don't want to see your power steering blow on the track is all. Good Question. I haven't had a chance to reach out to Setrab about the difference in hoses. But theres a local hobbies shop that specializes in AN fittings and such, so they should know too. Ill reach out to them first. Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted November 22, 2017 Author Report Share Posted November 22, 2017 (edited) You can read the full article here: https://maddmotorsportsdesign.blog/2017/11/20/why-did-i-decide-to-install-a-power-steering-oil-cooler/ After researching and not being pleased with the quality of coolers that I found, I decided to reach out to Setrab USA for recommendation and assistance. I have had good success running their oil cooler for the engine oil and thought it would have been a great idea to reach out and expressed a few concerns about price and placement. If you are NOT going to run a fan, you will need to place the cooler in an area that has good airflow, which for the SN95, will be in front of the radiator. However, that posed an issue for me because I already have a large oil cooler blocking the radiator, and adding another cooler will block more of the direct air flow to the radiator. That was not going to work for me. Marv mentioned that if I would consider running a Fanpack (which adds to cost), it will give me more flexibility in where I can mount the cooler because the fan will provide the air supply. The FP113M22I fanpack was the answer to all my problems. Not only is the Fanpack inexpensive, it is small enough to not limit my options for mounting. The placement was chosen for one simple reason, it just made sense. The area was easy to install, Having the cooler in an easy access area will make it better for maintenance, It would not interfere with rotating parts, The location is in a moderate to high pressure area of the front of the vehicle, High pressure area will provide ample air flow to the cooler if you make a ducting opening, AND Because it is directly behind the bumper, you will only need a short duct hose, or none at all. Once again, it just made sense. A Thermal Switch was also installed to help with the cooling of the oil. Instead of having the fan wired to a toggle switch, it will be wired to the 180*F Thermal Switch. This is convenient because I would not need to run a temperature gauge, remember to turn on the switch, or perhaps turn it on when it is not needed. The setup that Marv recommended was exactly what I needed. The FP113M22I Fanpack was introduced to use for DSG transmissions, high-performance street differentials, UTV engine oil cooling, and Formula Drift power steering applications. What is the advantage of running this pack? It is very small, however, it is extremely high performing. Because of its size and self-contained air supply you can mount it almost anywhere. Why is this an advantage? Because without a self-contained air supply, you will have to mount it in an area with good airflow, which usually means blocking the radiator. However, with a fan blowing 148CFM (at 0 static pressure), you can mount the cooler wherever you have space! And trust me, this Fanpack can fit in a lot of places! COMING SOON! Directions on how to install P/N FP113M22I. Edited November 23, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted November 22, 2017 Author Report Share Posted November 22, 2017 (edited) and to answer people's question about the hose, Teflon is actually a brand of PTFE. The hoses I am using are CPE. CPE was designed to replaced rubber in aviation in WW2. They can handle 1,000 PSI. If the factory hoses are rubber, CPE will do just fine, especially considering that they are on the low pressure side of the system. Since power steering fluid isn't considered a harsh fluid, like fuel, PTFE is not needed. Both hoses will do fine for the pressures associated. However, PTFE is recommended for high pressure in the power steering system AND anytime you are using harsher fluids (which is what it was really designed for). Edited November 22, 2017 by b.mad Link to comment Share on other sites More sharing options...
95riosnake Posted November 22, 2017 Report Share Posted November 22, 2017 The hoses themselves aren't the weak link for power steering applications. The method that the hose is engaged by the fittings at each end is where the weak link lies for high pressure. The ferrule design of the PTFE fittings is what makes the connection much stronger than the conventional fittings. Anyway, you are free to run whatever style hoses and fittings you want to run. I did a lot of research before doing braided lines for my car and the resounding opinion from the majority of builders was to use PTFE lined hoses (and yes I know PTFE is the actual material - I said teflon to make it more understandable to anyone reading this who doesn't have an engineering background). If you feel confident your lines are good to go, that's all that matters. PTFE Fittings use a ferrule and a flared nut vs. pinching the rubber between the two halves of the fitting like a conventional AN fitting. 2 Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted November 23, 2017 Author Report Share Posted November 23, 2017 (edited) 19 hours ago, 95riosnake said: The hoses themselves aren't the weak link for power steering applications. The method that the hose is engaged by the fittings at each end is where the weak link lies for high pressure. The ferrule design of the PTFE fittings is what makes the connection much stronger than the conventional fittings. Anyway, you are free to run whatever style hoses and fittings you want to run. I did a lot of research before doing braided lines for my car and the resounding opinion from the majority of builders was to use PTFE lined hoses (and yes I know PTFE is the actual material - I said teflon to make it more understandable to anyone reading this who doesn't have an engineering background). If you feel confident your lines are good to go, that's all that matters. PTFE Fittings use a ferrule and a flared nut vs. pinching the rubber between the two halves of the fitting like a conventional AN fitting. I didn't mean to come off snobby. People had questions about the hoses, so i thought that was the issue. Didn't know it was the fitting.. But noted..thanks.. Edited November 23, 2017 by b.mad Link to comment Share on other sites More sharing options...
b.mad@MaddRetros Posted November 27, 2017 Author Report Share Posted November 27, 2017 Installation instructions are published! Click the link: https://maddmotorsportsdesign.blog/2017/11/24/installing-the-setrab-fp113m22i-fanpack/ What is being installed Setrab Fanpack (P/N FP113M22I) Series 1, 13-Row Oil Cooler (P/N 50-113-7612) Single Spahl Electric fan w/shroud Setrab ProLine Mounting Brackets (P/N 23-1002) Setrab AN06-AN06 Thermal Switch Assembly, 180º (P/N 31-TS180-06) Low Pressure Steel Braided Hoses (P/N 21-SSN06-B) Fittings: Oil Cooler: M22-AN06 Adapter x2 (P/N 22-M22AN06-SE) Hose to oil cooler: "Hot" Side: 90* AN06 RU(Reuseable hose end) x1 (P/N 22-AN06SUAN06-90) "Cold" side: 90* AN06 with a 3/8" hose end (barbed) x1. Please note, if you are not converting to steel braided hoses, you will need two of these fittings. Power Steering Rack (low Pressure): Shortened 5/8"-18-AN06 ORB adapter fitting x1. If you purchased the Maximum Motorsports' Power Steering Rack fittings, you can use those instead. Please note the M16x1.5 fitting will NOT work. 90* AN06 RU(Reuseable hose end) x1 (P/N P/N 22-AN06SUAN06-90) Tools and Supplies Needed AN06 Wrench or 11/16" Wrench 3/4" Wrench 5/8" Wrench M22 (or 7/8") Wrench 5/32" or 4mm Hex Key Tool (Allen Wrench) Female Wire Connectors Ring Wire Connectors Stripping/crimper Pliers 18-gauge AWG Wire 8mm Socket and Ratchet Needle-Nose Pliers 3/4" Socket and Ratchet Drip Pan 242 (blue) Locktite, or Hydraulic Sealant Link to comment Share on other sites More sharing options...
