the.greg Posted May 2, 2013 Report Share Posted May 2, 2013 Ok people. Welcome to the May 2013 Voting thread. We've decided to make the voting just a simple poll this month, so vote one time for your favorite candidate! Congrats to this month's finalists: iRoush, SniveTroll, and Tony!iRoushMod List:Performance:MMR 600 Short Block-Flat Top Manley Pistons (13.7:1 Compression after head/block decking)-MMR I-Beam Rods-Ford Cast Crank-1998 Teksid Aluminum Block -Decked .030 Over -Dynamically Balanced Rotating Assembly-MMR Windage TrayMHS Stage 3 Ported Heads-Decked .030 Over-Oversized Stainless Valves-Timeserted Spark Plug Threads-Stage 3 Valve SpringsMHS Stage 4.5 Bullet Cams-Degreed for Max Power-245/243 Duration-108 Lobe Separation Angle-550/540 Lift- Ford GT Camshaft Followers- OEM Lash AdjustersSteeda Underdrive PulliesAccufab PlenumRoush 75mm Throttle BodyJLT Ram Air IntakePort Matched OEM Intake ManifoldMMR-Moroso Oil/Air SeparatorEGR DeletePCV DeleteMoroso Coolant OverflowOdyssey PC-680 Battery w/ aluminum mountFRPP 42# Injectors90mm Lightning MAF2004 Terminator Fuel Tank w/ PumpsMac Longtube HeadersMac O/R H-PipeDynomax Super Turbo Side Exit ExhaustFidanza Aluminum FlywheelExedy Mach 500 ClutchSteeda Firewall AdjusterSteeda Adjustable Clutch CableSteeda Quick Release QuadrantFRPP Aluminum DriveshaftFRPP 3.73 GearsChassis:Roush-Bilstein Shocks & StrutsMaximum Motorsports Front Coilovers (300# Springs)Maximum Motorsports C/C PlatesCustom Front End Alignment for AutocrossMaximum Motorsports Bumpsteer Kit (Cycled Bumpsteer out)Maximum Motorsports 4-Point Roll BarRoush Subframe Connectors (Welded In and tied to roll bar)Roush Rear Springs (No Isolators)Roush Tubular Rear Lower Control ArmsRoush Rear Sway BarRoush Pinion SnubberRoush-PBR 13" Front Brake Caliper KitRaybestos R-300 Brake RotorsPorterfield R4-S Brake PadsSpeed Bleeder KitInterior:Corbeau Style Reclining Race Seats w/ custom seat mountsG-Force 6-Point HarnessRoush Gauge Cluster with custom mounted Autometer Oil Pressure Gauge in ClusterHome Made Progressive Shift LightFlorida 5.0 Radio Delete PanelsHome Made HVAC Delete Panel w/ AFR Gauge MountHome Made Passenger Airbag DeleteMOMO Steering HubNRG Quick Release v2.0OMP od/1990/nn Steering WheelPLX DM-5 Wideband GaugeRoush Short Throw ShifterGutted Dash, Doors, and TrunkRemoved Sound Deadening, insulation, etc.Exterior:Roush Stage 3 Front BumperRoush-Yates (Penske) COT Tegris Front Splitter w/ Custom Fabricated Dive PlanesLongacre Splitter RodsSteeda Q400 HoodMoroso Hoods PinsRoush Side SkirtsRoush Rear ValancesRoush Side Exit Exhaust SystemRoush-Yates (Crawford Composites) COT Carbon Fiber WingAgent 47 Vortex GeneratorsWicked Motorsports Rear DiffuserSmoked Headlight CoversHIDmasters 6000k Hid Headlight/Foglight KitMirrored Finish Radiator PanelRoush 18x9 Argent Wheels-265/35/18 Sumitomo HTR-Zii Tires (Front)-285/35/18 Sumitomo HTR-Zii Tires (Rear) SniveTroll Mod List Performance:engine:Ported PI heads WAP MMR stroker 850 301 CIDCrower stage 2 camsmanley internals top to bottom. Livernois oil scraperRR intake Vortech T-trim w/ 2.70 pulleyFuel:60lb injectorsCPR fuel railsA1000 fuel system. Drivetrain:TKO 600spec 3+spicer 4" Aluminum driveshaftUPR axle bracesUPR/GMS diff girdleWelded axle tubesAuburn Diff 3.73 gearsMoser axlesSuspension:front suspension:QA1 A-armsQA1 K-memberGMS front coiloversKYB front strutsMM Caster platesSteeda Front Sway barSteeda Bumpsteer kitQA1 springsrear suspension:MM adj. LCAMM PHBH&R super race springsChassis:6PT roll bar w/ swing outs. Stiffler's trans mount. Custom subframe connectorsinterior:Autometer phantom and ultralite gaugesFAST dual widebandgay 60s tachRaptor shift light. APC race seats. TonyMod List:Performance:Motor4.6LAM sr upper intake plenumBBK caiBBK t/bExhaust:AM xpipeFLOWMASTER exhaust INTERIORnew carpet, kick plates, center console, door cups, shifter bezelprocar racing seatscustom molded in double dinstyle barUPR billet accessories EXTERIORToyota pacific metallic blue conplete repaintCervini's stalker kitsaleen hoodNew black cloth topAM smoked headlights and tailsnew badgescobra fogsSUSPENSIONsteeda front and rear sway barsair ride tech adjustable shocksridetech full air suspensionBBK grip caster camber platesBBK strut tower braceDRIVETRAINJEGS 373 gearsJEGS axle shaftsJEGS cross drilled rotorsTSW mirabeau wheels20x9 front20x10.5 rearNITTO 555 235/35/20 frontNITTO 555 275/30/20 rear Link to comment Share on other sites More sharing options...
Schiffy Posted May 2, 2013 Report Share Posted May 2, 2013 They are all great looking cars(well, 2 of the 3), but I'm gonna throw out my vote for my boy Jason and his almost 700hp ride.Sent from my secretary!!! Link to comment Share on other sites More sharing options...
Det_Riot Posted May 2, 2013 Report Share Posted May 2, 2013 Fugggg talk about cars from all corners of life. We got show n go tony, corner corner Brett, and quarter mile mayhem with Jason.......decisions decisiins Link to comment Share on other sites More sharing options...
95riosnake Posted May 2, 2013 Report Share Posted May 2, 2013 ^ +1, I'm going to have to think this one over a bit. Link to comment Share on other sites More sharing options...
64bit_Tuning Posted May 2, 2013 Report Share Posted May 2, 2013 None of the above.Reason: no 5.0L love... Link to comment Share on other sites More sharing options...
95riosnake Posted May 2, 2013 Report Share Posted May 2, 2013 None of the above.Reason: no 5.0L love...That's a tough thing to have in modular month... lol.Ok guys and girls its time to nominate for the April Ride of the Month! This month's theme is Modular powered cars.Snive's stroker is aaaaaalmost a 5.0L though! Link to comment Share on other sites More sharing options...
64bit_Tuning Posted May 2, 2013 Report Share Posted May 2, 2013 There is a modular 5.0... I never specified pushrod Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted May 2, 2013 Moderators Report Share Posted May 2, 2013 Tough decision for sure! Link to comment Share on other sites More sharing options...
95riosnake Posted May 2, 2013 Report Share Posted May 2, 2013 There is a modular 5.0... I never specified pushrodsigh... got me there Link to comment Share on other sites More sharing options...
Tony Posted May 2, 2013 Report Share Posted May 2, 2013 is it cool that i voted for myself :shiftyeyes:lol, i gave it to the cone hitter...i mean dodger :look: Link to comment Share on other sites More sharing options...
Det_Riot Posted May 3, 2013 Report Share Posted May 3, 2013 ugh such a hard decision, but at the end of the day I went with berttt. Such a smexy car, so much functional sex, plus I had a hand in his gauge cluster he hasn't hooked up yet ;] Link to comment Share on other sites More sharing options...
iRoush Posted May 3, 2013 Report Share Posted May 3, 2013 ugh such a hard decision, but at the end of the day I went with berttt. Such a smexy car, so much functional sex, plus I had a hand in his gauge cluster he hasn't hooked up yet ;]haha one day i will wire it up. just avoiding it currently because it requires removing the damn oil filter neck Link to comment Share on other sites More sharing options...
Solar Posted May 3, 2013 Report Share Posted May 3, 2013 But none of them are black...wtf! Link to comment Share on other sites More sharing options...
Tony Posted May 3, 2013 Report Share Posted May 3, 2013 look..5 people voted for me but are hiding :behindsofa:who voted? WHHOOO dammit! Link to comment Share on other sites More sharing options...
Pushrod91 Posted May 3, 2013 Report Share Posted May 3, 2013 MeSent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
copmagnet Posted May 3, 2013 Report Share Posted May 3, 2013 I was like, "easy decision" then i saw tonys engine bay....my god, its beautiful.. Link to comment Share on other sites More sharing options...
Steve@CJPP Posted May 3, 2013 Report Share Posted May 3, 2013 look..5 people voted for me but are hiding :behindsofa:who voted? WHHOOO dammit!I did, but it's because you have a panty dropping car that makes for one hell of a panty dropping sig. Link to comment Share on other sites More sharing options...
95riosnake Posted May 3, 2013 Report Share Posted May 3, 2013 Tony, you ended up getting my vote. It was a dead heat between your car and Brett's car, so I literally flipped a coin and you won the coin toss lol.I like both your cars equally for totally different reasons, lol. I had been thinking it over too much so I left it up to the coin haha.Not to take anything away from snive's ride though, lay some paint on it and I would've had to find a 3 sided quarter to flip lol Link to comment Share on other sites More sharing options...
WildWillyWalker Posted May 3, 2013 Report Share Posted May 3, 2013 Some of the best cars on here, and how diverse! My vote's in... interesting. Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted May 3, 2013 Moderators Report Share Posted May 3, 2013 Tony, you ended up getting my vote. It was a dead heat between your car and Brett's car, so I literally flipped a coin and you won the coin toss lol.I like both your cars equally for totally different reasons, lol. I had been thinking it over too much so I left it up to the coin haha.Not to take anything away from snive's ride though, lay some paint on it and I would've had to find a 3 sided quarter to flip lolFunny my vote came down to the exact same process... went the other way. Our votes cancel each other out. Link to comment Share on other sites More sharing options...
Tony Posted May 3, 2013 Report Share Posted May 3, 2013 lol, dan. my vote went to bret too...just cause he's tall too. i dont even know what kinda car he drives Link to comment Share on other sites More sharing options...
Number Tew Posted May 3, 2013 Report Share Posted May 3, 2013 Gave it to the guy that likes to talk to me on the phone Link to comment Share on other sites More sharing options...
Solar Posted May 3, 2013 Report Share Posted May 3, 2013 I voted for your Tony face! Link to comment Share on other sites More sharing options...
Tony Posted May 3, 2013 Report Share Posted May 3, 2013 lol, i'm just fuckin around. brett deserves to win simply cause he actually uses his mustang for racing. i use mine for picking up high school chics...hahaha, j/k. but seriously Link to comment Share on other sites More sharing options...
Det_Riot Posted May 3, 2013 Report Share Posted May 3, 2013 lol, i'm just fuckin around. brett deserves to win simply cause he actually uses his mustang for racing. i use mine for picking up high school chics...hahaha, j/k. but seriously Link to comment Share on other sites More sharing options...
Schiffy Posted May 3, 2013 Report Share Posted May 3, 2013 lol, i'm just fuckin around. brett deserves to win simply cause he actually uses his mustang for racing. i use mine for picking up high school chics...hahaha, j/k. but seriouslyYOU TOO!? Oh wait, what...Sent from my secretary!!! Link to comment Share on other sites More sharing options...
iRoush Posted May 3, 2013 Report Share Posted May 3, 2013 I only road race to pick up asian chicks. I tried drag racing but all there is are fat chicks with no teeth at those events :look: Link to comment Share on other sites More sharing options...
Steve@CJPP Posted May 3, 2013 Report Share Posted May 3, 2013 I only road race to pick up asian chicks. I tried drag racing but all there is are fat chicks with no teeth at those events :look:ugh what drag racing do you go to lol. Link to comment Share on other sites More sharing options...
MustangManiac Posted May 3, 2013 Report Share Posted May 3, 2013 ugh what drag racing do you go to lol.He meant a different type of " drag" Link to comment Share on other sites More sharing options...
Steve@CJPP Posted May 3, 2013 Report Share Posted May 3, 2013 ahh Link to comment Share on other sites More sharing options...
iRoush Posted May 3, 2013 Report Share Posted May 3, 2013 ugh what drag racing do you go to lol.the ones on an Indian reservation, the only damn place in so cal lol :B Link to comment Share on other sites More sharing options...
MustangManiac Posted May 3, 2013 Report Share Posted May 3, 2013 the ones on an indian reservation, the only damn place in so cal lol :bi wanna go Link to comment Share on other sites More sharing options...
Tony Posted May 3, 2013 Report Share Posted May 3, 2013 fuuk, even indians are drag racing now!! wtf have you people done?? Link to comment Share on other sites More sharing options...
iRoush Posted May 3, 2013 Report Share Posted May 3, 2013 i wanna golook up barona drags Link to comment Share on other sites More sharing options...
MustangManiac Posted May 3, 2013 Report Share Posted May 3, 2013 look up barona dragsI mean...bring me Link to comment Share on other sites More sharing options...
iRoush Posted May 3, 2013 Report Share Posted May 3, 2013 I mean...bring meI'm not going to a drag racing event. drag racers are so unsophisticated and barbaric compared to corner carvers.... lmao jk Link to comment Share on other sites More sharing options...
MustangManiac Posted May 3, 2013 Report Share Posted May 3, 2013 I hate you....I want to go to a corner carving event Link to comment Share on other sites More sharing options...
Det_Riot Posted May 3, 2013 Report Share Posted May 3, 2013 Just wanna say we've had more votes the past 3 days than we probably have in the past two ROTM combined LOL BUMP!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
OnyxCobra Posted May 3, 2013 Report Share Posted May 3, 2013 lol, i'm just fuckin around. brett deserves to win simply cause he actually uses his mustang for racing. i use mine for picking up high school chics...hahaha, j/k. but seriouslyyou get older, they stay the same age. Link to comment Share on other sites More sharing options...
Solar Posted May 4, 2013 Report Share Posted May 4, 2013 Excuse me....where the hell is April ROTM? Link to comment Share on other sites More sharing options...
