Prokiller Posted January 28, 2014 Report Share Posted January 28, 2014 The temperature today has reached a balmy 10 degrees Fahrenheit today. The wind chill makes it feel like -10. It's down right freezing out there. Yesterday it was 40 and people were calling it a heat wave. But tis the season for the garage project! Yes some of you can brag about your warm weather and your sunshine but we all know you suck because of it..... Anyway, getting back to the task at hand for today is our Ride of the Month Vote. However this month I'm tweaking it slightly; it's Build of the month. So only people that have active build threads here on SN95Source were eligible. Boy it was a lot to choose from in the nominations thread. Ultimately though we have 4 contestants for the oh so coveted winner thread. I want to be more clever in my introduction for this month, but my fingers are numb so I'll have to use what little bit of feeling i have left in them to cut/paste our contestants. 95RioSnakehttp://www.sn95source.com/topic/2191-the-chronicles-of-95riosnakes-ocd-machine/ 1995 Mustang Cobra coupe Current build: - Ridetech E3 Air Ride- Custom trunk and tank/compressor setup/spare tire sub enclosure- Various @Carbon Driven interior parts- Double din dash- Pioneer in dash screen, precision power/polk components- Wilwood W6A 6 piston 14" front/4 piston 13" rear brakes- Stainless oval exhaust with electric cutouts- Stifflers FIT braces/trans cross member Mod List prior to current build:Engine/fuel:Fordstrokers forged 347 stroker, 10.6:1 CRScat forged crankScat forged I-beam rodsProbe SRS forged pistonsHolley SysteMax headsHolley SysteMax intakeScorpion 1.6 roller rockers (7/16" stud mount)Canton 7qt road race oil pan clearanced for 94/95Accufab 75mm race TB fox conversionSCT BA-2600 mafSCT 4 bank eliminator chipFord Racing 42lb injectorsRussell -6an fuel linesAeromotive 340 Stealth pumpGZ Motorsports VP102 Sportsman vacuum pumpAllstar Performance breather tankCooling:Fluidyne aluminum radiatorLincoln Mark VIII fanCustom aluminum shroudXRP -20an stainless hosesCSR -20an swivel water neckCSI Overflow BottleTransmission/drivetrain/brakes:Built Tremec 3550MGW shifter26 spline McLeod RST twin disc clutchMcLeod FlywheelFord Racing aluminum D/S03 Cobra IRS, 3.55 gears, smoothed and powdercoatedComplete FTBR delrin bushing kitFTBR extreme duty toe linksFTBR sway bar linksFront/rear cobra anniversary brake calipersBaer D/S rotorsHawk ceramic padsRussell stainless brake linesFront Suspension:Tokico D-Spec strutsTeam Z coilover kit350lb HypercoilsMaximum Motorsports tubular A-arms2003 cobra steering rack w/-6an Teflon line conversionDerale power steering coolerUPR Bump SteerEnergy sway bar end links and rack bushingsMaximum Motorsports 4-bolt C/C platesRear Suspension:Bilstein HD shocksMaximum Motorsports coilover kit550lb HypercoilsCHE rear shock tower braceSpinTech subframe connectorsPower Adder:Procharger D1SC, 9psi 3.35 pulleyProcharger sheet metal 3-core intercoolerCustom built piping/power pipeRace Mart 50mm blow off valveExhaust:MAC Jet Hot coated 1-5/8 long tubesCustom-built X pipeBorla StingersCustom built side pipes with Borla side exhaust tipsExterior:Retrofitted headlights with TSX projectors/E36 shrouds and 5000k HID'sDakota fog conversion w/ 3000k HID's - Lamin-X yellow overlaysCervini's Y2K Cobra R hoodCarbon fiber windshield cowlSVO side exhaust skirts96-98 export taillights97 Cobra rear bumper cover/ stainless insertsBullitt fuel doorWheels/Tires:HRE 542R wheels, 19x9.5 front, 19x11 rearToyo 265/30/19 front and 295/30/19 rearInterior:Sparco Evo2 seatsSchroth Rallye Cross harnessesBullitt pedals03 Cobra-style shift knobRedline Goods shift bootSteeda AC knobs and headlight knobCarbon fiber door cups, door handle bezels, arm rest, and gauge bezelSinis Engineering cluster trim ringsAutometer C2 DPSS, oil pressure, boost, water temp, and volt gaugesAEM widebandAutometer dual A-pillar podAlpine head unitBoston Acoustics components in doorsBoston Acoustics 5x7's in rearBoston Acoustics G5 10" sub in custom boxKenwood 1000w mono ampKDezines rear seat deleteTaylor battery relocation495rwhp/494rwtq Hard to get interior pics currently due to garage lighting, so this is the best I have at the moment...old pic obviously Psychorugby http://www.sn95source.com/topic/2292-50-shades-of-red/Performance: MotorStock 351w roller block*Fordstrokers forged 408w stroker*TFS Twisted Wedge 11R 205 heads*TFS R-series intake*FTI custom grind cam*Ford Racing 5.8L swap oil pan*Behind Bars Racing stealth fuel system and fuel rails*Deca 60lb injectors*Accufab 90mm throttle bodyFox throttle body swapWalbro 255lph fuel pump*Aeromotive fuel pumpStainless steel braided -6AN fuel linesPerformance Distributor Screamin’ Demon ignition coilPerformance Distributor Dyna Mod TFI module CoolingBe Cool aluminum radiator with -16AN fittingsStainless steel braided -16AN radiator hoses*Canton aluminum overflow tank DrivelineTremec T-56 (Viper spec) transmission*McLeod RST twin disc clutchFord Racing 4.10 gearsTorsen T2 31 spline differentialMoser 31 spline axlesMoser 3" studsMoser carrier bearing cap stud kitMoser aluminum differential coverWeld axle tubesPowder coated axle housing Exhaust*Accufab headers*Bassani X pipe*Bassani cat-back*Electric cutouts Suspension:FrontQA1 tubular K memberBilstein HD strutsMaximum Motorsports coil over kitMaximum Motorsports non-offset tubular control armsProthane sway bar end links and bushingsUPR 4 bolt caster/camber platesSteeringSteeda bumpsteer kitMOOG inner tie rods2003 Cobra power steering rackProthane non-offset steering rack bushingsStainless braided -6AN power steering lines*Maximum Motorsports solid steering shaft RearBilstein HD shocksH&R Super Sport springsTeam Z double adjustable upper control armsTeam Z double adjustable Street Beast lower control arms*Maximum Motorsports coil over kit*Maximum Motorsports 26mm sway barProthane axle bushings Chassis StiffeningSteeda 351w strut tower braceEnergy Suspension motor mountsFull length subframe connectors*Stiffler’s T56 transmission cross member*Torque box kit*6 point roll cage with swing out bars*CHE rear strut tower brace Brakes94-04 Cobra PBR front calipers, powder coated Rio Red94-04 Cobra rear calipers, powder coated Rio RedRaybestos R-300 rotorsRaybestos Advanced Technology padsStainless braided lines93 Cobra brake booster*Wilwood master cylinderCustom hard linesABS delete Exterior: Rio Red paintSaddle convertible top94-98 Cobra front bumper*Cervini’s 95 Cobra R hoodSide scoops*Custom trunk lid/spoilerAll emblems shaved*HID headlights*HID foglights Engine BayRio Red paintWire tuckFuel line tuckBrake line tuckSmoothed bay and firewall Interior: *Custom saddle leather/Alcantara upholstered seats*Custom saddle leather wrapped steering wheelSINIS Built custom white face gauges*Relocate battery to trunk*Double DIN conversionPioneer head unitPioneer XM radioPioneer 6x9 4 way speakers Wheels:*18x9/10 95 Cobra R replicas, widened to 11” in rear*Nitto NT555 tires *planned purchase or build Interior:now Engine Bay: 95opalhttp://www.sn95source.com/topic/2341-opals-rebirth/ENGINE/Fuel Dart block 331 9:25:1 compFordStrokers/RPM 4340 Forged Steel 3.250 Crankshaft -INTERNALFordStrokers/RPM 4340 Forged Steel H Beam ConnectingRods 5.400Wiseco 2618 Forged Pistons (14cc, Inline) 4.030Wiseco GFX Ring PackageClevite 77 H Main BearingsClevite 77 H Rod BearingsDart Coated Cam BearingsScrew in Oil Galley PlugsFel Pro Rear Main SealARP Main StudsFreeze PlugsCUSTOMER SUPPLIED CAMSHAFTCam BoltCam Retainer PlateSA Gear Billet Timing Chain w/Torrington BearingMelling Oil Pump M68ARP Oil Pump BoltsMoroso Oil Pump Pick up 24519ARP Billet Oil PumpshaftFel Pro 1 Piece Pan GasketMoroso 7qt Oil Pan - 20511Mr. Gasket Oil Pan BoltsTiming Chain Cover - Fox BodyFel Pro Timing Chain Gasket SetAFR 195 Renegade competition heads w/ titanium valve spring keepersARP 7/16 rocker studsComp Cams Pro-Magnum 1.6 rockersFTI ported Holley Systemax 2FTI custom blower camAccufab 75mm fox style throttle bodyP-mas 95mm MAFRCI custom sumped fuel cell10an feed8an returnAeromotive A1000 fuel pumpAeromotive A1000 Platinum regulatorBehind bars race car fuel rails80# injectorsSCT 4 4 bank chipZeitronics wideband POWER ADDER Vortech si @ 16-18#sAnderson powerpipeVortech MondoSnow meth injectionZex 125 shot wet kitDuel purgeMSD window switch COOLING Fluidyne aluminum radiatorCustom built shroud w/ modified sn fanMezier 55GPM remote mount water pump16an linescanton overflow TRANSMISION/DRIVETRAIN/BRAKES TKO 600 RRPRO 5.0 shifterStifflers crossmember26 spline McLeod RST twin disc clutchMcLeod FlywheelFord Racing aluminum D/SStifflers safety loopcustom braced and Narrowed 31 spline 8.8 w/ carbon fiber clutch packsFRPP 3.73Wilwood 14" 6 piston superlites w/ 2 piece drilled/ slotted rotorsWilwood 13" 4 piston superlites w/ 2 piece drilled/slotted rotorsWilwood polished tandom master cylinderWilwood adj proportioning valveABS deleteMaximum motorsports manual brake conversionStainless lines FRONT SUSPENSION Team-Z auto-x tubular K-memberTeam-z tubular A-armsStifflers K-member braceMaximum motorsports coilover w/ bilstein race struts 375# hypercoilsSteeda sway barSteeda bumpsteer kitCustom built strut tower brace Rear Suspension Team-z mini tubTeam-z shock mount barinward mount QA1 adjustable shocks w 250# hypercoilsSteeda Double adjustable upper armsSteeda lower armsMax motorsports subframe connectorsStifflers fit system EXHAUST BBK ceramic 1/5/8 headersMAC h-pipeBassani raceCustom built tails EXTERIOR saleen front and rear bumperssaleen skirtsSaleen speedsterSaleen tail light coversSaleen light barcrystal clear cobras w/ crystal clear corners03 cobra mirrors WHEELS AND TIRES Custom Forged 19 x12 19 x9.5Nitto invo 345/30 275/35 INTERIOR Custom Saleen Recaro seatsCustom center consoleFull Custom built Autometer cluster w/ 200mph speedoAutometer triple a pillar pos water,oitl,voltAutometer speedo bezel w/ boost and nitrous pressCustom in dash I padCustom built RSD w/ 10" kickersRockford Fosgate P1000X5D 1000 Steve-Ohhttp://www.sn95source.com/topic/153-ebony-desires/Performance: Ford Racing 427W crate motor4.125 bore / 4.00 strokeSCAT forged crank & I-beam rodsForged Mahle pistons 10.5:1Hydra roller cam .576/.600 ; 242/248FRPP Aluminum “Z” heads 2.02 intake / 1.60 exhaustFord EFI distributor, MSD cap/rotorEdlebrock Victor upper/lowerBBK 75MM throttle bodyC&L intake tubeFRPP 90MM L-MAFMSD 6A boxAeromotive rails, braided lines from firewall, FRPP 47lb'ers and a 255 WalbroBBK shorties, rigged up off-road “h”, Flowmaster exhaustFRPP 4.10 gears...and a basically stock T-5 Transmission!Tuning by Keith Varin (The Mk2)Suspension: Maximum Motorsports K-member, A-arms, rear lower adj. control arms, front coilover kit & CC platesBlistein front struts with Hypercoils & Bilstein rear shocks with H&R SupersportsSteeda full length subframe connectorsSteeda bump steerExterior: H.O. Fibertrends 3.5” Cobra R hoodExport rear tailightsDEPO projector headlights (matching sidemarkers) de-chromed and painted black“Poxenham” front tow hookInterior: Pioneer AVIC double din swapAutometer Lunar gaugesPush button start (inactive)Crappy factory seatsSVT rear seat delete / sub & amp mount (made by yours truly)Wheels / Tires: GT500 replicas: 18x9 front / 18x10 rearPirelli P-Zero Rosso's: 265/35 front ; 315/30 rear Let the voting begin! I'll be hovering around a burning barrel for warmth if you need me. Link to comment Share on other sites More sharing options...
Supporting Member fiveohwblow Posted January 28, 2014 Supporting Member Report Share Posted January 28, 2014 Damn. Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted January 28, 2014 Moderators Report Share Posted January 28, 2014 I feel like I need to learn how to use my Nikon DSLR. Link to comment Share on other sites More sharing options...
Ferocious Posted January 28, 2014 Report Share Posted January 28, 2014 I didn't even bother looking at the pictures/mod list. Just seeing the names I immediately knew who had my vote. Good luck gents. Link to comment Share on other sites More sharing options...
Tony Posted January 29, 2014 Report Share Posted January 29, 2014 stevo-oh's motor is sick! Link to comment Share on other sites More sharing options...
Det_Riot Posted January 29, 2014 Report Share Posted January 29, 2014 Voted! Had to go with Chris. No one can deny with how unbelievably badass opal and rio and steve-oh's cars are but I think Chris is taking on the biggest transformation from a daily un modded GT to a fully built machine! Link to comment Share on other sites More sharing options...
Prokiller Posted January 29, 2014 Author Report Share Posted January 29, 2014 I had to go with Steve-Oh. he's always a bridesmaid, never a bride...I think this is his 3rd attempt for ROTM Link to comment Share on other sites More sharing options...
Sleeperstang1994 Posted January 29, 2014 Report Share Posted January 29, 2014 well dang! i hate making these decisions Link to comment Share on other sites More sharing options...
Rolocut Posted January 29, 2014 Report Share Posted January 29, 2014 Voted! Had to go with Chris. No one can deny with how unbelievably badass opal and rio and steve-oh's cars are but I think Chris is taking on the biggest transformation from a daily un modded GT to a fully built machine!I completely agree, While i love dans car, Chris's car is getting to be beautiful with the mods and to be honest I do not get on here enough to see what everyone else is doing out there in the world. 1. @95opal2. @95RioSnake I also find it funny how the first two cars this month were rio red, haha im a sucker for that color Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted January 29, 2014 Moderators Report Share Posted January 29, 2014 Voted! Had to go with Chris. No one can deny with how unbelievably badass opal and rio and steve-oh's cars are but I think Chris is taking on the biggest transformation from a daily un modded GT to a fully built machine!Thanks Bryan! It's got a long way to go, but I'm finally making progress!I completely agree, While i love dans car, Chris's car is getting to be beautiful with the mods and to be honest I do not get on here enough to see what everyone else is doing out there in the world.1. @95opal2. @95RioSnakeI also find it funny how the first two cars this month were rio red, haha im a sucker for that colorI'm Chris, @95opal is Rich. Just clarifying since after a really rough day at work, I think I confused myself reading your post. Rich's car is bad ass and I hope I can live up to the level of help he has given me with my car. Link to comment Share on other sites More sharing options...
Steve-Oh Posted January 29, 2014 Report Share Posted January 29, 2014 stevo-oh's motor is sick! Thanks Tony! <3 I had to go with Steve-Oh. he's always a bridesmaid, never a bride...I think this is his 3rd attempt for ROTMThanks Ryan! Lol I think you're right, this might be round three... Link to comment Share on other sites More sharing options...
64bit_Tuning Posted January 30, 2014 Report Share Posted January 30, 2014 Voted for Steve... Because he paid me. Link to comment Share on other sites More sharing options...
Prokiller Posted January 30, 2014 Author Report Share Posted January 30, 2014 keep them coming guys, voting ends saturday morning Link to comment Share on other sites More sharing options...
95riosnake Posted January 30, 2014 Report Share Posted January 30, 2014 Are we supposed to vote? It's been a while since I've been in one of these so I forget how it works in regards to the participants. Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted January 30, 2014 Moderators Report Share Posted January 30, 2014 Are we supposed to vote? It's been a while since I've been in one of these so I forget how it works in regards to the participants. I've held off voting myself. I'm obviously not voting for myself (it won't help haha). Link to comment Share on other sites More sharing options...
95riosnake Posted January 30, 2014 Report Share Posted January 30, 2014 I've held off voting myself. I'm obviously not voting for myself (it won't help haha). Yea I would never vote for myself, just wasnt sure if we were supposed to hold off from voting or not. Link to comment Share on other sites More sharing options...
Steve-Oh Posted January 30, 2014 Report Share Posted January 30, 2014 Oh I voted lol... Obviously not for myself. Sent from Space Link to comment Share on other sites More sharing options...
Prokiller Posted January 30, 2014 Author Report Share Posted January 30, 2014 vote, but not for yourself. holding you to the honor system here Link to comment Share on other sites More sharing options...
95riosnake Posted January 30, 2014 Report Share Posted January 30, 2014 vote, but not for yourself. holding you to the honor system here Done, and honor upheld Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted January 30, 2014 Moderators Report Share Posted January 30, 2014 Done, and honor upheld Ditto. Link to comment Share on other sites More sharing options...
Tony Posted January 31, 2014 Report Share Posted January 31, 2014 ahaa...a side shot so i can chop the wheels on my next mustang...for whenever you sell them to me Link to comment Share on other sites More sharing options...
