Prokiller
July ROTM Voting
Patriotism
15 members have voted
  1. 1. Who will win our July ROTM
    • Tabres
      8
    • itsblue95
      1
    • WildWillyWalker
      3
    • Brian
      3
My fellow Americans,
We observe today, not a victory of individuals to be elevated to the ranks of nominees, but a celebration of freedom - symbolizing America's founding core of choice - signifying renewal, as well as change.  For I have sworn before you and Almighty Interwebz the same solemn oath our forebears prescribed over two centuries ago; that no beautiful SN95 will go unnoticed, unappreciated, or unloved.
The world is very different now. For man holds in his mortal hands the power to abolish all forms of vehicular slowness and all forms of dysfunction. And yet the same revolutionary beliefs for which our forebears fought are still at issue around the globe -- the belief that the rights of man come not from the generosity of Ford, but from the hand of the Aftermarket.
We dare not forget today that we are the heirs of that first revolution. Let the word go forth from this time and place, to friend and foe alike, that the torch has been passed to a new generation of Americans -- born in this age, tempered by depression, disciplined by a hard and bitter peace, proud of our ancient heritage, and unwilling to witness or permit the slow undoing of those human rights to which this nation has always been committed, and to which we are committed today at home and around the world.
Let every other car model know, whether it wishes us well or ill, that we shall pay any price, bear any burden, meet any hardship, support any friend, oppose any foe, to assure the survival and the success of liberty and the SN95 mustang.
This much we pledge -- and more.
Today we celebrate a core belief in the American way of life, the cast of a ballot to elect a leader.  I hereby open up this voting to commence!!
(this speech was mostly plagiarized from an American President, gold star goes to the person who knows which one).
Tabres
.020 Teksid
Stock Cobra crank
-11cc Manley pistons
Manley H-beams
ARP hardware – main studs, rod bolts, head studs
Ford Racing HV oil pump
Canton windage tray
Canton road-race oil-pan
03/04 Cobra cylinder heads
Livernois valve springs
Stock 96-98 Cobra cams
04 Mach 1 lower intake
Stock 96 Cobra upper intake
Modularspeed/On3Performance coolant crossover delete
Mishimoto Radiator
Hellion 76mm kit – billet wheel, ball bearing upgrade converted to blow-thru using a slot-style Pro-M maf
VS Racing turbo blanket
Turbosmart Eboost2 boost controller
Borla Stinger mufflers dumped before the axle
E85 fuel
Stock 96 fuel tank
Glenn’s Performance fuel pick-up tube
100 micron pre-filter
Dual Bosch 044 pumps run in parallel
10 micron post-filter
-10an feed – spits to two -8an, each feeding one rail
Aeromotive fuel rails
80lb Siemens Deka injectors
Aeromotive fuel pressure regulator
-6an return line
D&D built T56 – 03/04 Cobra spec
McLoud twin-disk
MGW shifter
Ford Racing 31-spline diff
31-spline Moser axles
Ford Racing 3.55 gears
Ford Racing differential cover
Maximum Motorsports k-member
Maximum Motorsports standard offset a-arms
Maximum Motorsports bumpsteer kit
Maximum Motorsports coil-overs w/Bilsteins in front
Maximum Motorsports caster/camber plates
Maximum Motorsports solid offset steering rack bushings
Maximum Motorsports solid steering shaft
Maximum Motorsports full-length subframe connectors
Maxumum Motorsports oil-filter relocation kit
Tokico shocks in rear with H&R SuperSport springs
03/04 Cobra center console
Maximum Motorsports 4-point roll-bar with diagonal bar option
Corbeau FX1 Pro seats in microsuede
Autometer Phantom oil pressure gauge
Autometer Phantom water temperature gauge
Autometer Phantom fuel pressure gauge
Redline Products leather e-brake boot
Saleen replica 18x9 & 18x10 wheels in chrome
Kumho Ecsta MX 275/35/18 & 295/35/18 tires
Tuned by Bob Kurgan of Kurgan Motorsports
On 17lbs of boost it made 690rwhp/691 rwtq
On 22lbs of boost it made 810rwhp/788rwtq
1262630_10100822842389355_2011825789_o.j
itsblue95
-Performance
K&N rai
Dyno tune wet nitrous kit
4:10 gear
X pipe
2 chamber flow masters
-Suspension
Team Z street beast rear suspension
Eibach Pro Kit lowering springs
-Exterior
Stock exterior
-Interior
Stock Interior
w/ Led gauges
Innovate Wide band
Glow Shift Nitrous gauge
Pro 5.0 short shifter
-Wheels/Tires
American Racing wheel 17x9 all around
Weld Rt-s 15x10 w/ 26x11.5 Et Street slicks (fronts on order 15x3.5)
019A0C75-DD64-4155-98C4-34D01BA565ED-114
WildWillyWalker
Interior:
Corbeau FX1's
Corbeau harness bar
Corbeau 5 pt harnesses
Exterior:
Tinted windows ~ 20%
Tinted headlights and tail lights
HIDs
Sequential Tail Lights
Stickers
Removed the ugly honeycomb grille
18x9 (265/35/18) / 18x10 (295/35/18) flat black Saleen wheels with Saleen style decals (blue/black)
Suspension:
MM caster/camber plates
MM front coilover kit 275lb springs
Stock Saleen struts/shocks
H&R rear super race springs
MM extreme duty adjustable RCLAs
Drivetrain:
2.8" SC pulley
SCT tuner
03/04 Cobra fuel pump assembly and tank
ARH 1 3/4" long tube headers
Off-road x-pipe
FRPP aluminum driveshaft
3.73 Gears
03/04 Cobra FRPP Trac-Lok
Yukon 31 spline axles
Cobra rear brake upgrade
OceanCityCarShow2014576-578HDR_zps4b1912
Brian
Engine & Exhaust:
Factory longblock with 99,xxx original miles
MSD Blaster Coilpack
BBK CAI
BBK Ceramic Longtube Headers with Stage 8 Locking Fasteners
BBK Catted X-Pipe
Bassani Stainless Steel Catback
Lethal Performance O2 Extensions
Fel-Pro Q2941 - Teflon Rear Main Seal
Drivetrain:
Factory T5 Transmission
MGW Orange Short Throw Shifter
Cobra Bob Shifter Gasket
Centerforce Dual Friction Clutch
FRPP Throw Out Bearing
FRPP Aluminum Driveshaft
FRPP Roller Pilot Bearing
FRPP Driveshaft Bolts
FRPP Clutch Fork
Maximum Motorsports Clutch Cable Package
Maximum Motorsports Clutch Cable Heat Shield
Maximum Motorsports Clutch Pedal Height Adjuster
ARP Flywheel Bolts
Fidanza 13.5lb Flywheel
AMSOIL ATF
Rear End:
Moser 31 Spline Axles
Detriot TrueTrac LSD
Strange 3.90 Ring and Pinion
FRPP Install Kit
FRPP Diff Girdle
FRPP Recalibration Tool
Royal Purple Gear Oil
Suspension & Steering:
Steeda Sport Springs
Borgeson Solid Steering Shaft with Vibration Reducer
Maximum Motorsports C&C Plates
Bilstein HD Grooved Shocks/Struts
Wheels & Tires:
Chrome Saleens - 18x9/18x10
Front Tires: BFG KDW - 265/35/ZR18
Rear Tires: BFG KDW - 295/35/ZR18
Exterior:
Export Mirrors
TheRetrofitSource Retrofitted Projector Headlights
1996-1998 Cobra rear bumper
Stainless Steel with Chrome Finish "COBRA" Bumper Inserts
Cobra Grille Emblem
MRT Hood Struts
Foglight Mod
TORQJNKY's "No Drill" Front License Plate Brackets
Window Tint (20%)
Interior:
FR500 Steering Wheel
2003 Cobra Seats
Blue LED Gauge Cluster & HVAC Mod
XstreetGif_USA.gif?1308445421
Glad to be in the company of some really, really nice cars!
Wish I could vote for everyone but I gotta toss mine to Brian.  I've just got a thing for white cars... :lol:
brians car is just minty fresh!!! wildwilly's car is just plain bad ass!! itsblues car is my fav kind of mustang.....a red new edge!! tarbereser's engine bay is awesome!!!
so tarsbesaesrba gets my vote this month!!! :P
Thank you to everyone that nominated me! It's an honor! These 3 cars are simple amazing! I haven't really been able to do much to this car since I'm still paying on it, but it has a long road ahead for it for sure. It will get to where I want it to be eventually!
Guest
