Prokiller Posted August 29, 2013 Report Share Posted August 29, 2013 Welcome everyone to our September Ride of the Month voting! This month for your viewing pleasure we have 4 cars that don't usually win much at car shows but they sure blow some doors and minds.First up with a mustang so dirty that it almost makes mustang fans despise the owner. From the accumulation of years of pine needles, sap and grime this thing is down right dirty but oh so fast. Give it up for.....SniveTroll:Performance:Ported PI heads WAP MMR stroker 850 301 CIDCrower stage 2 camsmanley internals top to bottom. Livernois oil scraperRR intake 60lb injectorsCPR fuel railsA1000 fuel system. TKO 600spec 3+spicer 4" Aluminum driveshaftUPR axle bracesUPR/GMS diff girdleWelded axle tubesAuburn Diff 3.73 gearsMoser axlesSuspension:QA1 A-armsQA1 K-memberGMS front coiloversKYB front strutsMM Caster platesSteeda Front Sway barSteeda Bumpsteer kitQA1 springs6PT roll bar w/ swing outs. Stiffler's trans mount. Custom subframe connectorsMM adj. LCAMM PHBH&R super race springsInterior:Autometer phantom and ultralite gaugesFAST dual widebandRaptor shift lightAPC race seatsOur next mustang up for the challenge is a black car that by outward appearances looks pretty stock cobra; understated wheels and export tails set it apart but most people won't be all over those changes. Not to mention the beast of a 427 under the hood. Give it up.....Steve-Oh:Performance:Ford Racing 427W crate motor 4.125 bore / 4.00 stroke SCAT forged crank & I-beam rods Forged Mahle pistons 10.5:1 Hydra roller cam .576/.600 ; 242/248 FRPP Aluminum “Z” heads 2.02 intake / 1.60 exhaust Ford EFI distributor, MSD cap/rotor Edlebrock Victor upper/lower BBK 75MM throttle body C&L intake tube FRPP 90MM L-MAF MSD 6A box Aeromotive rails, braided lines from firewall, FRPP 47lb'ers and a 255 Walbro BBK shorties, rigged up off-road “h”, Flowmaster exhaust FRPP 4.10 gears ...and a basically stock T-5 Transmission! Tuning by Keith Varin (The Mk2) Suspension:Maximum Motorsports K-member, A-arms, rear lower adj. control arms, front coilover kit & CC plates Blistein front struts with Hypercoils & Bilstein rear shocks with H&R Supersports Steeda full length subframe connectors Steeda bump steer Exterior:H.O. Fibertrends 3.5” Cobra R hood Export rear tailights DEPO projector headlights (matching sidemarkers) de-chromed and painted black “Poxenham” front tow hook Interior:Pioneer AVIC double din swap Autometer Lunar gauges Push button start (inactive) Crappy factory seats SVT rear seat delete / sub & amp mount (made by yours truly) Wheels / Tires:GT500 replicas: 18x9 front / 18x10 rear Pirelli P-Zero Rosso's: 265/35 front ; 315/30 rear Our third contestant is a relatively new member to our humble forum. I had the joy of seeing this work of art in person at Mustang Week. Let me tell you it's down right nasty. Let's here it for.....Haterbuilt:Performance-Stock bore and stroke b headed cobra 4.6 engineManley forged 9:1 compression pistonsManley H Beam rods w/ARP 2000 boltsStock Kellog forged crankARP main studs 2000ARP head studs 2000Manley stock size valvesManley valve springs and retainersStock porting on heads and intakePower adder On3 turbo kit with 70mm turbo on 17 psiStock T45Ram clutch stage 3Stock flywheelMoser 31 spline axlesGT500 Carrier3.27 gearFord Racing rear end girdleARP axle studsSuspension-UPR k-member and lower control armsUPR heavy duty k member and lower control arms boltsUPR Coil over kit with strange adjustable strutsJ&M caster camber platesUPR bump steer kit2003 Cobra steering rackUPR upper control arms and spherical bushingUPR axle spherical bushingUPR lower control arms and spherical bushingsUPR coilover kit with strange adjustable shocksExterior-Resprayed with Spies Hecker MB502 black and Sikkens clear coatShaved antennaCarbon Fiber cowl panelShaved windshield wipersNew belt moldingsNew front windshieldNew rear glass moldingsKaenan S281 spoilerSmoked tailights5% tintInterior-2003 Cobra charcoal gray interial panel conversion with center console2003 Cobra 10th anniversary floormats, door inserts, shift boot, and steering wheelCorbeau CR1 seatsRear seat deleteAutometer Phantom II boost and fuel psi gaugeInnovate MTX-L white wideband gaugeAutometer steering column gauge holderSpeed of Sound pillar podWheels/Tires-HRE 540 18x8.5 on Nitto NT555 245/40/18 tiresHRE 540 18x10.5 on Nitto NT555R 305/40/18Our final contestant is a man who is no stranger to a race track. whether it be the 1/4 or the crazy cones, he does it. Bright yellow is a favorite for a lot of guys so expect this puppy to shine! Let's welcome.....Alex302:Performance:04 Mach 1 4.6 32v and tremec 3650 trans with stiflers cross member.Mac long tubes, xpipe and flowtech dumps.JLT tru cai.DIY head cooling mod.Tuned by Eric at EFI unlimited. Brackes converted to hydo boost and 04 ABS pump.Front, 14" GT500 rotors with S197 two piston calipers and steel braided lines.Rear, stockSuspension:Front, BC coilovers Maximum Motorsports k-member with control armscobra rack, MM bump steer kit and MM steering shaft. Rear,BC coiloversMM extreme duty lower control arms MM panhard barExterior:Mach 1 chincobra tinted headlightsside scoops281 wingInteroir:Mach 1 clustercobra style pedalspro 5.0 short shifterWheels/Tires:18x9 18x10 FR500 with 265/285-35-18Car made 338 HP, 350 TQ rwhp and ran a 12.9 et at 109 mph in the 1/4 mile with a crappy 2.2 60'Click here to view the original image of 909x608px.Click here to view the original image of 1024x768px.Click here to view the original image of 909x608px.Thank you to everyone who nominated this month and to our finalists. May the best sleeper win!!!! Link to comment Share on other sites More sharing options...
OnyxCobra Posted August 29, 2013 Report Share Posted August 29, 2013 I thought sleepers were supposed to look mostly stock lol Link to comment Share on other sites More sharing options...
Det_Riot Posted August 29, 2013 Report Share Posted August 29, 2013 hmmmm hmmm hmmm decisions decisions decisions........ Link to comment Share on other sites More sharing options...
Ferocious Posted August 29, 2013 Report Share Posted August 29, 2013 I thought sleepers were supposed to look mostly stock lolAgreed" we have 4 cars that don't usually win much at car shows "I LOLd when I read that.All cars are awesome and unique in there own way. My votes locked in.Good luck gents. Link to comment Share on other sites More sharing options...
iRoush Posted August 29, 2013 Report Share Posted August 29, 2013 lol hardly sleepers but my vote is casted. Link to comment Share on other sites More sharing options...
NVRL8TE Posted August 29, 2013 Report Share Posted August 29, 2013 Voted. Link to comment Share on other sites More sharing options...
Str8racn Posted August 29, 2013 Report Share Posted August 29, 2013 Wow these are some tough choices. :peace: Link to comment Share on other sites More sharing options...
Schiffy Posted August 29, 2013 Report Share Posted August 29, 2013 DAMNIT! Who so I choose!? Link to comment Share on other sites More sharing options...
SniveTroll Posted August 29, 2013 Report Share Posted August 29, 2013 mine fresh out of the hen house! Link to comment Share on other sites More sharing options...
F8L GT Posted August 29, 2013 Report Share Posted August 29, 2013 [MENTION=21]Steve-Oh[/MENTION] I guess I never seen pics of your car. I never realized it was so freakin BadassSent from my MILESTONE3 using Tapatalk 2 Link to comment Share on other sites More sharing options...
95riosnake Posted August 29, 2013 Report Share Posted August 29, 2013 Had to give it to [MENTION=9]SniveTroll[/MENTION] because his car is the epitome of a sleeper IMO :thumb: Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted August 29, 2013 Moderators Report Share Posted August 29, 2013 Had to give it to @SniveTroll because his car is the epitome of a sleeper IMO :thumb:Exactly. When pine needles and faded paint can whip your ass, you know it's a sleeper. Link to comment Share on other sites More sharing options...
Steve@CJPP Posted August 29, 2013 Report Share Posted August 29, 2013 Great group of cars, good luck to all. Link to comment Share on other sites More sharing options...
Steve-Oh Posted August 29, 2013 Report Share Posted August 29, 2013 Had to give it to @SniveTroll because his car is the epitome of a sleeper IMO :thumb:Completely agree!- - - Updated - - -@Steve-Oh I guess I never seen pics of your car. I never realized it was so freakin BadassSent from my MILESTONE3 using Tapatalk 2Much appreciated! :thumbsup: Link to comment Share on other sites More sharing options...
Brian Posted August 29, 2013 Report Share Posted August 29, 2013 All nice cars but I casted my vote. Was a hard choice. Link to comment Share on other sites More sharing options...
haterbuilt Posted August 30, 2013 Report Share Posted August 30, 2013 i dont feel like my car fits the sleeper catergory too well i'd probably vote the first car too lol but its all good either way! Link to comment Share on other sites More sharing options...
Alex302 Posted August 30, 2013 Report Share Posted August 30, 2013 Happy to be nominated and on this list. Thank You. Link to comment Share on other sites More sharing options...
Tony Posted August 30, 2013 Report Share Posted August 30, 2013 dam how the hell has steve-oh never won yet, lol? dam that thing is sexy!!!! i want it. Link to comment Share on other sites More sharing options...
Prokiller Posted August 31, 2013 Author Report Share Posted August 31, 2013 last day of voting people! if you haven't already do it up!! Link to comment Share on other sites More sharing options...
Musturd Posted August 31, 2013 Report Share Posted August 31, 2013 Strictly business Link to comment Share on other sites More sharing options...
