Prokiller Posted May 29, 2014 Report Share Posted May 29, 2014 At the start of this month's nominations I figured we had enough people to fill the Green theme i wanted to create. After such a brutal winter, we've finally turned the corner and it's spring! Trees are in full green, flowers are blooming all over the place. Heck, everyone's car no matter what color it is, has a fine coating of yellow/green pollen on it. It ended up being that the other three top nominations were all orange. This year a lot of us are down still working on the cars, but I'm hoping that will change once car show season starts in earnest. Without further ado though, here are our June Ride of the Month contestants!! stprorolla49Performance- Paxton Novi 20003.25" pulleyCX racing 24x12x3 intercooler3" aluminum pipingCustom 4" powerpipeHPS Couplers39lb '03 Cobra injectorsHPX MAFVortech Maxflow BypassAviator fuel pumpKB 20 amp BAPBassani catted x-pipeBorla Stinger catback - fully polishedDynomax 4" double wall tipsPainted intercooler piping and powerpipe DHGCustom machined/smoothed valve covers painted Ford Wrinkle BlueCustom machined aluminum valve cover plaques Tuned by Kevin Hand at Wicked Motorsports - 404rwhp/398rwtq Suspension- Maximum Motorsports front coiloversHypercoil 250lb springsMaximum Motorsports c/c platesIntrax rear IRS springs (isos removed)Bilstein HD's front and rearBuilt '04 Cobra IRSFRPP 4.10 gearsFRPP IRS girdleMaximum Motorsports urethane subframe and diff IRS bushingsRotorPros zinc coated dimpled and slotted rotorsHawk Performance Ceramic pads Exterior- '01 Cobra bumper'01 Cobra tailsMach 1 chin spoilerBlack housing headlights'03 Cobra mirrors Interior- Sinis Engineering gauge ringsAutometer Sport Comp gaugesAutometer gauge bezelSpeed of Sound pillar podOn-In-60 illuminated build number coin deleteCustom Machined aluminum headlight knob and power point cover Wheels/Tires- OE Wheels LLC 18x9 and 18x10 Anthratice Bullitt reps265/35/18 and 315/30/18 Toyo Proxes R888's Orange 94: Engine4.2 v6 (1998 F-150)M112 Supercharger w/2.93 pulleyWater Methanol InjectedSSM adapter PlateMild ported split port heads and intakeComp Cams 259HR115 camComp Cams 26918 valve springsScorpion 1.73 roller rockersLightning 90mm MAFC&L boost pipeWalbro 255lph pumpCobra Blue 39lb injectors94 3.8 v6 stock headers94 3.8 v6 25% underdrive pulleysDouble roller timing chainStock polished valve coversDrivetrainT5 transmission (95GT)Cobra clutchStock clutch cableTriple hook quadrant/ locking firewall adjusterMac shifter8.8 fox diff assembly 3.73 gearsInterior00’ Mustang interiorBoost gaugeLED swapBillet pedals, turn signal, defrost, temp controls, headlight control, EbrakeFog light switchHidden antennaAlpine stereoCollection of Pool Ball shifter knobs (favorite: orange #5)ExteriorCobra bumperCobra R hoodCobra clear headlightsCobra fog lightsStock horizontal taillightsWinglessAntenna removedPassenger door keyhole removedBullitt Wheels 9" front 10" rear255/35ZR18 Hankook Venture Plus front275/35ZR18 Kumho rearPaint: 94 Ford “Bright Orange”SuspensionHAL KmemberMM CC platesEibach Pro- kit springsTokico D Spec Shocks StrutsFront FRPP Control ArmsAM UCA and LCAExhaustMac Cat Back w/polished tipsPacesetter H-pipeGutted Cats MaximumRisk Engine:331 c/i Dart Sportsman blockScat forged crankProbe pistons (8.5:1 c/r)Forged rodsAFR 185 head (out of the box)Edelbrock Performer RPM2 intake (out of the box)Custom CamFRPP roller rockersMoroso valve coversConverted to Fox accessories with aftermarket bracketsNo A/CNo Smog pumpB&G turbo headers with Borg Wagner 80mm turboHome made 4" downpipe, splits to 2 3" mufflers and 3" aluminum cold side.50mm wastegatePrecision intercoolerFuel:Custom fuel system with 2 walbro 255lph pumpsGlenns performance fuel pump manifold (provision for 3 walbro pumps)Glenns performance sumped tank-12an fuel filter, 10 micron/ pre pumps-10an fuel filter, 100 micron/ after pumps-10 an brainded feed line-8an brainded return with aeromotive, boost referenced regulator-Aeromotive fuel rails-96lb injectors-AEM water/meth injectionCooling:Edelbrock water pumpCustom BeCool radiator moved into the rad support about 2 inchesLincoln Mark VIII cooling fan160 degree thermostatFox coolant linesCustom radiator hoses (stainless steel)Engine management:Accel DFI gen 7AEM boost controllerAEM water/ meth controllerDrivetrain:Spec billet flywheelSpec clutch stage 3+ with aluminum pressure plate6speed Magnum t56custom aluminum driveshaft8.8 rear end with FRPP 31 spline differentialMoser 31 spline axlesSuspensionMaximum Motorsports:-MM 6 point cage -MM caster camber plates-MM rear lower control arms -Maximum Motorsports Kmember-MM tubular control arms-MM coil overs with Biltein shocks-MM panhardbar-MM Full length Subframe connectors-MM torque arm-03 Cobra spindles-MM bump steer-03 Cobra steering rack-MM power steering setupBrakes Front-14 inch Roush rotors with 4 piston Alcon Calipers and stainless brake hoses-ABS removedRearstock brakes with stainless brake hosesWheelsstreet:18" CCW sp20s 18x9 front 18x11 rear245's Pirelli Rosso tires & 305 Mickey Thompson Drag Radialstrack:CCW Drag Pack (17"front/ 16" rear)H&M RaceMaster front tires & 28x10 Hoosier slicks ExteriorCobra bumper front & rear96-98 tail lightstwo tone Kandy Tangerine & GreyCervinis 00 style Cobra R hoodShaved antenna, etc, etcInterior, Sound & other Misc-Corbeau seats-Custom Aluminum rear seat delete-Complete dash gauges from Autometer (DFI does not allow you to run stock gauges on sn95, 5.0 since the factory wiring harness is removed) tach, speedo, volt, water temp, fuel level, fuel pressure, oil pressure, oil temp, boost controller, Wideband.-Jensen radio, with Pioneer door and rear deck speakers, 450watt amplifier and single 12" bass speaker-Remote mounted oil filter, oil cooler, oil thermostat-hids-other minor stuffcar dynoed at 740rwhp@ ~13lbs of boost on 93 pump gas and water/meth injection. kinda of a cheat photo as it's two in one, but i'll let it slide Poisoned Pony Engine- stock Mach 1 engine, 121k miles- BBK underdrive pullies- SCT Strategy tune Exhaust- BBK longtube headers- BBK offroad X-pipe- Magnaflow Magnapack catback Drivetrain- OEM Valeo clutch kit- hybrid short throw shifter, stock 3650 base, fox body T-5 handle- FRPP 4.10 gears Suspension- Eibach Sportline springs- OEM Tokico Exterior- Fresh repainted Competition Orange in March 2014- Custom hood stripe done '69 Mach 1 style- 18x9 and 18x10 Black FR500's Good luck all of you! Link to comment Share on other sites More sharing options...
Brian Posted May 29, 2014 Report Share Posted May 29, 2014 Damn.... this is going to take me a while to decide. Link to comment Share on other sites More sharing options...
Blackmage Posted May 29, 2014 Report Share Posted May 29, 2014 ugh, i have it narrowed down to two... but who shall get THE VOTE! .... great candidates this month Link to comment Share on other sites More sharing options...
95riosnake Posted May 29, 2014 Report Share Posted May 29, 2014 Well shit, this is going to be tough. Link to comment Share on other sites More sharing options...
Ferocious Posted May 29, 2014 Report Share Posted May 29, 2014 Mmmmm, that bullitt <3 Link to comment Share on other sites More sharing options...
Orange 94 Posted May 29, 2014 Report Share Posted May 29, 2014 Great selection!I don't compare to the competition, but appreciate the nomination Link to comment Share on other sites More sharing options...
Tony Posted May 29, 2014 Report Share Posted May 29, 2014 i seriously love all the cars here!! it's just that i have a soft spot for an underdog like 'ol OJ building an amazing performing AND looking sixxer!!! love that fn car!! got my vote fo sho!! Link to comment Share on other sites More sharing options...
OnyxCobra Posted May 30, 2014 Report Share Posted May 30, 2014 these are all great examples of different cars/builds. good luck guys! Link to comment Share on other sites More sharing options...
64bit_Tuning Posted May 30, 2014 Report Share Posted May 30, 2014 Obvious choice is obvious. Link to comment Share on other sites More sharing options...
stang232 Posted May 30, 2014 Report Share Posted May 30, 2014 All cars are great and represent different ideas for modifications so the choice is tough.But my vote goes to the beautiful Bullit @stprorolla49 Link to comment Share on other sites More sharing options...
MaximumRisk Posted May 30, 2014 Report Share Posted May 30, 2014 thank you guys for the nomination, much appreciated! I just love the simple, yet really cool/different/you-dont-see-everyday build that @Orange 94 did!!! He gets my vote Link to comment Share on other sites More sharing options...
95riosnake Posted May 30, 2014 Report Share Posted May 30, 2014 Vote cast! Link to comment Share on other sites More sharing options...
RockinHrse_98 Posted May 31, 2014 Report Share Posted May 31, 2014 Dang, this is a tough choice. Link to comment Share on other sites More sharing options...
smallblocksn95 Posted June 1, 2014 Report Share Posted June 1, 2014 Voted Link to comment Share on other sites More sharing options...
95riosnake Posted June 1, 2014 Report Share Posted June 1, 2014 Btw @stprorolla49 you got my vote Mike The attention to detail is something that definitely resonates with me Side note, please tell me what your user name means, I've always wondered lol. Link to comment Share on other sites More sharing options...
stprorolla49 Posted June 1, 2014 Report Share Posted June 1, 2014 Thanks for the nomination and all the votes guys! @95riosnake Dan, my username is from when I used to skate when I was in middle school when I first signed up for stangnet. My old skates were ST Pro's, hence the username. It's super gay now but if I changed it, people might not recognize me. Who knows, maybe I'll change it. Back on topic, my vote is cast! Link to comment Share on other sites More sharing options...
95riosnake Posted June 1, 2014 Report Share Posted June 1, 2014 Thanks for the nomination and all the votes guys! @95riosnake Dan, my username is from when I used to skate when I was in middle school when I first signed up for stangnet. My old skates were ST Pro's, hence the username. It's super gay now but if I changed it, people might not recognize me. Who knows, maybe I'll change it.Back on topic, my vote is cast! You shall not change the user name! I was just curious lol Link to comment Share on other sites More sharing options...
Prokiller Posted June 2, 2014 Author Report Share Posted June 2, 2014 Thanks for the nomination and all the votes guys! @95riosnake Dan, my username is from when I used to skate when I was in middle school when I first signed up for stangnet. My old skates were ST Pro's, hence the username. It's super gay now but if I changed it, people might not recognize me. Who knows, maybe I'll change it.Back on topic, my vote is cast!here i always thought you like stone temple pilots...voting closes tomorrow morning so if you haven't voted, now's the time Link to comment Share on other sites More sharing options...
Det_Riot Posted June 2, 2014 Report Share Posted June 2, 2014 I had a feeling this month would be close! Link to comment Share on other sites More sharing options...
Prokiller Posted June 3, 2014 Author Report Share Posted June 3, 2014 voting is now closed Link to comment Share on other sites More sharing options...
